2016 t120. Hit the starter then click click click... - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #1 of 29 (permalink) Old 08-31-2019, 11:30 AM Thread Starter
Main Motorcycle: Triumph T120 Black
Bike is usually on trickle charger except last two weeks. Five minutes on trickle charger and bike started up. Can the battery be shot already? Any other issues with the bike Iím not aware of?
Sent from my iPhone using Tapatalk
George107 is offline
post #2 of 29 (permalink) Old 08-31-2019, 11:58 AM
Main Motorcycle: 2015 BMW K1600GTL
vistavette's Avatar
Other Motorcycle: 2017 Triumph T120 Black
Yes. Batteries go bad and they just need to be replaced. Although two weeks is more than long enough to drain a battery. Keep an eye on it
Sent from my Pixel 3a using Tapatalk
2017 Triumph Bonneville T120
2015 BMW K1600 GTL
vistavette is offline
post #3 of 29 (permalink) Old 08-31-2019, 01:22 PM Thread Starter
I get that. Iím questioning it due to the fact that just 5 minutes on trickle charge was enough to charge it. Will check the voltage after lunch. Thanks
post #4 of 29 (permalink) Old 08-31-2019, 01:24 PM
vistavette's Avatar
Ah....it was probably just weak from sitting. I'd bet the battery is fine
2015 BMW K1600 GTL
post #5 of 29 (permalink) Old 08-31-2019, 01:37 PM
Have your battery load tested and then you'll know if it's good or bad.
George107 likes this.
justalurker is offline
post #6 of 29 (permalink) Old 08-31-2019, 01:43 PM
Main Motorcycle: 2018 T120
tahtye's Avatar
Other Motorcycle: 2018 Tiger 800 XRx
Iíve heard the ecu wants a minimum amount of voltage to start. If itís below that threshold, no go. Perhaps your battery voltage was just below the threshold. That is why it only took a short while on the charger to get it over the hump.
Thatís my guess..
retjustdad53 likes this.
tahtye is online now
post #7 of 29 (permalink) Old 08-31-2019, 01:46 PM Thread Starter
Thatís my guess..
Thatís what Iím hoping... voltage meter will tell
post #8 of 29 (permalink) Old 08-31-2019, 01:58 PM
A load test of the battery will tell... not a volt meter. The battery must hold voltage under load.
post #9 of 29 (permalink) Old 08-31-2019, 02:47 PM Thread Starter
Tested w multimeter. Ran 14.25 volts at 5k rpms.
post #10 of 29 (permalink) Old 08-31-2019, 02:49 PM Thread Starter
So I just tested the battery. 12.87 prior to ignition. 14.21-14.26 at idle w high beam on. 14.25 pretty steady at 5k rpms. Itís off the trickle charger so Iíll test it again in about 2 hrs. It cxled my ride today but I think Iím ok.
