Bulb low beam out. - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 20 (permalink) Old 09-17-2019, 02:54 PM Thread Starter
Main Motorcycle: 2016 T120 Bonneville
datarider's Avatar
Other Motorcycle: 1970 BSA Victor 441
Send a message via Skype™ to datarider
Bulb low beam out.
How do you get the bezel off to change headlamp bulb? There is a hole at the bottom, but nothing seems to release. 2016 T120.
datarider is online now
post #2 of 20 (permalink) Old 09-17-2019, 03:24 PM
Main Motorcycle: Daytona 675R
Scottty's Avatar
Other Motorcycle: Thruxton R
If it's the same as the the 2016 Thruxton there are two screws behind the bezel which secure the headlight assembly into the bowl.
Scottty is online now
post #3 of 20 (permalink) Old 09-17-2019, 03:25 PM
Main Motorcycle: 2019 Speed Twin
Kinjane's Avatar
There are two bolts to remove at roughly 4 and 8 o’clock and the bezel has to be lifted up to release the (unseen) securing clip.
When replacing the rim you’ll need to pull down the shield at around 1 o’clock as the securing clip is located otherwise it’ll sit on the wrong side of the shield and the clip will deform the headlamp shell.
Whenever I see a bike advertised with 'a shed load of extras' I often wonder how well it handled with a deckchair, lawnmower, some hose and a rake strapped to it.
Kinjane is offline
post #4 of 20 (permalink) Old 09-17-2019, 03:33 PM
Main Motorcycle: 2018 T120
tahtye's Avatar
Other Motorcycle: 2018 Tiger 800 XRx
#12 in this exploded view.
tahtye is offline
post #5 of 20 (permalink) Old 09-17-2019, 08:38 PM
geb
Main Motorcycle: 2009 H-D Dyna Glide
Other Motorcycle: 2016 Triumph T120
Extra Motorcycle: 1998 H-D 1200XLH
Further,....beware, there is a small connector on the back of the headlight assembly that if not released carefully is easily broken.
There was a threat on this subject some time ago.
geb is offline
post #6 of 20 (permalink) Old 09-19-2019, 09:11 PM Thread Starter
datarider's Avatar
Cool Bezel removal
Thanks everyone for your solution. I was expecting a screw on the bezel and did not realize it was the screws at 8 and 4. I will get at this tomorrow. I'm wondering too, why low beam burned out. I assume the bulb contains both high and low? And I assume that it is the low beam which comes on automatically when starting and running the bike. Not familiar with the led light tech, other then I believe it should last for many years. Even my "70 BSA, with the standard bulb has never burned out.
post #7 of 20 (permalink) Old 09-19-2019, 09:44 PM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Right, the bulb has hi and low filaments, so orientation during installation is important. The OEM halogen bulbs usually last a long time. I'm still on the original. Auto parts stores do sell spares though. I figure it's the fact that I have one taped inside of my right side cover that keeps my OEM bulb from burning out. It's right next to the necessary 5mm hex key.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is online now
post #8 of 20 (permalink) Old 09-20-2019, 09:10 PM Thread Starter
datarider's Avatar
Good info. I used to carry a spare clutch cable, bulb and zener diode in my headlamp on my past Bonnevilles, and of course they were never needed.
post #9 of 20 (permalink) Old 09-21-2019, 10:32 AM
Main Motorcycle: 2016 Street Twin
StreetTwin's Avatar
The OEM bulbs have a working life of 450 to 900 hours. Mine lasted 3 years and approximately 30,000 km. (18,000 miles)
Inexpensive replacements (less than $2) can be had from China on Ebay.
10,000 kilometers later, it is still working and just as bright as OEM bulbs at a fraction of their cost.
https://www.ebay.ca/itm/Car-SUV-H4-H...JZybhK&vxp=mtr
tahtye likes this.
StreetTwin is online now
post #10 of 20 (permalink) Old 09-21-2019, 02:58 PM
bluesforchallah's Avatar
Location: Shakedown Street and Eletric Ave., Seattle, Wa
The bulb in my Speed Twin lasted 7 months / 3600 miles. Replaced it with with a Sylvania Silverstar Ultra H4 bulb. Hopefully it'll give me a little bit more life than the Philips did.
Chris / RudeBoy BIR #309
Past rides:2014 Scrambler, 2008 T100, 1975 Honda CB400/4, 1989 Honda GB500, 1965 Honda CB450 Black Bomber, 1972 BSA A75 Rocket3
bluesforchallah is offline
