T100 downshifting ‘klunk’ - Triumph Forum: Triumph Rat Motorcycle Forums
 11Likes
post #1 of 18 (permalink) Old 11-05-2019, 12:18 PM Thread Starter
Main Motorcycle: 2017 T100
LA-Liquid-T100's Avatar
Other Motorcycle: 1977 CB750F2
Looking to see if anyone knows about why my water cooled T100 has what feels like a ‘klunk’ noise while high speed downshifting from 2nd to 1st. This noise is also felt through the pegs...it feels as if the bike lurches forward a bit during the process.
It’s not the typical mechanical noise and feel of this bike.
It’s sporadic when it’s happening but it seems it’s in the initial stage of some sort of internal failure. Bike has 20k and is coming up in the end of warranty.
Sent from my iPad using Tapatalk
LA-Liquid-T100 is offline
post #2 of 18 (permalink) Old 11-05-2019, 01:09 PM
Main Motorcycle: 2015 BMW K1600GTL
vistavette's Avatar
Other Motorcycle: 2017 Triumph T120 Black
Well, can you clarify the statement "high speed downshifting"? Do you mean quickly?
Sent from my Pixel 3a using Tapatalk
2017 Triumph Bonneville T120
2015 BMW K1600 GTL
vistavette is offline
post #3 of 18 (permalink) Old 11-05-2019, 03:03 PM
Main Motorcycle: '19 Speed Twin 1200
Other Motorcycle: '12 Bonneville SE
Extra Motorcycle: '14 Honda CTX700N
From my experience, the shift from 2nd to 1st is best made while almost at a complete stop and close to idle rpm. I have found harsh shifting into 1st from neutral above 2000 rpm and down shifting from 2nd to 1st with speeds over 15 mph. I suppose the harshness could be described as a hard klunk, but no lurching.
The lurching could be a sign that your clutch cable needs to be a adjusted. Possibly there is too much slack causing the clutch to not fully disengage during shifting.
jazzyj is offline
post #4 of 18 (permalink) Old 11-05-2019, 03:39 PM
Main Motorcycle: Daytona 675R
CafRacer's Avatar
Other Motorcycle: Thruxton R
I don't think I've changed down from 2nd to 1st at anything more than walking pace never mind at "high speed".
Even then I'd be blipping the throttle in between to match the engine speed.
But as said already check your clutch adjustment.
lambroving likes this.
2016 Thruxton R, track racer kit, x pipe decat, US Vance and Hines, de-snorkel, no slack throttle mod, heated grips, 17t fr sprocket, quickshifter, TuneECU remap with custom riding modes, tubeless conversion.
CafRacer is online now
post #5 of 18 (permalink) Old 11-06-2019, 02:27 AM
Main Motorcycle: Street Twin
Other Motorcycle: T595
Extra Motorcycle: CB900F
Same here. Why do you ever require first when in motion except for pulling away or on a race bike with high gearing. Last time I used it on a bike it was 1979 and a fs1e
Sent from my Moto G (4) using Tapatalk
Tripletotwin is offline
post #6 of 18 (permalink) Old 11-06-2019, 03:18 AM
Main Motorcycle: Triumph Street Twin '17
Other Motorcycle: Mutt Mongrel 250
It depends on where you ride, to be fair - I ride dail in London and regularly drop down to first when filtering or approaching junctions where timing will get you across without stopping. Second starts to bog below 18mph, and a good proportion of London riding is below 20, so I change down to first while moving quite often.
It’s not changing down at high speed though...
step-hent is online now
post #7 of 18 (permalink) Old 11-06-2019, 03:21 AM
Are perhaps I will bump into you some time between Heathrow and Shoreditch then but after April as I've given up commuting in the winter.
post #8 of 18 (permalink) Old 11-06-2019, 06:01 PM Thread Starter
I tend to ride a little fast on my bike... I keep the revs up to power out of traffic. In LA we split lanes so like it’s mentioned above, you want to have the ability to quickly get on with it.
I appreciate the input but so far looks like nobody has experienced the same. It’s definitely not normal. It’s a very solid, “something is slipping” internally, enough to feel it in the pegs. I will take it to the dealer next week but have the suspicion that they won’t find anything wrong.
post #9 of 18 (permalink) Old 11-06-2019, 06:07 PM
vistavette's Avatar
If you're down shifting into 1st at any speed over a slow walk, of course it's going to be an issue. I think the bike has a slipper clutch that keeps the rear wheel from locking up. I live in Las Vegas and visit S California, and I lane split when there. I've never needed to downshift to 1st while moving.
Tripletotwin likes this.
2015 BMW K1600 GTL
post #10 of 18 (permalink) Old 11-07-2019, 04:02 AM
I'm sorry I commute hard in traffic and again only every need to change into first if coming to a stop and the traffic moves again always walking pace. There is a reason why neutral sits between 1st and 2nd. I would try adopting a different riding style before assuming the bikes playing up
