Thruxton 1200 to Bonneville T120 ECU Swap and TuneECU - Triumph Forum: Triumph Rat Motorcycle Forums
 6Likes
  • 2 Post By Lawton's_Cycle
  • 1 Post By Lawton's_Cycle
  • 2 Post By kdxandrew
post #1 of 9 (permalink) Old 08-26-2019, 10:25 AM Thread Starter
I'll summarize the whole event but i just wanted to share an experience with the community. Because the engines between the Thruxton 1200 and the T120 are nearly identical, we installed a Thruxton 1200 ECU to a T120 just to see if it would work. Differences being the Thruxton has a lighter crank and 11:1 CR instead of T120s 10:1 CR.
It took us swapping out the ECU, instrument cluster, and ABS module before the ECU was happy. It was very hard to start and once it did start, it idled at 3000 rpm and ran poorly.
I was hoping to pick up 10-15 hp +/- from the more aggressive tune but it was a failure. This was attempted on a stock T120 with Vance and Hines slip-ons.
Other than the compression ratio and lighter crank, I'm not aware of any other mechanical changes between the Thruxton and T120 engine. The air box and exhaust are different, but I believe the bike would still start and at least idle some what decently. I must be missing some other difference.
All of this may be a moot point as TuneECU has listed the Bobber 1200 as a bike that can be remapped. Is the T120 in the works for mapping ability?
welshrob and GreenBonnie01 like this.
Lawton's_Cycle is offline
post #2 of 9 (permalink) Old 09-06-2019, 05:06 PM
Main Motorcycle: Triumph T120
Breton's Avatar
Other Motorcycle: BMW R100RT
Valves diagrams aren't differents ?
It would explain...
Breton is offline
post #3 of 9 (permalink) Old 09-07-2019, 01:45 AM
Dougl1000's Avatar
The pistons, valves and cams have the same part numbers, I believe. Can you get more compression just from timing? It would be nice to drop a Thruxton R tune into a T120.
Dougl1000 is online now
post #4 of 9 (permalink) Old 09-09-2019, 02:37 PM Thread Starter
Thruxton has a different part number cylinder head. Most likely where the added compression comes from.
post #5 of 9 (permalink) Old 09-09-2019, 03:42 PM
Dougl1000's Avatar
Yes, I remember someone talking about “shaving” the head.
post #6 of 9 (permalink) Old 09-09-2019, 09:06 PM
Main Motorcycle: 2016 THRUXTON S/GREEN
Other Motorcycle: FZ 09
Extra Motorcycle: 2016 FZ07
For all the trouble why not just flog the 120 and get the Speed Twin.
vitesse is offline
post #7 of 9 (permalink) Old 09-11-2019, 09:28 AM Thread Starter
Good question. I very much like the riding position and styling of the Bonneville. I also have custom paint, Ohlins suspension, and some other accessories that wouldn't transfer over.
kdxandrew likes this.
post #8 of 9 (permalink) Old 09-18-2019, 04:37 AM
Main Motorcycle: Speed Twin
kdxandrew's Avatar
Other Motorcycle: Enfield 350
Love the spirit of adventure - Could you achieve the desired result with a tec cam, x-pipe and PCV tune?
vitesse and CafRacer like this.
kdxandrew is offline
post #9 of 9 (permalink) Old 09-19-2019, 09:47 AM Thread Starter
It's funny you mention that! I am indeed working on those now. Those are my winter projects for this year. I also found a complete Thruxton 1200 exhaust system that I'm adapting to fit. I already have the header pipes installed as they install with zero modification. It's the intermediate pipes to the mufflers that will require some fabbing to connect to a set of Predator Pros. The stock T120 tubing is drastically smaller than the Thruxton.
I've found a local shop that has extensive experience with the power commander and is one of few shops I've found that actually makes ignition timing adjustments! I think there is a decent gain to be had, just by running premium and adjusting timing. Last on the list and probably most difficult is to fab a custom air box that will allow an open type air filter element (like a K&N pod filter/s), but not the tiny ones now available. The goal is to build something that will have at least the same surface area of the stock filter element. If you compare the Thruxton air box vs the T120 Air box, there are obvious differences in inlet size, so the T120 would probably benefit from something a bit more free flowing, especially with a TEC camshaft.
