Would I switch to Lithium technology?
No and for a lots of reasons but primarily because of the complexity of preserve capacity and battery life.
Can it be used and is there benefits?
Yes - A low self discharge and high power density reduces the weight significantly compared to a Pb battery.
Also high cranking amps reducing voltage drop when high power consumption is needed (starting the engine)
Here's a few of the drawbacks and conditions that will either -
- shorten lifespan of the battery (1)
- destroy the battery within a short period of time (2)
- or destroy battery instantly and potentially make it burst in to flames (3)
- Price tag - still way to expensive caused by "new" technology (although it's been around for a decade)
Very low capacity - if you have a bike that once in a while dos'nt start right away, you will run out of power quite fast and if so, remember to stop trying starting the bike at 20% capacity at the latest (1) Going under 5% might and under 2%, certainly destroy the battery (2)
A short-circuit starter motor will cause the battery to destruct (3)
- On a "12V" Lithium battery, the voltage must not get under 10,5V (2)
This is normal controlled by the built-in protection circuit - if the battery is equipped with the circuit - but means in practice that the battery capacity is lower than stated.
- Can't be used in a temperature under - 20° C or over 60-80° C (2 and 3)
- Should be kept within a state of 20 to 80% charged (1)
It should Ideally be hold in a state of 60% charged to obtain maximum lifespan - around 300 to 500 charges.
- Your regulator on the bike and the built-in overcharge circuit in the battery - if it has one - is set to obtain a 100% charge (1)
- Should never be charged to full capacity unless you plan to use the battery (start the bike) right away or within a day after a full charge (1)
You just might get lucky and keep the charge within the 20-80% all the time and it will probably last you 5-10 years if you don't start the bike to often.
In the end - the choice is yours 🙂
