Tools for Speed Twin And More - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 3 (permalink) Old 08-15-2019, 12:41 AM Thread Starter
I want to start working on my Speed Twin. No mechanical experience and not sure where to start with which tools to buy. Preferable I want to get sets which I can use in other domains (my car possibly stuff around the house) so future investment. Hoping to get a few questions answered:
Are SAE*tool sizes interchangeable with metric tools? In other words, will I have to buy both sets of tools? Am I safe with all metric tools these days?
primary goals:decat, oil change, camshaft (in the next year or two).
These sets I’ve compiled (searching this forum) cover all the sizes I need? Are the sets missing anything? I have 0 tools right now except a good quality Torque wrench (random, yes)
Socket and Rachet set
https://www.amazon.ca/TEKTON-4-Inch-...95129407&psc=1
These are the sizes available
45-pc 1/4-3/8-inch Drive
47-pc 3/8-inch Drive
55-pc. 1/4 inch Drive
58-pc 1/2-inch Drive
84-pc 1/2-inch Drive
Which drive size should I get. Should I get the biggest size then use an adapter? Is it useless to go with the 84-pc 1/2-inch Drive or is the 45 pc enough for the triumph.
I also found this for extra bits
TEKTON 2840 Everybit Ratchet Screwdriver and Bit Set, 105-Piece
https://www.amazon.ca/TEKTON-2840-Ev...3&s=hi&sr=1-17
Wrench Set
This one has a swing arm. Is this a gimmick that will break or something standard/useful?
https://www.amazon.ca/TEKTON-WRN5707...29&sr=1-6&th=1
includes:
(1) 1/4, (1) 5/16, (1) 3/8, (1) 7/16, (1) 1/2, (1) 9/16, (1) 5/8, (1) 11/16, (1) 3/4, (1) 13/16, (1) 7/8, (1) 15/16, (1) 1 inch, (1) Roll-up storage pouch
Allen Keys Sets
These are allen keys. Should I consider getting the allen bits too? Or are the keys usually fine.
https://www.amazon.ca/TEKTON-Wrench-...s%2C306&sr=1-5
Oil Filter Wrench
https://www.amazon.ca/uxcell-Filter-...%2C138&sr=8-12
uxcellŽ 65mm Dia Oil Filter Socket Wrench 14 Flutes. I found this size for another Triumph on the forum. Are they all the same?
Dealer Tools
Any tools I will need from the dealer?
Adapters
Any adapters required with above tools?
Torque Wrench
Purchased
Paddock stand
Comes with the 8mm spools (used on Speed Twin)
https://www.amazon.ca/dp/B00AWE0DS8/...dDbGljaz10cnVl
Notes
You see a lot of Tekton above. Did some research and it appears good value i.e low price decent quality for hand tools from what I’ve read.
Missing anything?
ericthered is online now
post #2 of 3 (permalink) Old 08-15-2019, 01:05 AM
Main Motorcycle: 2016 Street Twin
If you’re just starting out why don’t you get something like this... https://www.amazon.ca/dp/B074MH432L/..._aFovDbTT5TGH3
And then just add tools as and when you need them
shadydaverave is offline
post #3 of 3 (permalink) Old 08-20-2019, 01:28 PM
Main Motorcycle: 2017 T100
grant.edwards's Avatar
Everything on WC Triumphs is metric. If you're just working on your Speed Twin, you won't need SAE stuff.
Start with a 3/8 drive socket set. Make sure you get a couple different lengths of extensions. You'll almost never need extra-deep sockets, so don't bother with them to start. I would definitely recommend a set of metric hex/allen sockets, but a set of metric hex/allen key/wrenches is also really handy to have.
You'll want a thin-wall 14mm spark plug socket. Get one with the foam insert that hangs onto the spark plug. For oil filters I use a 64mm 14-flute, but 65mm will probably work too.
Next, a set of metric combination wrenches. The gearwrench style "ratcheting" ones seem like a cool idea, but in the situations where a socket won't work there never seems to be enough clearance to use gearwrench ones. So, just get normal combination wrenches.
After that, I'd probably recommend a 1/4" drive socket set.
Grant
grant.edwards is offline
