Street Twin lost downshifting, bent internal shift mechanism DIY walk-through - Page 9 - Triumph Forum: Triumph Rat Motorcycle Forums
 101Likes
post #81 of 104 (permalink) Old 02-15-2019, 01:12 PM
Main Motorcycle: T100 LC
Simon64ds's Avatar
Other Motorcycle: Street Triple R
Originally Posted by cosmetik View Post
lets pretend there could be a reason on why this is designed this way apart from negligence.
OK, let’s pretend that.
Simon64ds is offline
post #82 of 104 (permalink) Old 02-15-2019, 01:25 PM
Main Motorcycle: Thruxton R my19
cosmetik's Avatar
Other Motorcycle: dyna super glide my07
Extra Motorcycle: street cup my18 (dead)
my meaning is to elaborate something on the why its designed this way. You and some others have a lot of experience with engines and cycles. After all this is the "Technical Talk" part of the forum and we could use your experience on more than discussing the size of a metal rod or washers ad nauseam. Stating this, if i would do the protection, i would use a material like nylamid or cold-roll that could disperse the shock in a tip over, but when a stronger force would act (crash) it would be crushed allowing to work as my design-hypothesis post #68
been there, done that.
cosmetik is online now
post #83 of 104 (permalink) Old 02-15-2019, 02:47 PM
Main Motorcycle: 2007 Blk&Red Triumph T100
Other Motorcycle: '86 Red 883 Evo Sportster
Extra Motorcycle: '81 Red GS450E Suzuki
A damaged Hinckley Triumph shift shaft is not a new problem. Take a look at my post #15 showing shift shaft end thrust resisting washers to bridge over the oil seal, a sawcut about halfway through the shift arm and cross-drilled holes through the shift lever footpad bolt to weaken the lever etc. with the intention of breaking outside before something breaks inside. If the pad bolt or the lever end breaks off then there is enough lever left to shift gears.
https://www.triumphrat.net/club-cafe...se-call-2.html
Ntnbutrbl is offline
post #84 of 104 (permalink) Old 02-15-2019, 05:33 PM
Simon64ds's Avatar
Ah, I see. I didn’t really understand, sorry. The problem is, we can only guess at why anything is designed the way it is. Why was the shifter designed like that? Why was the 900 artificially restricted to well below it’s actual potential? Why use ‘this’ material and not a stronger/lighter/more durable one? Why? Why? Why?
The truth is - no one knows. We can all make guesses and theories to ‘justify’ things, but they’re only guesses and theories. The only people who actually know are the design team - and they’re not telling!
Indeed some times the factory actually sets out to mislead the public by failing to disclose material facts. Like the ‘new’ more powerful 900 where they’re trying to infer that they haven’t fitted a different camshaft for instance, when they most certainly have. Presumably because they don’t want people joking that they went out and bought a stack of TEC cams!
I hope you get your bike fixed up OK, stay safe.
cosmetik and Eakins like this.
post #85 of 104 (permalink) Old 02-15-2019, 10:20 PM
It would be so good if someone in Triumph's design/R & D department would reply to problems with Triumphs in customers' hands to explain things such as the shift mechanism fragility during a left side tipover dating back to at least 2007, the fragility of an early Hinckley Bonneville starter intermediate shaft bearing boss, and occasional Bonneville footpeg bolt breakage and why they do not respond in an energetic manner to these design weaknesses. They should certainly know that this site exists.
Fortunately, work can be done by owners to prevent the above-described weaknesses from making a failure.
Forchetto and StreetTwin like this.
post #86 of 104 (permalink) Old 02-16-2019, 01:34 AM
Main Motorcycle: KTM Freeride
cougsfan's Avatar
Other Motorcycle: '17 Triumph T120
Extra Motorcycle: '78 BMW R80/7
Just think if dirt bikes had shift mechanisms this fragile! I have done far more than minor tip overs directly on the shift lever, even bent the lever around 90 degrees with no damage to the internals. Maybe Triumph should buy a dirt bike and tear one apart to see what they do differently.
StreetTwin likes this.
cougsfan is offline
post #87 of 104 (permalink) Old 02-16-2019, 04:33 AM
Main Motorcycle: Triumph Street Scrambler
Other Motorcycle: 1995 Triumph Trident
Extra Motorcycle: 1966 DMW Deemster
I disagree I don't believe Triumph have fitted a new cam in the 900s.
philmore is offline
post #88 of 104 (permalink) Old 02-16-2019, 04:37 AM
Main Motorcycle: My old 1967 '500
Twintorsk's Avatar
These bikes are primarily ridden by guys in dandy suits larping some non existent past i dont think triumph saw the need to engineer them.for hard use?
Twintorsk is offline
post #89 of 104 (permalink) Old 02-16-2019, 09:00 AM
Simon64ds's Avatar
Fair enough. I expect the truth will be revealed in the fullness of time. Meanwhile it’s not keeping me awake at nights..
post #90 of 104 (permalink) Old 02-23-2019, 07:51 AM
Main Motorcycle: Bonneville
BonnieJon's Avatar
Other Motorcycle: bmw
my nylon spacer now added...
StreetTwin and Simon64ds like this.
BonnieJon is online now
I saw (and heard) the Street Twin today 2wheel_Ted Air Cooled Twins Talk 31 08-17-2018 06:38 PM
Seeking subjective advice on trading in a 2015 Bonneville SE for a 2016 Street Twin Scrambler900 Air Cooled Twins Talk 94 02-29-2016 07:04 PM
Triumph’s questionable marketing campaign… Britfan Air Cooled Twins Talk 270 02-28-2016 02:06 PM
MCN Street Twin initial ride review Sofiaspin Air Cooled Twins Talk 9 12-14-2015 07:04 PM
motorcycle.com Street Triple R review Tbirdnz News Room - Homepage 3 09-17-2012 05:29 PM
