Broken Gear Lever - Triumph Forum: Triumph Rat Motorcycle Forums
 10Likes
post #1 of 51 (permalink) Old 09-07-2019, 01:06 PM Thread Starter
Was riding in my Speed Twin when I noticed my gear level wasn't in the usual spot. Stuck in 1st gear I rode back home.
Once home, took a picture of the gear lever. It looks like a sheered bolt inside and not even flush against the outside wall as you would expect. How does this happen?
What options do I have to fix this myself.
I guess I should try and get the metal bolt out of the hole? Any opinions would be good. Dealer will take a month. Images attached
ID:	654788   Click image for larger version
ericthered is offline
post #2 of 51 (permalink) Old 09-07-2019, 03:40 PM
Main Motorcycle: Speed Twin
Other Motorcycle: Ducati Multistrada
Extra Motorcycle: KTM 300 & 500
I bet it was loose-- many of us find these loose and backing out--should be a recall
maybe dealer can order new one for you
and just give it to you to install at home
and cover the part under warranty
put some blue loctite on thread of new part
old broken bolt may spin out easy if no loctite on it
try a pick and try to spin it out
or take the shifter off and take it and linkage to dealer
markg333 is online now
post #3 of 51 (permalink) Old 09-07-2019, 05:13 PM Thread Starter
Used a drill bit and then a thread extractor. Have a temporary solution for now until I hear back from dealer on warranty status. Crazy how a 6 month old part is breaking
post #4 of 51 (permalink) Old 09-08-2019, 05:57 PM
Id love the hear about the temporary solution- I cant see how anything would work :-)
and how long it takes dealer to get parts -we keep hearing how long it takes to get parts from Triumph
I looked up those ball end sockets and amazingly you cant buy them--or just them and the center rod as an assembly
each end comes only with the part they connect too -how dumb is that
so in your case you need to buy the gear shifter for $82 to get the ball end socket!
I think these sockets are loosening up and then breaking because they are half way turned out, not seated and stressed
PSA -check yours regular and even put a dab of blue loctite on threads
mine was loose brand new so I caught it before it could back out much
Name:	Screen Shot 2019-09-08 at 5.56.59 PM.jpg
post #5 of 51 (permalink) Old 09-08-2019, 10:49 PM Thread Starter
Yeah that's true, I would love to know if there is a generic part i could use here instead of the entire assembly from Triumph
The temporary solution is to thread the old socket back in and baby the gears until I hear back from warranty. As it's already weakened (and with only 3 threads), it will come lose anytime.
post #6 of 51 (permalink) Old 09-09-2019, 07:39 AM
Main Motorcycle: Daytona 675R
CafRacer's Avatar
Other Motorcycle: Thruxton R
I would just buy a 6mm rod end bearing such as this one from eBay and put a new bolt through into the gear lever, job done.
Just check whether yours is left hand or right hand thread.
https://www.ebay.co.uk/itm/SI6T-K-Ro...edirect=mobile
You'll need to place washers either side of the Rose joint to pack it out to the correct distance and so you don't lock up the joint, definitely looks like yours has snapped because it backed off, mine's threaded nearly to the other side of the the gear lever.
CafRacer is online now
post #7 of 51 (permalink) Old 09-09-2019, 10:36 PM Thread Starter
Well this took an interesting turn. The warranty claim was denied. They say that the bike looks like it was dropped from the factory indent on the pipe (see attached picture). Will update you guys here how it goes. They wanted a picture without me holding the rod end. So they could "see what I was hiding behind". This is a joke LOL
You guys all have this indent too right? Just want to make sure
post #8 of 51 (permalink) Old 09-09-2019, 11:31 PM
Kinda stuff that pisses me off
first off these things are coming loose--as I mentioned it should be a recall
I don't think they are loctite from factory or maybe they didn't tighten then right
Several folks here caught them loose- -including me
and that DENT is normal- ugh
who is your dealer if you dont mind or what city/state ?
have a look at what the dent is for
post #9 of 51 (permalink) Old 09-09-2019, 11:53 PM Thread Starter
Thanks, dealer is one in Canada, Ontario. I'll be sure to mention their name if they don't sort this out. Had to tell them to look at all their other floor models, what a bunch of goons.
LA-Liquid-T100 likes this.
post #10 of 51 (permalink) Old 09-10-2019, 02:47 AM
Main Motorcycle: TBS,Daytona 900
Other Motorcycle: Speed Twin
Yeah we all have that dent........It astonishes me how incompetent some dealers are.
Burren Boyo. is offline
