x pipe meerkat vs cone engineering - Page 11 - Triumph Forum: Triumph Rat Motorcycle Forums
 127Likes
post #101 of 117 (permalink) Old 09-06-2019, 12:33 AM
Main Motorcycle: 2018 Bonneville T120
Jet City's Avatar
Other Motorcycle: 2019 Speed Twin
Extra Motorcycle: 2005 Aprilia Tuono Racing
Meerkat installed successfully. Took about three hours because I was being VERY careful not to screw up my brand new bike!
Thanks Peter!
Ashman, tahtye and kdxandrew like this.
I hear running is good for you, but the ice cubes keep falling out of my glass.
Jet City is offline
post #102 of 117 (permalink) Old 09-06-2019, 09:42 AM
Other Motorcycle: 2001 Bonneville T100
Originally Posted by MotoChooch View Post
It was a bit of a bitch getting to about 2 nuts (engine to frame and top frame bolt), the exhaust fittings to the engine were a bit finicky because of the joining pipe between the two exhaust pipes, and the clamps on the cat itself. Ratcheting box wrenches are KEY here! The rest was easy, but trying to film things it took longer than it should have. Just glad it's DONE! She sounds soooooo good! Definitely feel the rev up being smoothed out. Low speed is smoothed out a bit. Shifting now feels like it holds the RPM a little longer, which results in me having to delay releasing the clutch slightly to get a smooth upshift when just cruising around.
All in all, really like the piece and fitment was perfect. Happy to have removed the cat!
In your pic it looks like you put the heat shield back on?? I did not....
1970 Moto Guzzi 750
tdshepard is offline
post #103 of 117 (permalink) Old 09-06-2019, 02:07 PM
Main Motorcycle: 2020 Triumph Speed Twin
MotoChooch's Avatar
Other Motorcycle: 2016 Tiger 800 XRt
I did not put the heat shield back on.
2016 Triumph Tiger 800 XRt; 2020 Triumph Speed Twin
Previously: 2009 Kawasaki Vulcan 900 Custom, 2016 Triumph Street Triple R, 2019 Triumph Speed Triple RS
MotoChooch is offline
post #104 of 117 (permalink) Old 09-06-2019, 03:54 PM
Jet City's Avatar
Here's a pic. Brushed stainless Meerkat and 2019 Speed Twin. Twin is black and shiny. Like my soul.
Name:	Meerkat Speed Twin.jpg
Jet City is offline
post #105 of 117 (permalink) Old 09-06-2019, 10:25 PM
I don't want to bust your chops and I don't want to come off as an A**hole but it just looks like to me you left the upper heat shield on your bike. On my 2017 it was not necessary with a Mercat install. Perhaps your bike is different. Of course it is no big deal, just saves a few ounces.....
https://i476.photobucket.com/albums/...d/SAM_0236.jpg
1970 Moto Guzzi 750
post #106 of 117 (permalink) Old 09-07-2019, 12:43 PM
MotoChooch's Avatar
Ahhhh ok now I see it. Didn't think to take it off and don't really think I should? Keeps the heat off whatever is behind it no?
Sent from my SM-G965U using Tapatalk
post #107 of 117 (permalink) Old 09-08-2019, 03:00 PM Thread Starter
Main Motorcycle: 2019 Street Twin
[QUOTE=MotoChooch;2003996568]Ahhhh ok now I see it. Didn't think to take it off and don't really think I should? Keeps the heat off whatever is behind it no?
The heat is generated by the cat, once it is removed there is a huge reduction in heat generated and the heat shield is not needed. You can keep it on or take it off.
@meerkat likes this.
chim chim is offline
post #108 of 117 (permalink) Old 09-09-2019, 09:59 AM
MotoChooch's Avatar
[quote=chim chim;2003997034]
If I can get it off without taking anything else apart I will. I don't like that empty bracket hanging there.
post #109 of 117 (permalink) Old 09-13-2019, 09:43 PM
Main Motorcycle: 2019 Triumph Speed Twin
coldeskimo's Avatar
Other Motorcycle: 2014 Yamaha SR400
Oh the sound is so sweet. Meerkat installed !! Yes there is a little hp increase in the mid range as quoted and you won't be disappointed. I'm only sad I waited 3 months to get around to doing this! No heat shield required. Onwards and Upwards
Speedblue2, Jet City and kdxandrew like this.
coldeskimo is offline
post #110 of 117 (permalink) Old 09-14-2019, 08:39 PM
Main Motorcycle: 05 Speedmaster,daily ride
Speedblue2's Avatar
Other Motorcycle: 1975 MotoGuzzi,project
Extra Motorcycle: Wish I had a Speedtriple.
So after the cat removal and the Meercat install bike runs much better? Does it need a fueler added on or does the fuel injection adjust enough that it does not need a fuel controller added on. Just recently traded in my old Victory for a Speed Twin 2019. What difference. Triumph is like 300-lbs lighter! Enjoying the new ride.
Speedblue2 is offline
