Ď19 ST Flasher Relay - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 10 (permalink) Old 08-07-2019, 09:11 AM Thread Starter
Main Motorcycle: 2019 Street Twin
Seadog49's Avatar
Other Motorcycle: 1964 Honda CB77 Superhawk
Extra Motorcycle: 1966 Honda CB77 Superhawk
Can anyone tell me where the turn signal flasher relay is located on the 2019 Street Twin? It makes no noise when working and I canít seem to locate it under either side cover. Thanks.
Seadog49 is offline
post #2 of 10 (permalink) Old 08-07-2019, 09:15 AM
Main Motorcycle: Street Twin
Other Motorcycle: T595
Extra Motorcycle: CB900F
It's a fully electronic unit that's built into either the ECU or the instrument cluster and not a separate part.
Sent from my Moto G (4) using Tapatalk
Tripletotwin is offline
post #3 of 10 (permalink) Old 08-07-2019, 09:26 AM
Main Motorcycle: Street scrambler
Davey gravey's Avatar
Extra Motorcycle: Sr400
Bugger. I was hoping that might be a fix for the fast flash I now have with new led. I've done the type 2 3 4 thing, no luck.
Sent from my TA-1033 using Tapatalk
Davey gravey is offline
post #4 of 10 (permalink) Old 08-07-2019, 09:29 AM
Main Motorcycle: 2019 Speed Twin
Kinjane's Avatar
Flash rate is adjustable through its four different settings via the info button.
From memory you hold the info button down prior to turning on the ignition with the red run button in the run position and watch the dash for the settings to appear then release the button and then use it to cycle through the different speed settings.
Whenever I see a bike advertised with 'a shed load of extras' I often wonder how well it handled with a deckchair, lawnmower, some hose and a rake strapped to it.
Kinjane is offline
post #5 of 10 (permalink) Old 08-07-2019, 09:36 AM
Like I said, I tried it. Don't work
post #6 of 10 (permalink) Old 08-08-2019, 03:21 AM
Main Motorcycle: 2016 Street Twin
If it’s not triumph led indicators your using and none of the 4 modes work for you, try buying led indicator resistors and hard wire them in between the indicators and the wiring harness.. then try the different modes to get one that works
shadydaverave is online now
post #7 of 10 (permalink) Old 08-08-2019, 06:08 AM
Nah. To much work for no real reward. I'm done with that headlight bucket for a while, don't enjoy getting in there. But thanks for the input
post #8 of 10 (permalink) Old 08-08-2019, 01:44 PM Thread Starter
Seadog49's Avatar
Thanks for the info, Tripletotwin. I had hoped to install a Kisan signal minder, but that's not going to work.
Seadog49 is offline
post #9 of 10 (permalink) Old 08-16-2019, 02:25 PM
Newbie
I am planning on purchasing Motogadget LED indicators for my 2018 street twin. Since the relay is a fully electronic unit, will I need to install resistors?
I am assuming that it is a fully electronic unit like the 2019 Street twin
Sent from my iPhone using Tapatalk
jsa9791 is offline
post #10 of 10 (permalink) Old 08-17-2019, 05:01 AM
Main Motorcycle: 2016 Thruxton S
Ashman's Avatar
Other Motorcycle: 850 Norton Featherbed
Extra Motorcycle: 1960 650 Manxman
Send a message via Yahoo to Ashman
Maybe Davey you didn't have your tongue out right when doing it
Ashman is online now
