Repacing inner tubes? - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 15Likes
post #11 of 20 (permalink) Old 02-25-2019, 11:50 AM
Main Motorcycle: KTM Freeride
cougsfan's Avatar
Other Motorcycle: '17 Triumph T120
Extra Motorcycle: '78 BMW R80/7
Originally Posted by PGR View Post
Slight fork in the topic, but:
What brand of tube is considered "best"? Is there any consensus on that besides thick and heavy duty?
Pete
"Which brand is Best" questions on things such as tubes to me are sort of empty questions because there are so many brands, none of us have tried every brand out there, and the differences between many brands is infinitesimal from a practical standpoint, and the sub supplier for one brand may change between one purchase and the next. Any answer will probably be somewhat prejudiced from lack of overall sampling.
Get at least a 3 mm thick tube or preferably a 4 mm thick tube, and you will be fine.
I always coat the tube and inside the tire with talcum (baby) powder before installation. It seems help the tube seat initially and not become glued to the tire over the long haul. After installation I always fill the tube full of air, pull the stem, let the air completely out then re-fill it. This is to help the tube seat with no tension against the tire and may help with the longevity. (These might be wive's tales type of advice, but I was taught to do these things as a young man and I have had overall good luck with tubes.) A bike shop usually won't do those things when they install a tire.
One other "trick" is to inflate the tube and let it set for a day or two before installation, if you have the time available. This helps the tube maintain it's shape during installation and reduces the chances of pinching it. If I can't do that sometimes I install the tube with just a little bit of air in it
cougsfan is offline
post #12 of 20 (permalink) Old 02-25-2019, 02:02 PM
Main Motorcycle: '02 Bonneville 100yr anv.
Back2-2's Avatar
Other Motorcycle: 2006 Honda 450X
That there are some excellent tips and advice!
“Its all about motorbikes. Always has been, always will be”
Neil in AZ
Back2-2 is online now
post #13 of 20 (permalink) Old 02-25-2019, 02:20 PM
Legend
Main Motorcycle: 2008 Bonneville Black
Driftless Admin
BonnieBlack's Avatar
Other Motorcycle: Spousal 2009 Bonnie Black
I install the tire with tube full of air. Just barely full, not bulging or anything. Helps the tire irons glide over it instead of grabbing it for a pinch. Not that I don't sometimes still pinch the tube, but that helps me.
Agree with all your other points!
Back2-2 likes this.
BonnieBlack is offline
post #14 of 20 (permalink) Old 03-04-2019, 07:47 AM
Sharkguy's Avatar
Other Motorcycle: Buell Ulysses
I always buy the "heavy Duty" tubes. I must say I am guilty of not replacing them with new every time. Usually I inspect the tubes when reusing, This time the bike came with a new set of Michelin heavy duty tubes so I had the guy that was changing the tires change the tubes too. Next time I need tires I'm converting to tubeless.
Back2-2 likes this.
Sharkguy is offline
post #15 of 20 (permalink) Old 03-04-2019, 10:20 AM
Newbie
Main Motorcycle: 2013 Bonneville T100
GreatWhiteBuffs's Avatar
I don't have any experience with purchasing new tires along with tubes yet but I would suggest looking into swapping out valve stems for some 90 degree stems before getting the new tires or tubes installed.
2013 Triumph Bonneville T100
GreatWhiteBuffs is offline
post #16 of 20 (permalink) Old 03-04-2019, 05:25 PM
joeschmoe's Avatar
Anytime I have owned a bike with tubes in it, I have always replaced them. To me, it’s cheap insurance.
I reckon as long as you get yourself a good quality tube, you should be fine.
- Joe
joeschmoe is offline
post #17 of 20 (permalink) Old 03-04-2019, 07:13 PM
Main Motorcycle: 08 t100
Other Motorcycle: 08 Thruxton
Extra Motorcycle: 72 Norton comando
I would usually change tubes every other time until a couple years ago when a valve stem shed itself from the tube for no apparent reason. After that I sealed the spokes, installed the NAPA 90-426 tubeless valve stem and replaced the tube with air. So far so good.
rweb is online now
post #18 of 20 (permalink) Old 03-04-2019, 07:29 PM
Main Motorcycle: Bonneville T100 SMQ SE
Tornado99's Avatar
Other Motorcycle: 1974 Norton Commando 850
I agree on changing the tubes at regular tire change intervals (which generally should be happening every 2-3 seasons for motorcycle rubber).
On my '74 Norton Commando, when setting up with first new rubber since restoring bike, I selected "Counter Balance" tubes, which have dynamic balancing beads already inside. These seem to work really well....so much so I'm considering those tubes for my bonneville.
https://fortnine.ca/en/counteract-re...ance-tire-tube
2013 T100 Steve McQueen; +NH Togas; -SAI; -O2; +Breathe; +TTP#3; +Avon RoadRiders; +Iron&Resin Sidebag; +Kisan Auto-Off Indicators & BrakeLight Flasher; +MatchlessClueless LED Brake & Indicators; +LED 3000 Lumens Headlamp; +DeCosse Keyless system
Tornado99 is online now
post #19 of 20 (permalink) Old 03-11-2019, 01:22 AM
Main Motorcycle: 2018 Triumph Speedmaster
Does anyone use the tire sealant called Ride On. I heard it's a good product. Planning a long trip and want as much insurance against a flat as possible.
d100allenbaugh is offline
post #20 of 20 (permalink) Old 03-12-2019, 07:58 AM
Sharkguy's Avatar
Well, guess I jinxed myself. Picked up a blade from a disposable razor knife in the rear tire on Friday as I was headed to a parts swap meet. Had to wait on the side of the road for an hour and a half for the tow truck. I'm going tubeless now. The tube got punctured in two places and there is a nice long scratch next to the punctures.
Sharkguy is offline
Inner tubes, butyl or natural rubber? TR7RVMan Classic, Vintage & Veteran 6 05-30-2018 08:08 AM
1970 tr6r push rod tubes questions Jewelkutter Classic, Vintage & Veteran 72 04-22-2018 07:26 AM
The Solution To MAP Sensor Tubes That Fall Off BigGuy82 Thunderbird Twin - Technical Talk 23 06-15-2013 08:15 AM
NEED tubes! & 'Forks by Franks' FattRat Air Cooled Twins Technical Talk 2 07-27-2006 02:21 PM
NEED tubes! & 'Forks by Frank' FattRat Club Cafe' 3 07-27-2006 12:57 PM
