Help- Fuel Leak - Triumph Forum: Triumph Rat Motorcycle Forums
 7Likes
  • 1 Post By Ashman
  • 2 Post By jb44
  • 4 Post By Mystic
post #1 of 7 (permalink) Old 07-19-2019, 03:58 PM Thread Starter
Main Motorcycle: T120 Black MY2018
Mystic's Avatar
Help- Fuel Leak
Hi All,
I removed the fuel tank the other day to hard-wire a GPS and after removing all the electrical connections and hose underneath the tank, I ended up disconnecting the banjo bolt to take the fuel tank completely off the frame. Re-fit everything back once the wiring was done and didn't take the bike out since then.
This morning, when I went out for a ride, I smelled strong petrol/gas which at one point became unbearable. Checked the sides of the bike for any leak but there was none.
Reached home, unbolted the tank and saw petrol drops on the banjo bolt. Tightened it a bit but the leak kind of increased. Tool off everything and fit the bolt again, this time with both the washers in the bolt (like in the exploded view below) and the tank became a fuel fountain. Gave up and wrapped up for the day.
Anyone know what I am doing wrong or any idea how to fit the banjo bolt correctly? There is no instruction in the service manual and nothing on the internet which can help shed some light.
See pics attached/below: Banjo nut and exploded view
ID:	649564   Click image for larger version
Mystic is offline
post #2 of 7 (permalink) Old 07-19-2019, 06:50 PM
Main Motorcycle: 2016 Thruxton S
Ashman's Avatar
Other Motorcycle: 850 Norton Featherbed
Extra Motorcycle: 1960 650 Manxman
Send a message via Yahoo to Ashman
Not sure why you took that bolt out to remove the tank as the fuel hose has a quick release fitting for tank removeal, what has happen is you will now have to replace the washers on that bolt to seal it as the washers are soft, most of the time can be reused but in your case not so, you might be able to seal it with some fuel sealent.
Ashley
jb44 likes this.
Ashman is online now
post #3 of 7 (permalink) Old 07-20-2019, 06:42 AM Thread Starter
Mystic's Avatar
Thanks Ashman. There is no quick release clip underneath the tank in the newer models and the clip on the other end of the hose was impossible to take out despite all my will.
I’l try with new washers and see what happens. It’s just a bugger!
Mystic is offline
post #4 of 7 (permalink) Old 07-20-2019, 08:11 AM
Main Motorcycle: 2018 Street Twin
Other Motorcycle: 2016 Honda CB500F
Extra Motorcycle: 2014 Yamaha XT 250
Originally Posted by Mystic View Post
..... There is no quick release clip underneath the tank in the newer models and the clip on the other end of the hose was impossible to take out despite all my will......
Yes there is a quick disconnect:
The specialized tool for disconnecting makes the job easier.
In the meantime, try Ashman's suggestion of using new crush washers and torquing down the banjo bolt.
jb
Ashman and Simon64ds like this.
jb44 is offline
post #5 of 7 (permalink) Old 07-20-2019, 10:19 AM
Main Motorcycle: TBS,Daytona 900
Other Motorcycle: Speed Twin
Canít it be done without the tool?
Burren Boyo. is offline
post #6 of 7 (permalink) Old 07-20-2019, 11:38 AM
Dougl1000's Avatar
Originally Posted by Burren Boyo. View Post
Can’t it be done without the tool?
Yes. You just have to push the tabs in. It’s a bitch to get off and more of a bitch to snap it back on. But it does go on. WD-40 helps.
Dougl1000 is online now
post #7 of 7 (permalink) Old 07-20-2019, 12:34 PM Thread Starter
Mystic's Avatar
Thanks everyone for the valuable feedback. Whilst waiting for the replacement washers, I filed the current ones to level the surface, fit them back on whilst tapping on the bolt head very mildly with a rubber mallet in order to seal the washers properly.
It worked! And no more leaks. Phew.
And I have ordered a pair of that wretched clip pliers too to avoid any further tinkering with the banjos.
Sent from my iPhone using Tapatalk
andrewb, Ashman, Tricolour and 1 others like this.
Mystic is offline
