Many of you have been hearing about this of late. My 68 rebuilt Bonneville has always, since I have had it, had a very slight stumble off idle or otherwise closed throttle. Coasting etc. Always idles fine. Always runs smooth and quick, except for that slight stumble off idle. So I went through most everything. Tri spark ignition timing was off about 1 degree. Fixed it. Did the valve adjustments. Spot on. Compression very even at about 145. Went through the carbs. Found I had sleeved slides. Looked top shelf. Very little play. Low jets clean and open. Had replaced main and needle jets with stock size amal bits. Also new needles on center groove. Balanced slides. Plugs looked pretty good and never fouled. Never did a throttle chop. Don't fancy reaching for the key at classic triumph hyper speeds. Experimented with different float levels on brand new stay up floats with alloy needles. Nothing cured or changed that little stumble. So I said screw it, and got new Premier carbs. Key info: I pulled the carb balance tubes and manifolds off the head. They looked great. Cleaned them up, added new gaskets and new phenolic blocks and reinstalled everything with the new premiers. Balanced the slides etc and fired it up. Ran crap. Removed carbs. Adjusted float heights (way off), sprayed everything with carb cleaner and air. Reinstalled and it ran better but left side was awful. Went through it carefully, reinstalled and still crap. Removed it and put the old carb on and it ran nice, but STILL had my little stumble. Also another new development is, at very low revs, as when I am leaving from a stop in first gear and the revs go down for a moment, it stops firing on the left cylinder. Picks up the moment I pull in clutch and increase revs. Looked at plugs. Right side is fine, if not a touch lean, and left side is sooty and black. Said "Hmm". installed new plug, gapped to 30 thou and restarted. Same ****. Double Hmm. So either the spark is getting interrupted, or the mixture is very bad. I am out of time right now, but I intend to remove the left plug wire, stick a spare plug in it, start it on the right plug and observe the spark, looking for to see if it is steady or erratic. My plug wires are too short to swap sides. Also this bike has been 1st kick every single time. Not so much any more. If anyone has any better, or other ideas, please shout it out.
