Brake Switch of Street Twin not working - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 03-06-2019, 12:58 AM Thread Starter
Hi Friends,
I have a problem with my front brake switch operation. Due to malfunction of this microswitch, my stop light is not working. Has anyone faced this issue? I checked at Triumph service center, they informed me that switch is not a available as standalone part for replacement. I need to change the complete kill switch assembly which costs very high. Can you please suggest where can I get the microswitch for front brake?
kedarrajpathak is offline
post #2 of 12 (permalink) Old 03-06-2019, 12:25 PM
Main Motorcycle: 2018 T120
tahtye's Avatar
Other Motorcycle: 2018 Tiger 800 XRx
https://www.worldoftriumph.com/parts...100074513-1-2/
Part #12 is the rear bs. It looks to me like the front bs is the same SPDT switch as the rear. Put it in your cart to see the Triumph part #. Then ask your dealer to reference it and see what they say..
Good luck!
tahtye is offline
post #3 of 12 (permalink) Old 03-06-2019, 04:53 PM
Main Motorcycle: 2019 Speed Twin
Kinjane's Avatar
T2026285 is the part number for an SPDT switch that fits onto part T2027750 (Bracket, Brake Switch, Front) used on both the Street Twin, Street Cup, Street Scrambler and the Street Triple S (from VIN 803572). Could be the part you're looking for.
Whenever I see a bike advertised with 'a shed load of extras' I often wonder how well it handled with a deckchair, lawnmower, some hose and a rake strapped to it.
Kinjane is offline
post #4 of 12 (permalink) Old 03-06-2019, 05:17 PM
Main Motorcycle: 2016 T120
TrueSavage's Avatar
I've experienced switches stop working for me several times
The last time was a couple of Summers ago on my 1 year old T120. I o[need up the switch housing and found a spider's nest preventing the contacts. I cleaned that out with a dental pick and some contact cleaner. Before that on other bikes it was dirt and dust. I cleaned that out with some contact cleaner. I also had switches stop working because of ice.
It does not matter where you go, how you got there, or how long it took you, someone on a Triumph Bonneville has done it before you. If you didn't do it on a Triumph, it doesn't really matter anyway.
TrueSavage is offline
post #5 of 12 (permalink) Old 03-07-2019, 12:24 AM Thread Starter
Thanks a lot for your quick answers. I will try with Triumph dealer once again with the part numbers quoted above.
post #6 of 12 (permalink) Old 03-18-2019, 09:08 PM
Newbie
Hey Im having the same issue. The micro head got broken. Hit me up if you got a solution
Thanh To is offline
post #7 of 12 (permalink) Old 03-21-2019, 12:06 PM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Any "after market" parts used?
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #8 of 12 (permalink) Old 03-21-2019, 01:30 PM
Main Motorcycle: Street Twin
Other Motorcycle: Honda CB500X
Have you replaced the front brake lever with an aftermarket one? Sometimes, after market levers are shaped slightly different to stock and will not allow the brake light switch to work properly.
Glencoeman is online now
post #9 of 12 (permalink) Old 03-22-2019, 12:24 AM Thread Starter
No. I am using stock levers.
post #10 of 12 (permalink) Old 07-20-2019, 01:35 PM
Main Motorcycle: Triumph Bonneville T120
Other Motorcycle: BMW R1200GS
I had the front brake micro switch come apart on my T120. I tried to find a replacement switch but couldn't. I even tried looking for the part on suppliers to Nissin as I guess it is their part as it attaches to what looks like their front lever casting. Anyway I took the whole cluster and cables in to the dealer and they replaced it under warranty. I know it is like $500 to replace the whole thing. Not cheap. They got the cluster and loom shipped in 24 hours, great service Triumph - especially all the way out here in Utah, 500 miles from anywhere.
Unfortunately the switch turns the brake light off when closed, so if the switch breaks your brake lights stick on. You can't just rely on the rear brake switch to activate the brake light. Well that was my observation anyways.
I was very careful when reassembling everything, it was easier from looking underneath the bars as it is very easy to damage the micro switch with the brake lever when you put it all back together. I think mine initially broke because the original lever was very rough on the surface where it contacted the switch, so over time it ended up breaking off the nub of the switch from sideways stresses.
I replaced the levers with the Triumph accessories ones. At least the left and right levers are now from the same vendor, unlike the originals it seems. They have very nicely machined surfaces where they contact the brake and clutch micro switches, so much better than the originals. OK, $250 I know, but they are a huge improvement in feel and operation.
I looked closely at the stock T120 levers. They look like the brake one is perhaps from Nissin and the clutch one from who knows where. Very different, very odd.
I just used the word break/brake/broke about 100 times...
mecsw500 is offline
Street twin rear brake ABS Gaz907 Water Cooled Twins Technical Talk 11 09-04-2018 03:47 AM
longer brake lines and clutch cable for Street Twin RevKen Water Cooled Twins Talk 14 07-25-2017 08:43 AM
Torque Setting List zucchina Water Cooled Twins Talk 4 05-10-2017 11:09 PM
Alternative front brake light switch Forchetto Air Cooled Twins Technical Talk 22 01-04-2016 06:39 PM
675 Piston Swap Procedure - LONG!! david_m Sprint Forum 111 06-03-2012 01:07 AM
