How many deep battery cycles? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 5 (permalink) Old 04-15-2018, 10:52 AM Thread Starter
Main Motorcycle: Triumph Bonneville T100
DesertBum's Avatar
Other Motorcycle: Prev. TigerXCX, Tiger abs
OK, probably my rapidly onsetting dementia but three times now in the past month or two I've left the key turned on when parking the bike and ran the battery down where it would not start. This last time it was dead enough my compact Li jump starter wouldn't work. After recharging I put a battery tester on it and it showed fine on the voltage but in the upper 'weak' zone when load tested. What I'm wondering is how many times I can do this before I should start thinking of replacing the battery. I'd rather not wait until the battery is totally dead some day and I'm far from home.
Edit - the bike (thus battery) is only 7 months old.
DesertBum is offline
post #2 of 5 (permalink) Old 04-15-2018, 05:39 PM
Main Motorcycle: '17 Bonneville T100
Kris_01's Avatar
Batteries don't like being run down. The life of that battery is probably "iffy".
Kris
Kris_01 is offline
post #3 of 5 (permalink) Old 04-15-2018, 06:02 PM
Main Motorcycle: 2016 Thruxton S
Ashman's Avatar
Other Motorcycle: 850 Norton Featherbed
Extra Motorcycle: 1960 650 Manxman
Send a message via Yahoo to Ashman
Just make a habit of taking your key out as soon as you stop, never use the kill switch as thats one way of forgetting to turn your key off and your insurance will not help if you left the key in your bike when leaving it if it goes missing.
Ashley
Ashman is online now
post #4 of 5 (permalink) Old 04-24-2018, 01:28 AM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
If you managed to resurrect your battery after discharging it fully just once then you dodged a bullet.
Tricolour is online now
post #5 of 5 (permalink) Old 04-24-2018, 05:41 AM
If you are that worried, why not replace it? It's not serious money for a new battery and that would put your mind at rest. And as Ashman says, get into the habit of always removing the key when parked to ensure it's turned off.
sensitive is offline
Ď72 TR6R Tiger 650 Newbie Questions N8wink Classic, Vintage & Veteran 38 01-05-2018 07:15 AM
help me wire my 1970 t120 650 cheapstreet Classic, Vintage & Veteran 20 12-09-2017 06:36 AM
My 3-month-old Battery Died suddenly dchernikoff Air Cooled Twins Technical Talk 11 08-04-2017 09:01 PM
Battery draining and gear engaged. Help welcome! Berlino Air Cooled Twins Technical Talk 29 04-21-2016 04:22 AM
melted fusebox and flat battery blueblackhussar Daytona Deliberations 5 04-20-2015 06:59 PM
