Throttle Spacers - Remove throttle sloppiness - Page 6 - Triumph Forum: Triumph Rat Motorcycle Forums
 43Likes
post #51 of 68 (permalink) Old 07-03-2019, 10:50 AM
Main Motorcycle: ThruxtonR,
pmorritt's Avatar
Other Motorcycle: BMWR1100RT
Originally Posted by Tricolour View Post
Just checked my bike.
I do have a horn button.
I may have pressed it accidentally without noticing.
As far as the throttle slack remover bizzo goes I haven’t noticed a throttle problem on my R.
Me too. 3 years with my TTR and never noticed a problem. Every one of my bikes had an initial bonding ride. After that all smiles.
Masquerading every day as a normal person is exhausting.
pmorritt is online now
post #52 of 68 (permalink) Old 07-04-2019, 08:48 AM
Main Motorcycle: Triumph Speed Triple S
Originally Posted by Glock Holiday View Post
I installed them as my second mod the first being replacing the meep meep horn with a Faimm freeway blaster and I like the difference they make...Do I think they are overpriced for what you actually get? You bet. Am I happy with them installed om my bike? Yes I am...
To each his own I always say.
cheers!
I do have a horn button.<img src="https://www.triumphrat.net/images/TriumphRat_2015/smilies/tango_face_grin.png" border="0" alt="" title="Big Grin" class="inlineimg" />
Dude-you must not be as sensitive to the loose throttle as the rest of us who feel a huge difference. As an experiment, you should order and install them, ride for a day, then decide is you don’t notice anything. If you don’t, return them for a refund. I can tell you I enjoy riding MORE with the spacers than without.
PrimoThruxton and SUPERCRUZ like this.
Mylesb21 is offline
post #53 of 68 (permalink) Old 08-12-2019, 04:15 PM
Main Motorcycle: 2020 Triumph Speed Twin
MotoChooch's Avatar
Other Motorcycle: 2016 Tiger 800 XRt
Installed these on my Speed Twin. HUGE difference! Love it. Just wish they made them for my 16 Tiger XRt.
PrimoThruxton likes this.
2016 Triumph Tiger 800 XRt; 2020 Triumph Speed Twin
Previously: 2009 Kawasaki Vulcan 900 Custom, 2016 Triumph Street Triple R, 2019 Triumph Speed Triple RS
MotoChooch is offline
post #54 of 68 (permalink) Old 08-23-2019, 02:45 AM
Newbie
Dave Jarman's Avatar
Made 4 spacers 6mm x 4mm from an old bank card superglued to each side of throttle body dovetail exact width and no filing cost was a drop of super glue
Dave Jarman is offline
post #55 of 68 (permalink) Old 08-23-2019, 02:25 PM
Main Motorcycle: 2017 T100
LA-Liquid-T100's Avatar
Other Motorcycle: 1977 CB750F2
Originally Posted by Kahrooco View Post
Hello All, i owned a 2017 Street Twin.My throttle hand would be buzzing for a hour after the ride. I traded in the Street for a T120. I no longer have the sleepy hand syndrome.The Street Twin throttle had alot of side to side as well as back and forth movement .The service manager and lead mechanic asked me is there anything wrong with the bike S.T,i said "great bike but i did not want the buzzing in my hand".They asked me what i felt was the issue i stated they sloppyness of the throttle. I tested the throttles on all the show room models examples Harley,triumph's you would be surprised the difference's. I was told i could add vinyl shims ,o-ring's to the end to eliminate some of the unwanted not kneaded slop.I didn't try suggestions i would have i just traded up to the T120. I have no issue anymore with my hand .The T120's have a larger diameter (fatter)handle bar that helped too. So to the non believers of eliminating slop "your a wrong Rat".Safe riding all..
I would add that going from a 7/8” bar to a heavy 1” bar would be most of your vibration solution. Another aspect to the T120/100 is that they have thick isolation rubber that is in between the 4 bolts that hold the bar down. Congrats on your 120!
2017 T100- OHLINS TR 634/FKS 215, LSL Flat Tracker handlebars, Booster Plug, STS (Smart Turn System)auto turn signal cancelation, Modified comfort seat with Supracor, Chrome Grab Rail, Triumph Barrel Style Hand Grips, Aluminum Oil Filler Cap, Cibie 82240 Light unit, Triumph Center Stand
LA-Liquid-T100 is offline
post #56 of 68 (permalink) Old 09-09-2019, 05:29 AM
Main Motorcycle: 2016 Thruxton 1200
CanberraR3's Avatar
Other Motorcycle: 2018 Street Scrambler
Extra Motorcycle: 2016 Tiger 800 XCX
Wow, I just found this thread. I kept seeing people referring to how they’d fixed their sloppy throttle so I did a search to see what the issue was. Four ride by wire Triumphs in my garage and I never realised I was supposed to be having difficulty with take offs, cornering, blipping the throttle or riding smoothly. It’s so obvious that this is fixing a non-existent problem for people who most likely lack the experience or skill to to cope with a normal condition. Sorry, but that’s the way I see it. Each to their own, so spend the money if you feel you need to but please respect my decision not to.
cougsfan and Roasted like this.
CanberraR3 is offline
post #57 of 68 (permalink) Old 09-09-2019, 07:30 AM
Main Motorcycle: Speed Twin
Other Motorcycle: Ducati Multistrada
Extra Motorcycle: KTM 300 & 500
I had no problems as mentioned above
but I didn't like a quarter inch of throttle play
so it was worth it to me to install the spacers to get rid of it
and- each person might find various benefits from installing them--for $40 bucks thats a cheap mod on a motorcycle even if it is a little part--it fits perfect
markg333 is offline
post #58 of 68 (permalink) Old 09-09-2019, 12:09 PM
Dougl1000's Avatar
There is no sloppiness in my throttle. The spring returns it to zero throttle and the rpms increase continuously from zero. Dealertool reads closed throttle as 0.8%. The spring is progressive. The resistance is light until about 5-7% throttle above which it becomes greater. Is this what people mean by sloppiness?
Dougl1000 is online now
post #59 of 68 (permalink) Old 09-09-2019, 12:41 PM
Highball's Avatar
+1
I rode my Speed Twin 125 miles to bring it home from the dealership.... No problems other than not caring for the excess slack. Tossed the spacers in afterward and I like the difference.
@CanberraR3 just likes to talk smack... but you better respect his smack talk, dammit! Lol.
Highball is online now
post #60 of 68 (permalink) Old 09-09-2019, 12:43 PM
Highball's Avatar
These spacers don't work on a T120 or any TBW Triumph with a 1" bar.
LA-Liquid-T100 likes this.
Motor Dies just as I take up throttle cable slack. TR7RVMan Classic, Vintage & Veteran 33 09-06-2018 01:02 AM
Throttle cable measurements clumsy Hinckley Classic Triples 8 04-13-2018 10:41 AM
Balance Throttle Bodies without removing wheel, fender, etc. thensley Water Cooled Twins Technical Talk 0 09-15-2017 06:31 PM
Carb Tuning ? toxic Classic, Vintage & Veteran 19 08-24-2016 05:21 PM
At idle, bike is rolling ~8mph? What's up with the throttle? Atom30 Street Triple Forum 20 06-11-2015 04:29 PM
