Handlebar end plugs - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 05-14-2018, 09:54 AM Thread Starter
Main Motorcycle: 2018 Bonneville T120
Blusideupp's Avatar
Other Motorcycle: 2018 Speedmaster
Handlebar end plugs
I will be changing out the bars on my new Speedmaster with an LSL Flat Track bar. The new bar does not have threaded end plugs like the stock bars do.
I do not want bar end mirrors. Any recommendations for end plugs for a 1" bar?
Blusideupp is online now
post #2 of 5 (permalink) Old 05-14-2018, 11:02 AM
Main Motorcycle: Triumph Bonneville T100
DesertBum's Avatar
Other Motorcycle: Prev. TigerXCX, Tiger abs
I'm in the same boat for a slightly different reason - I have new bars but apparently mislaid the threaded plugs that came with my bar end mirrors. There's lots of commercial ones out there through the usual suspects and fleabay, but they tend to be pricy for what they are. However watching one of Delboy's videos he just used a concrete wall anchor. With that you could use your original end cap but probably with a larger bolt. I haven't looked yet but I think they also make plastic anchors that might work and take the original screw with the cap. I'm going to try that before I look at the moe expensive options.
DesertBum is offline
post #3 of 5 (permalink) Old 05-15-2018, 07:00 AM Thread Starter
Blusideupp's Avatar
Not a bad idea. It's worth looking into.
Here is Delboy's video that DesertBurn is referring to..
post #4 of 5 (permalink) Old 05-16-2018, 03:42 PM Thread Starter
Blusideupp's Avatar
No luck finding any anchor bolts today like in the video. ( at 3:30 mark on the video) All I could find were the kind with the big hex nut on the end.
post #5 of 5 (permalink) Old 05-17-2018, 12:54 AM
DesertBum's Avatar
Well having pointed out Delboy's video I spent part of today trying to find one as well. No luck, but since I'm mounting bar-end mirrors I need strength and rigidity (so the mirror doesn't vibrate too much). However, one possibility I did notice if you're only you're only mounting the end caps is to simply firmly pound in a rubber stopper, cut off the excess flush with the end of the bar, then drill a hole in it for your cap bolt. Drilling in rubber like that is kind of weird and the hole won't look big enough, but it will firmly grip whatever is screwed in.
Bar end turn signals on a WC or T120 model (Street Twin, Bonnie, Thruxton, Bobber) EintrachtL÷we Water Cooled Twins Technical Talk 5 02-02-2019 07:32 PM
Sprint GT/ ST handlebar conversion kits chriscoote Sprint Forum 72 04-25-2018 01:31 AM
Bar End Mirrors - Problem Seantx Speed Triple Forum 4 04-11-2017 11:25 AM
engine cut out lilic24000 Classic, Vintage & Veteran 25 03-31-2017 11:36 PM
Bar End Mirrors & Finishers Scrambler900 Water Cooled Twins Technical Talk 15 05-13-2016 02:57 PM
