Camshaft Timing - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By CafRacer
post #1 of 8 (permalink) Old 10-16-2019, 10:54 AM Thread Starter
Other Motorcycle: 1978 Suzuki GS550
Camshaft Timing
So, I’m stepping through the 20k service on my T120. I’ve mostly been referring to the Haynes manual since it’s more procedural and less about removal/installation.
However in the maintenance table of the triumph manual, it mentions Camshaft Timing for 20,000 miles. But there’s no procedure for verifying camshaft timing that I can find in either manual. The only similar thing I can see is in the installation instructions for the camshaft which involves using camshaft timing plate (a special triumph part).
Has anyone done this procedure? Is the timing plate the proper way to verify cam timing, or is there another way aside from the installation instructions?
isoparmesan is offline
post #2 of 8 (permalink) Old 10-16-2019, 02:57 PM
Main Motorcycle: Daytona 675R
CafRacer's Avatar
Other Motorcycle: Thruxton R
Are you sure they haven't got it mixed up with the valve clearance check, that's due at 20000 miles according to the triumph service sheet, no mention of camshaft timing on any service sheet I've ever seen.
Only needs to be checked when the camshaft or chain has been removed.
LA-Liquid-T100 likes this.
2016 Thruxton R, track racer kit, x pipe decat, US Vance and Hines, de-snorkel, no slack throttle mod, heated grips, 17t fr sprocket, quickshifter, TuneECU remap with custom riding modes, tubeless conversion.
CafRacer is online now
post #3 of 8 (permalink) Old 10-16-2019, 04:25 PM Thread Starter
It's listed right under the valve clearance check in the maintenance table.
post #4 of 8 (permalink) Old 10-16-2019, 07:38 PM
Main Motorcycle: 2016 Street Twin
There are those of us who have changed camshafts on these bikes so I can tell you.. if you go to the effort of checking your valve clearances to check the cam timing you need to remove the alternator cover then line the crankshaft up with the timing hole and then check the slot in the camshaft is level with the surface of the cylinder head, if it’s upside down you need to turn the crankshaft another turn, line up and check again...
This will be detailed in the Haynes/tritun manual, but you will then need an alternator gasket and possibly new o rings for the balancer shaft.
It is however highly unlikely the timing would be off, you would notice the bike running rough, so that whole procedure might be unnecessary
shadydaverave is offline
post #5 of 8 (permalink) Old 10-16-2019, 08:14 PM
CafRacer's Avatar
Can you post a screenshot, it's not on any service sheet I've ever seen, certainly not for the Thruxton which has basically the same engine.
post #6 of 8 (permalink) Old 10-16-2019, 08:56 PM Thread Starter
Here’s the page from the tritun manual.
post #7 of 8 (permalink) Old 10-17-2019, 09:38 AM
CafRacer's Avatar
Never heard of tritun, is that a forum?
Have you got your owner's manual, it's not mentioned in the copy I've got or in the official triumph service manual, although they have been known to be wrong in the past, apologies if I'm mistaken.
It won't have moved anyway, the most you need to do with line up the marks on the the cam gear, I don't know if the gear is slotted but it won't have moved on the cam.
Because it coincides with the valve clearance check you'd look at it anyway.
post #8 of 8 (permalink) Old 10-18-2019, 01:12 AM Thread Starter
It’s the site that has official triumph service documentation. It’s what dealers use, I believe.
I’ve already buttoned it up after adjusting the valves, and I didn’t specifically check the cam gear marks. The bike is running totally fine though, so I think I’m just going to disregard this for now.
