Handle bar shake - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 24 (permalink) Old 01-24-2019, 03:39 AM Thread Starter
Twin Phill's Avatar
Handle bar shake
On my way to work today l let go of the bars, vibration was excessive 60kmh. Held the bars again (thinking s#@t) shakes gone. The bike is 9 months old 7000kms, I bought it new and have never damage the bike or popped wheelies. I just some info so when I go to the dealership I'll be prepared.
Twin Phill is offline
post #2 of 24 (permalink) Old 01-24-2019, 06:02 AM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
7000km.
Are your tyres ok?
Pressure ok.
Headstock bearings.
Front wheel to rear wheel alignment?
Others will add to this I am sure. Hi
Tricolour is offline
post #3 of 24 (permalink) Old 01-24-2019, 06:30 PM Thread Starter
Twin Phill's Avatar
Hi mate everything is in good nic. Maybe the head stock need tightening? Thanks for your help.
post #4 of 24 (permalink) Old 01-24-2019, 07:55 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
My $0.02 is on the front tire. Add you location and bike to your profile as that might help.
vitesse likes this.
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #5 of 24 (permalink) Old 01-24-2019, 10:58 PM
Main Motorcycle: 2017 T100
LA-Liquid-T100's Avatar
Other Motorcycle: 1977 CB750F2
Handle bar shake
The front tire probably needs to be rebalanced.
I started getting wobble when I took my hands off the handlebars at around 7,000 miles... rode it for another 4K miles. Went away when I got the new tires.
2017 T100- LSL Flat Tracker handlebars, Booster Plug, Modified comfort seat with Supracor, Chrome Grab Rail, Triumph Barrel Style Hand Grips, Aluminum Oil Filler Cap, Cibie 82240 Light unit, Triumph Center Stand
LA-Liquid-T100 is online now
post #6 of 24 (permalink) Old 01-25-2019, 04:01 AM Thread Starter
Twin Phill's Avatar
Thank you everyone for the input, new to any like this. It's great to be a part of one.
post #7 of 24 (permalink) Old 01-27-2019, 09:48 PM
Main Motorcycle: 2017 Triumph T120
Motard-Menace's Avatar
Most likely the front tire, as this has been the case for numerous folks. That said I actually had a bad rim on my 2017 that Triumph took care of under warranty with a new rim. So if replacing the tire doesn't solve the issue then have someone take a look at the rim balance without a tire on it. Mine had a bad weld apparently.
Motard-Menace is offline
post #8 of 24 (permalink) Old 02-19-2019, 08:28 PM
richreed701's Avatar
Other Motorcycle: None at this time
My T120 needed the steering head adjusted ("tightened") somewhere less than 5K miles, which probably corresponds to your 7000 km. Again, not a wheelie guy, don't ride aggressively and always maintained proper tire/tyre pressure. I do admit to being a tad on the hefty side and I do a lot of weekend touring (i.e. an extra 40 pounds of baggage and stuff). I remember thinking at the time that this was quite early in the bike's life to need the steering head tinkered with. I have run a lot of Kawasakis and a few Hondas and steering head adjustments were usually a 35K mile event, not 4500.
I suspect it is the nature of the beast, kinda like that first chain adjustment or retorqueing the head bolts after the initial run. The bike is well north of 10K miles now and everything is just peachy. No head shake.
I think I remember elsewhere on this forum that some owners have replaced the steering head bearings with aftermarket ones. Maybe Triumph went with the lowest bidder?
Rich Reed
Woodinville, WA
richreed701 is offline
post #9 of 24 (permalink) Old 02-20-2019, 01:54 PM
Main Motorcycle: 2018 T120 Bonneville
aj7840's Avatar
Other Motorcycle: 00 Ducati Monster 900
Extra Motorcycle: 07 BMW K1200GT
You could have a problem!
Is this the first time you took you hands off the bars and discovered this, or have you occasional taken both hands of the bars and this just developed. If it's the latter it is a problem and should be corrected.
Some motorcycles do have a wobble when you take your hands off the grips, older Goldwings were notorious for this.
Quick steering sport bikes tend do it, which is why most of them have steering dampers. Some bikes just need one hand on the bars to dampen this out. It also is more frequent with bikes that use tapered bearings in the steering head if they are not properly adjusted
IF you feel it with one or both hands on the bars it is a problem
My T120 is still at the dealers waiting for winter to end and a chance to increase the mileage from 1.0 miles, so I can't say it this is normal on the T120.
Almost all of the bikes I've owned or ridden that did not have a steering damper tended to do this. The old Meridian Triumphs had a friction steering damper.
It is what it is, until it isn't
aj7840 is offline
post #10 of 24 (permalink) Old 02-21-2019, 01:13 AM Thread Starter
Twin Phill's Avatar
Both hands on the bars, no shake. One hand on the bars, no shake. No hands on the bars, shake. Thanks for your you information, I am going to take it back to the dealership.
Lowering the handle bar... aj700 Speed Triple Forum 37 01-16-2017 08:21 PM
handle bar swap question zoom Street Triple Forum 6 01-03-2017 11:18 AM
2015 Bonneville stock handle bar height Mhoffm Air Cooled Twins Technical Talk 3 10-08-2015 10:14 AM
Sprint 2003 Handle bar conversion.. Help with Lockstock Sprint Forum 6 08-18-2012 02:38 AM
Replacing handle bar due to crash midliferider Hinckley Classic Triples 10 09-07-2008 12:41 AM
