Street Twin lost downshifting, bent internal shift mechanism DIY walk-through - Page 8 - Triumph Forum: Triumph Rat Motorcycle Forums
 101Likes
post #71 of 104 (permalink) Old 02-13-2019, 07:11 PM
Main Motorcycle: Thruxton R my19
cosmetik's Avatar
Other Motorcycle: dyna super glide my07
Extra Motorcycle: street cup my18 (dead)
@Simon64ds indeed a terrific bike... but any comment on the exhibits?
rock & roll baby
been there, done that.
cosmetik is online now
post #72 of 104 (permalink) Old 02-13-2019, 07:47 PM
Main Motorcycle: KTM Freeride
cougsfan's Avatar
Other Motorcycle: '17 Triumph T120
Extra Motorcycle: '78 BMW R80/7
Originally Posted by StreetTwin View Post
Feel free to message me if I was not clear in the above description.
I now see what you are talking about. I also now understand your math. What hung me up is that I have never seen anyone express pi as (22/7). Interesting way to remember a value fairly close to pi.
cougsfan is offline
post #73 of 104 (permalink) Old 02-13-2019, 08:38 PM
Main Motorcycle: 2016 Street Twin
StreetTwin's Avatar
22/7 is a close representation of pi.
https://www.quora.com/Why-do-we-use-22-7-for-pi
StreetTwin is offline
post #74 of 104 (permalink) Old 02-14-2019, 03:29 AM
Main Motorcycle: T100 LC
Simon64ds's Avatar
Other Motorcycle: Street Triple R
rock & roll baby
You mean do I have any comments on your photo?
Sure I do. You crashed your bike and it sustained damage.
Do I think the factory deliberately ‘engineered’ the shifter assembly to be sacrificial in a crash? No, sorry, I don’t. I think that when designing, from a clean sheet of paper to create a brand new engine, what happens when the owner falls off it is a long way from the desiigner’s mind.
tsmgguy and StreetTwin like this.
Simon64ds is offline
post #75 of 104 (permalink) Old 02-14-2019, 06:16 AM
Sharkguy's Avatar
Other Motorcycle: Buell Ulysses
Originally Posted by Simon64ds View Post
But surely the standard seal buts up against a lip cast into the cover? In other words it is ‘positively located’ into it? I would love to see a close up view of the inside of the clutch cover.
Anyway, as a precaution that I’m wrong (wouldn’t be the first time I can promise you) I have now fitted a Mk2 version of the delrin spacer. No bloody way is that shift shaft being knocked inwards now.
Here ya go, the one still has the washer stuck to the bearing/seal. Lots of thickness there.
ID:	633780   Click image for larger version
Sharkguy is offline
post #76 of 104 (permalink) Old 02-14-2019, 07:11 AM
Main Motorcycle: Triumph Boneville 2017 T
I ended up using what I have in the garage and that was washers.
I put two 28mm/14 followed by one 23/12.
My washers are a bit thicker.
Sent from my SM-G935F using Tapatalk
StreetTwin and Simon64ds like this.
Singlin is offline
post #77 of 104 (permalink) Old 02-14-2019, 09:19 AM
StreetTwin's Avatar
Looks as if you have two big washers and two smaller washers. No matter. Use whatever you have and whatever works. Ideally you would want a close fit that still allows free movement of the shift lever. Do double check your clearances when the engine is hot as metal expands when heated.
post #78 of 104 (permalink) Old 02-14-2019, 10:05 AM
cosmetik's Avatar
no. i mean on the exhibits. have you seen videos of motorcycles "standing up" after crashes?
most of the experience i read here is from a tip over on the garage/mellow cruising and how to avoid a "costly" repair. lets pretend there could be a reason on why this is designed this way apart from negligence. i think it would enrich the thread.
rock & roll baby
post #79 of 104 (permalink) Old 02-15-2019, 11:14 AM
Main Motorcycle: Street twin
Eakins's Avatar
The dimensions I have are 14mm internal diameter, 25 mm external diameter and 6 mm thickness.
Guys, I do not claim that these are the ‘best’ sizes (and they’re certainly not the ‘only’ sizes) but they’re what I ended up with.
We used an off-cut of delrin bar that was kicking around (the engineers - which I am emphatically not - used it for making gears as a ‘day job’ before the business closed). Now the workshop is turned over to race bikes (which has the added attraction of not spending too much time with the wives.. ).
Thanks for the specs on the delrin washer. I ordered enough delrin bar knowing that using hand tools and a drill I wouldn't get the accuracy on the first attempt but I got there in the end. Here's some pics.
Simon64ds likes this.
Eakins is offline
post #80 of 104 (permalink) Old 02-15-2019, 12:07 PM Thread Starter
Sabathius's Avatar
Nice job! That's exactly what I'll be doing with my Delrin rod order arrives.
Sabathius is offline
I saw (and heard) the Street Twin today 2wheel_Ted Air Cooled Twins Talk 31 08-17-2018 06:38 PM
Seeking subjective advice on trading in a 2015 Bonneville SE for a 2016 Street Twin Scrambler900 Air Cooled Twins Talk 94 02-29-2016 07:04 PM
Triumph’s questionable marketing campaign… Britfan Air Cooled Twins Talk 270 02-28-2016 02:06 PM
MCN Street Twin initial ride review Sofiaspin Air Cooled Twins Talk 9 12-14-2015 07:04 PM
motorcycle.com Street Triple R review Tbirdnz News Room - Homepage 3 09-17-2012 05:29 PM
