Repairing flat on '17 T100 front wheel - Triumph Forum: Triumph Rat Motorcycle Forums
 9Likes
post #1 of 16 (permalink) Old 12-18-2017, 09:48 AM Thread Starter
Main Motorcycle: Triumph Bonneville T100
DesertBum's Avatar
Other Motorcycle: Prev. TigerXCX, Tiger abs
OK, I know all about how to fix the flat on a tubes wheel once it's off the bike, but getting the wheel off if out traveling has me baffled. On my old Tiger I'd put it on the center stand and with just the tiniest shifting of weight (i.e. removing or leaving my luggage boxes on) I could have either wheels off the ground for removal. On the Bonnie, NOT. I have it on the center stand and the weight is clearly forward. I put 40lbs of weight in my luggage bags and the front wheel was still firmly on the ground. Had to literally sit on the back to get the front wheel to rise. At home I resorted to a jack under the skid plate, but is there some other trick to getting the front up so the wheel can be removed? Carrying a jack is of course not an option. If I'm with someone else they could sit on the back the whole time but I usually am riding off alone. Help!!!
DesertBum is offline
post #2 of 16 (permalink) Old 12-18-2017, 01:51 PM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
You're right. This operation can't be done without a jack or a lift. You'd also need a 17mm Allen socket key and some way to drive it, plus other tools. No one carries this stuff when they ride, so road side assistance is about the only option.
I take comfort in the fact that I've never had a flat in all my years of owning and riding many different bikes, all with tube-type tires.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #3 of 16 (permalink) Old 12-19-2017, 02:01 AM
Main Motorcycle: 2016 Bonneville T120
NN65's Avatar
Other Motorcycle: 2005 Kawasaki W650
Extra Motorcycle: 1965 Jawa CZ360, RIP
Not as lucky as Tsmgguy here: 3 flats in a year. Maybe Vietnamese roads... two screws, one of which legit’ (*) and a cutter blade.
The 17mm Allen key weighs over a kilo I reckon, but is a necessary addition for a touring toolkit, as they don’t come easy, even a town-sized tyre repair shops.
I have a jack but found the engine bash plate is good enough if you slip logs under to prop up the front wheel, as long as you are careful and don’t load the bike while it’s up.
Ride-on did not save me from the flat, and repair spray gave me some respite from pump to pump to a proper-looking shop.
I often carry a battery-driven air pump on the longer rides, to be used while the engine runs.
I use Fobo TPMS, which have saved my day twice in the three times (not installed until after the first flat on the front wheel).
Aaaah the joys of riding.
No irony here: you couldn’t wipe the smile off my face.
NN
(*) one was sharp at both ends, and found in a high-repair-shop-density area.
Smile safely, ride easy
keep the rubber-side down
NN65 is offline
post #4 of 16 (permalink) Old 12-19-2017, 02:02 AM
NN65's Avatar
Makes me think of having a 17mm male bit made, to adapt to large wrench holders.
NN65 is offline
post #5 of 16 (permalink) Old 12-19-2017, 03:21 AM
Main Motorcycle: Thruxton 900
Other Motorcycle: Thruxton 1200r
Extra Motorcycle: KTM Duke 390
17mm bolt with 2 nuts locked together a dot of weld to make good should do the job .
The Hornet likes this.
Hedgepig is online now
post #6 of 16 (permalink) Old 12-19-2017, 03:31 AM
Main Motorcycle: T100 LC
Simon64ds's Avatar
Other Motorcycle: Street Triple R
@DesertBum Why don’t you go to an Auto Breaker and buy a scissor jack of the sort used in small Hondas and Toyotas? If you’re already packing tyre irons, pump, spare tubes etc it’s not going to add too much extra weight.
The front spindle is easy - use a ‘multi adapter’. These nifty little things have 17,19,22&24 mm hexagon heads and fit pretty much every bike. They’re small, cheap, light and invaluable.
Look on Amazon or EBay for ‘motorcycle front spindle tool’ or similar. Or put this item # into EBAY..
202140363471
Good luck.
Simon64ds is offline
post #7 of 16 (permalink) Old 12-19-2017, 07:52 AM
Kevhunts's Avatar
Other Motorcycle: 1972 Yamaha DT2
Thought about adding Slime to my tubes. Anyone tried this?
"For every one you see, you probably missed three"
Kevhunts is offline
post #8 of 16 (permalink) Old 12-19-2017, 08:24 AM
The Hornet's Avatar
You could seal the rims and go tubeless
Simon64ds likes this.
Red Devil
The Hornet is offline
post #9 of 16 (permalink) Old 12-19-2017, 08:39 AM
Main Motorcycle: Thruxton 1200R 2016
jsobell's Avatar
It's not often I get a puncture in the front, but went to ride home today, and found the front felt a bit soft.
I still rode it home, and tomorrow morning I'll top up the air and ride it down to the workshop to fix it up.
Now if this had been a tubed wheel, this would probably have done the usual explosive decompression on the way in to work, and there's no way in hell I could have ridden it home.
The Hornet and Delta like this.
Bike with a few things added, such as... me. I prefer riding my bike to bragging about the chromed rear foot-pegs. Does that make me strange?
jsobell is offline
post #10 of 16 (permalink) Old 12-19-2017, 10:54 AM
Main Motorcycle: 2017 Street Twin 900
I'm just posting in response to @jsobell and his well scrubbed in tires. Nice to see it is being ridden hard. Do you take it to the track?
Delta is offline
Front wheel lip bent efixe Street Triple Forum 27 04-22-2017 11:48 PM
Front wheel fit VodkaAndPickles Air Cooled Twins Technical Talk 1 01-25-2016 09:58 PM
Spindle sequence on conical hub front wheel Bear of Little Classic, Vintage & Veteran 5 12-08-2015 11:24 AM
Fitting new front wheel bearings T140. Reassembly with a hitch. Rod Rocket Classic, Vintage & Veteran 2 10-27-2015 05:43 PM
