Rear wheel lift - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 06-15-2019, 01:28 PM Thread Starter
Main Motorcycle: Triumph Street Twin
Barnstormer's Avatar
Other Motorcycle: 2002 Honda cb500s
Extra Motorcycle: 1974 Honda CB350 K4
Rear wheel lift
What's the best way of raising the rear wheel off the ground on the ST? I have no centre stand fitted, so is it a paddock type of stand, or a jack?
Anyone tried to use the centre stand mounting holes somehow?
Steve
Enjoy the ride, but relish the safe return home more.
Barnstormer is offline
post #2 of 12 (permalink) Old 06-15-2019, 02:26 PM
Main Motorcycle: ThruxtonR,
pmorritt's Avatar
Other Motorcycle: BMWR1100RT
street Twin I’m guessing. Just get some bobbins, threaded holes already there and a decent paddock stand. Pit Bull is an excellent one. They make one with the traditional rear handle and one with a side handle if you have limited space. The one with the side handle is better if you’re a little nervous lifting the bike from the rear.
Masquerading every day as a normal person is exhausting.
pmorritt is offline
post #3 of 12 (permalink) Old 06-15-2019, 02:41 PM Thread Starter
Yeah sorry, street twin 2019, couldn't se any threaded holes, will have a closer look though.
post #4 of 12 (permalink) Old 06-15-2019, 03:32 PM
Main Motorcycle: Street Twin
steve11201's Avatar
These take 4 seconds to install. https://www.tecbikepartsusa.com/TEC_.../t-stw-bob.htm
It simply inserts through the rear axle.
steve11201 is online now
post #5 of 12 (permalink) Old 06-15-2019, 04:29 PM
Main Motorcycle: 2016 Thruxton S
Ashman's Avatar
Other Motorcycle: 850 Norton Featherbed
Extra Motorcycle: 1960 650 Manxman
Send a message via Yahoo to Ashman
I have a motorcycle sissor jack that works great and is also good to use when the bike is on the lift work table fo under $100 no need for bobbins and has adjustable arm to sit on the frame and also a flat top works on all my bikes.
Ashley
Ashman is online now
post #6 of 12 (permalink) Old 06-15-2019, 05:27 PM Thread Starter
Yeah, they look good for raising the wheel.
Might need something else though when I need to remove it
Thank's
post #7 of 12 (permalink) Old 06-15-2019, 05:28 PM Thread Starter
Ashley
Is it fairly stable?
post #8 of 12 (permalink) Old 06-15-2019, 05:42 PM
Main Motorcycle: 2016 Street Twin
StreetTwin's Avatar
Solid as a rock. Place it under the tabs for the optional centre stand.
When lifting the front wheel, place it under the cat - just remove the heat shield.
StreetTwin is online now
post #9 of 12 (permalink) Old 06-16-2019, 07:15 AM
steve11201's Avatar
Thank's
Yes, you will. Also for chain tensioning. I use a harbor freight scissors jack for that (and oil changes, etc.). But for chain maintenance these are faster and simpler than jacking up the bike. If it’s a choice of one or the other I’d get the scissors jack.
post #10 of 12 (permalink) Old 06-16-2019, 07:56 AM
Ashman's Avatar
Its a motorcycle sissor jack and is completely stable, that and my lift table are 2 of the best things I brought for my workshop, and the good thing about the sissor jack it slids under the bike and don't get in the way when working on the bike.
