Coolant - Triumph Forum: Triumph Rat Motorcycle Forums
 10Likes
  • 1 Post By PGR
  • 1 Post By steveboilard
  • 2 Post By tsmgguy
  • 3 Post By StreetTwin
  • 1 Post By tsmgguy
  • 2 Post By steve11201
post #1 of 9 (permalink) Old 07-16-2019, 11:29 AM Thread Starter
Main Motorcycle: Street Twin
steve11201's Avatar
Coolant
I've read a few threads on this and I'm still confused. Can I just use any OAT coolant that is free if silicates for my 2016 Street Twin? Like this one from Revzilla? Also, I can't find in the owners manual, Tritun Manual or Hayes Manual how much I actually need when draining and refilling. Thanks - didn't do too well in chemistry in high school.
steve11201 is online now
post #2 of 9 (permalink) Old 07-17-2019, 08:30 AM
PGR
Main Motorcycle: 2018 Bonneville T120
PGR's Avatar
The Haynes manual says the coolant capacity for the T100, Street Twin, Street Cup, & Scrambler is 1.52 liters.
And why wouldn't you just use the Triumph HD4X Hybrid OAT 50:50 premix coolant? I only paid $10.95 per liter at my local Triumph dealership.
Pete
steve11201 likes this.
Veni Vidi Velcro (I came, I saw, I stuck around)
PGR is offline
post #3 of 9 (permalink) Old 07-17-2019, 11:49 AM Thread Starter
steve11201's Avatar
Pete
Amazingly, the local Triumph dealer doesn't have a parts department. But I can go to the next closest one an hour away if necessary.
Thanks!
post #4 of 9 (permalink) Old 07-17-2019, 12:56 PM
Main Motorcycle: 2018 Speedmaster
Extra Motorcycle: 2014 Honda Shadow
I used Zerex G05. It's Hybrid OAT, and readily available at your local auto parts store.
steveboilard is offline
post #5 of 9 (permalink) Old 07-17-2019, 04:18 PM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Or a 50-50 mix of Prestone and distilled water, like grand dad used. Fill the radiator, cap, and bring the coolant tank up to the line, worrying not about capacity. Ride and check the level again in the overflow tank. Done.
Back2-2 and steve11201 like this.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is online now
post #6 of 9 (permalink) Old 07-18-2019, 07:31 AM
Main Motorcycle: 2016 Street Twin
StreetTwin's Avatar
That is exactly what I did a week ago. Drain rad and expansion tank, flush with tap water, fill with 50-50 Prestone and I was done. I was reluctant to post in fear of being accused of blasphemy for not using Triumph's outrageously priced product.
Before the lectures start, please note that this has been my protocol for the past 25 years with my ZX - 6 and SV 1000 without any ill effects.
The price of the Triumph product is four times that of the Prestone. It is guaranteed to be compatible with all manufacturers' engines and wont void your warranty.
It's your money and it's your bike. Don't believe the hype.
tsmgguy, Back2-2 and steve11201 like this.
StreetTwin is offline
post #7 of 9 (permalink) Old 07-18-2019, 09:52 AM
tsmgguy's Avatar
Assuming a 50/50 coolant change every three years, a single gallon of Prestone is about nine years worth, twelve if you count the three years you should get on the original factory fill. Waterless, permanent coolants are less efficient, and I seriously doubt that any liquid should be left in a bike for its entire service lifetime.
Flushing and changing the engine coolant in my T120 was no more difficult than changing the engine oil.
post #8 of 9 (permalink) Old 07-19-2019, 09:39 AM Thread Starter
steve11201's Avatar
Thanks everyone. I emailed Prestone and asked this: "Triumph specifies their brand of Hybrid OAT antifreeze for my 2016 Street Twin. Is Prestone 50/50 compatible with this engine, and with the various seals that it comes into contact with?" and the answer from this was: "Yes, it is. Please let me know if you require anything further. Sincerely, Aaron Jones, Prestone Consumer Relations Representative. Phone: 203-731-8191
The description of Zerex G-05 also looks fine. So it will be one or the other depending on what's in stock at the local auto place.
Back2-2 and StreetTwin like this.
post #9 of 9 (permalink) Old 07-22-2019, 11:37 PM
Main Motorcycle: T120
Kirkemon's Avatar
Other Motorcycle: Ducati Superlight, RD400F
When my level is low, I top off with Water Wetter:
https://www.redlineoil.com/waterwetter
Kirkemon is offline
