start then click - Triumph Forum: Triumph Rat Motorcycle Forums
 11Likes
post #1 of 23 (permalink) Old 04-17-2019, 06:42 AM Thread Starter
Newbie
Main Motorcycle: 2018 Bonneville
Other Motorcycle: 2014 Bonneville
start then click
Morning. New to the site. New to Triumph for last 6 months. Bought a 2014 Bonnie and fell in love then bought a new 2018 Bonnie and am bedding her in. Last night I stopped for a drink, went to leave and the bike just dead. turned key to proper start position. Moved start switch and engaged the start and click.
Pulled the seat and verified battery terminals tight. I work on Laboratory Equipment so am familiar with wiring harness and molex type plug connectors. Check everything around the ECM as it was moved to put the battery in the bike but all looks well. I start wondering about the engine immobilizer and keys etc etc.
Here are a few observation;
When key was removed, on the odometer trip computer LED screen I could still see the gear icon and the fact it was in Neutral and mileage being displayed very faintly. Yes, the key was removed
I had to wait for a good 5 minutes before the key in the ignition would activate the start switch
One occurrence of an audible arcing sound around the starter
Every time I tried to start the bike with the switch it would go dead, completely dead with the above anomaly of LED screen occurring.
Finally I waited till I had good juice flowing from the ignition and I simply asked someone to push start me so I could get the bike home. When I got it home the first thing I did was stop and restart several times with no issues. this morning 10 hours later same, no issues. huh. okay. I really get concerned about electrical issues that come and go.
anyone else out there experiencing anything like this? Will be taking the bike back to the dealer today so they can run diagnostics I assume. I love this bike but am a little bummed.
Collings
Collings is offline
post #2 of 23 (permalink) Old 04-17-2019, 09:46 AM
geb
Main Motorcycle: 2009 H-D Dyna Glide
Other Motorcycle: 2016 Triumph T120
Extra Motorcycle: 1998 H-D 1200XLH
Sorry that I have no diagnosis for your problems.
But can not resist the opportunity to encourage M/C designers and manufacturers to to STOP burdening their products with excessive electronic systems of dubious value. By their very nature, M/C's are a difficult operational environment to deal with.
Unfortunately, Collings experience can be the result.
vitesse likes this.
geb is offline
post #3 of 23 (permalink) Old 04-17-2019, 02:02 PM
Main Motorcycle: Triumph Street Scrambler
Other Motorcycle: 1995 Triumph Trident
Extra Motorcycle: 1966 DMW Deemster
Does the battery need a good charge?
philmore is online now
post #4 of 23 (permalink) Old 04-17-2019, 04:53 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Most likely the battery. There's a minimum voltage threshold for starting. Many threads on here.
As for the comment above about complexity, thank nanny. Not Triumph's idea.
vitesse likes this.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #5 of 23 (permalink) Old 04-17-2019, 09:29 PM
geb
You're likely partially correct. Our ever present nanny state style of government insisting on ever safer vehicles. However I question if there was a government mandate for heated grips, traction control, and ride modes.
vitesse likes this.
geb is offline
post #6 of 23 (permalink) Old 04-17-2019, 11:09 PM
lambroving's Avatar
Heated grips isn't rocket science. All my BMW's from 1985 on had them standard. Nice...
The bikes have to have ABS in Europe and the TC and modes come along with the ABS from the vendor.
vitesse likes this.
post #7 of 23 (permalink) Old 04-18-2019, 12:28 AM
Main Motorcycle: 2018 Tiger 800 XRx Low
Other Motorcycle: 2013 Street Triple R
Extra Motorcycle: 2019 Z900RS Café
Or even better, test the bikes, use premium components to justify the going mad prices of the new bikes, and don’t use new buyers as guinea pigs? Plenty of bikes loaded with electronics working just fine...
vitesse likes this.
Evangelos K is offline
post #8 of 23 (permalink) Old 04-18-2019, 06:13 AM Thread Starter
Newbie
Red face
thanks all. 24hrs later update: all is well with the bike. Strange experience but I cannot reproduce it (thankfully).
I was using the kill switch to power down the bike which I will no longer do as the manual advises using the key to kill the bike and I have read on this forum that it can scramble the ECU. Lesson learned. I wonder if this was cause......
I am almost at 500miles and the machine is bedding in nicely. Gearing is very smooth now and hitting 5K on the Tach regularly; wow. Been a while since I had that much power between my legs. ;O)
battery is at nominal voltage 12.98Vdc and my Fluke was just calibrated.
I bought a Triumph because of their history. I love this machine. Peace.
vitesse likes this.
Collings is offline
post #9 of 23 (permalink) Old 04-18-2019, 09:44 AM
geb
Collings, Good to hear that you have things straightened out.
But,....the kill switch might scramble the ECU ???....And I thought kill switches weren't rocket science !!!
The more the fancy electronics the more opportunity for problems, just read the forums, lads...
GEB
geb is offline
post #10 of 23 (permalink) Old 04-18-2019, 10:27 AM
Main Motorcycle: 2018 T120 Bonneville
aj7840's Avatar
Other Motorcycle: 00 Ducati Monster 900
GEB
Amazing that the kill switch will do that, but most of the "code" writers came from the manufacturing side of things where a kill switch is an emergency stop. You have to reset the system after an e-stop, to insure what ever required the e-stop is fixed. Most plant operations required the electricians to do that rather than the operator. A lot of operators figured out it was a good way to get extra break time.
Not so good if it is a conveyor in a bakery oven, eventually those cookies catch fire if they set to long in the heat.
It is what it is, until it isn't
aj7840 is offline
The dreaded "click" when trying to start Forchetto Air Cooled Twins Technical Talk 22 05-13-2019 01:57 PM
09 Bonneville won't start click once help rainegaming Air Cooled Twins Technical Talk 3 11-03-2016 10:26 PM
Click. . ., click. . ., click. . . ? scrimbo57 Cruisers - America, Speedmaster 4 10-24-2016 09:32 PM
Electrical ***/Intermitent No Start CDickey Speed Triple Forum 4 05-05-2010 09:09 PM
cold start fix? depewm Air Cooled Twins Technical Talk 1 02-28-2010 11:13 AM
