thruxon/t120 shifting - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
post #1 of 26 (permalink) Old 07-12-2019, 04:17 PM Thread Starter
Main Motorcycle: 2016 Thruxton R
thruxton/t120 shifting
I have a 2016 Thruxton R, and the first 3 upshifts (1-2, 2-3, 3-4) are somewhat clunky. 4-5 and 5-6 are silky smooth. Anyone else experience this and is there any remedies (ie. different oil, I'm using Motorex which is supposed to help shift quality but I see no difference). Doesn't seem to make much difference preloading the shifter either.
speedm is offline
post #2 of 26 (permalink) Old 07-12-2019, 08:23 PM
Ranjith Punani's Avatar
Check your clutch, it might not be fully disengaging. The ratios in the "smooth" gears are a lot closer than the ones in the lower gears.
Ranjith Punani is offline
post #3 of 26 (permalink) Old 07-13-2019, 12:17 AM Thread Starter
thanks, i'll give that a shot. just wondering if it's 'normal' for it to clunk in those gears. i see/hear it in videos of the bike as well (jump to 0:35):
speedm is offline
post #4 of 26 (permalink) Old 07-13-2019, 05:56 PM
Main Motorcycle: 2016 THRUXTON S/GREEN
Other Motorcycle: FZ 09
Extra Motorcycle: 2016 FZ07
Nope mine is flawless, as said, check linkage and clutch disengaging.
vitesse is offline
post #5 of 26 (permalink) Old 07-13-2019, 08:17 PM
Main Motorcycle: 2014 Street Triple R
stgatev's Avatar
My shifts are like that: 1-2-3-4 are clunky, 4-5-6 are smooth, but only when doing clutchless upshifts. When using the light and easy to modulate clutch, all shifts are as smooth as I want them to be. As Ranjith noted, the 4-5-6 are much closely spaced thus no big drop in RPMs.
stgatev is offline
post #6 of 26 (permalink) Old 07-14-2019, 07:26 AM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
So are mine and this was after first service?
Tricolour is online now
post #7 of 26 (permalink) Old 07-14-2019, 07:39 AM
Main Motorcycle: 2016 Thruxton 1200
CanberraR3's Avatar
Other Motorcycle: 2018 Street Scrambler
Extra Motorcycle: 2016 Tiger 800 XCX
If you are timing your throttle and clutch correctly and you clutch is properly adjusted all the changes should be smooth as butter. Mine are on my Thruxton, although my Street Scrambler shifts ever smoother. I don’t understand why you wouldn’t just use the recommended Castrol and focus on getting the changes right.
CanberraR3 is online now
post #8 of 26 (permalink) Old 07-14-2019, 08:38 AM
Tricolour's Avatar
You are lucky that you do not have the same problem.
I have made my clutch adjustments and they are correct.
I have changed my oil since the service and it has made no difference.
In my opinion there is an issue with my selector and this is is not an isolated incident.
My gear changes were like yours until the dealer did my first service then I had this issue.
It is a problem with the selector mechanics.
Your suggestions are basic, simplistic and condescending.
Have a look at some previous posts on the gear change linkage weakness.
If my gear changes had not been smooth before the service I would not have noticed such a big difference.
post #9 of 26 (permalink) Old 07-14-2019, 09:03 AM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Lower gears, slightly clunky. Higher gears, higher RPM and higher speed, buttery smooth. It's been a characteristic of the beast for over three years now. No concerns here.
speedm likes this.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #10 of 26 (permalink) Old 07-14-2019, 09:42 AM
CanberraR3's Avatar
Apologies. I wasn’t directing my remarks at your situation.
