Booster Plug on a Thruxton R? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 08-15-2019, 07:41 PM Thread Starter
Anyone using one? Thoughts? Dyno results?
https://www.ebay.com/itm/Booster-Plu...YAAOSwZtlaMEcT
thanks,
Armen is offline
post #2 of 8 (permalink) Old 08-15-2019, 08:56 PM
Dougl1000's Avatar
thanks,
6% increase in fuel. No extra power but smoothed out low end throttle a bit.
Dougl1000 is offline
post #3 of 8 (permalink) Old 08-15-2019, 10:35 PM
Main Motorcycle: Speed Twin
Other Motorcycle: Ducati Multistrada
Extra Motorcycle: KTM 300 & 500
put on on my 19 speed twin and it smooths things out
dont expect 5 HP or anything
its a cheap date so do it--you will like it
plug and play and remove and sell it if you dont like it
its 150- - thats cheap for any bike mod :-)
markg333 is offline
post #4 of 8 (permalink) Old 08-17-2019, 10:59 PM
Main Motorcycle: 2016 Tri Thruxton Std
Other Motorcycle: I WISH it were a Bultaco
Ditto here.
I added a booster plug about a month ago and so far most of the snatch is gone at low rpm. Not entirely, but a vast improvement over stock. This is a relative thing. The jerky throttle roll on was so bad, I took the bike off the road and didn't ride it until the plug was installed. I don't modify as a rule, but this time it was worth the money and effort.
Additionally, if you get into it - the AI sensor attachment M/F plug on my bike (2016 Thrux Std) is way under the tank, and the tank must be raised about 5 inches to even see it. I used the longest available offset needle nose pliers to get at the attachment point.
NOTE: The instructions from the manufacturer showing an attachment point just under the side cover are WRONG, at least for my model Thrux.
Weedie
"Some folks are educated beyond their intelligence." Mark Twain - An American Original.
weedie is offline
post #5 of 8 (permalink) Old 08-18-2019, 10:30 AM Thread Starter
Thanks!
Thanks for the responses. I'm assuming when you said '6% increase in fuel', you mean increase consumption, not mileage.
Armen is offline
post #6 of 8 (permalink) Old 08-18-2019, 10:51 AM
Main Motorcycle: 2017 Triumph T120
Pudge's Avatar
Since I installed the BP on my T120 I haven't noticed any significant change in fuel economy. According to my bike's LCD display it was 51.2 mpg before and 51.3 after install. This was from around town riding and I waited about a month to check the "after" reading.
Clearview windshield, Triumph Cruise Control Kit DRL Type 2, Pazzo levers, JW Speaker Evo 2 LED headlamp, Booster Plug, Triumph LED indicators, 4 bar tank badges, chrome throttle body, clutch and inspection covers.
Pudge is online now
post #7 of 8 (permalink) Old 08-18-2019, 12:18 PM Thread Starter
Thanks!
I'm not obsessed with mileage, but I hate to have a shorter range on a tank.
Armen is offline
post #8 of 8 (permalink) Old 08-25-2019, 01:27 AM
Main Motorcycle: 2017 T100
LA-Liquid-T100's Avatar
Other Motorcycle: 1977 CB750F2
Iíve been running a booster plug on my T100 since January. I read what everyone is stating that it runs 6% richer. I wiped out my tail pipes at install and noted the mileage. With 12.4k it didnít have much black soot. At 18.25k I checked the tail pipes again. Had a lot more soot on the paper towels. Itís not a very scientific study but Iím satisfied that itís running richer. The payoff is smoother throttle. Worth it. Gas mileage was reduced a bit but not significantly.
2017 T100- OHLINS TR 634/FKS 215, LSL Flat Tracker handlebars, Booster Plug, STS (Smart Turn System)auto turn signal cancelation, Modified comfort seat with Supracor, Chrome Grab Rail, Triumph Barrel Style Hand Grips, Aluminum Oil Filler Cap, Cibie 82240 Light unit, Triumph Center Stand
LA-Liquid-T100 is offline
