Sticky Clutch <1k - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
  • 1 Post By Glimmerman
post #1 of 9 (permalink) Old 04-07-2017, 10:22 PM Thread Starter
Sticky Clutch <1k
I'm still less than 1k miles, or around that and my clutch cable is already sticky. I noticed it a few days ago- engine seems 'grainy' in first for lack of a better work, a bit slow even though I'd hit the rev limit. Then today, I'd pull in the clutch only to have it stick. And it wouldn't fully release unless I actually pushed it out. I could tell it wasn't fully releasing as I could feel the engine kick a tiny bit right when I'd push it out. I have been riding in all weather, but I rode in worse conditions on my old bike that presumably didn't have a teflon cable.
Any suggestions? Aside from taking it to the shop tomorrow and getting a new cable under warranty...and missing out on the best weather weekend we're going to have this year.
Even though I don't want to- I'm still taking it in since this bike is so new- I wouldn't expect to have issues so early on. Anything else the sticky lever might be indicative of? Anything potentially more serious? I'm running stock levers.
squidlydickens is offline
post #2 of 9 (permalink) Old 04-09-2017, 04:06 AM
Main Motorcycle: Street Twin
Other Motorcycle: Kymco 300i
Always worth disconnecting the cable at the bars and running some oil through on any new bike. There is a myth that nylon lined cables don't need lubricating but once a bit of dampness has corroded the dry inner cable the damage is done.
STroadster is offline
post #3 of 9 (permalink) Old 04-09-2017, 11:00 AM
Main Motorcycle: 2016 Thruxton R
c317414's Avatar
Other Motorcycle: 1974 Norton Commando
Extra Motorcycle: 1967 TR6C
The myth is grounded in fact. The solvents in some lubricants damage the liner and make the issue worse.
c317414 is offline
post #4 of 9 (permalink) Old 04-10-2017, 11:43 AM Thread Starter
So- an update, the cable was fine. Somehow the lever screw had gotten tighter... and was holding the level in.
post #5 of 9 (permalink) Old 04-13-2017, 06:40 PM
Main Motorcycle: 2017 Street Twin in Red
Other Motorcycle: 1976 BMW R75/6
I had the same problem but with clutch slip as well. Turned out it was road dirt that had got into the lever stopping it from returning fully. A wash with WD40 followed by spray grease sorted it.
OldSalty is offline
post #6 of 9 (permalink) Old 08-17-2018, 06:49 AM
Qeww's Avatar
Interesting. I’m having a similar issue but at 10k mile. Glad to hear it’s only dirt and grime. I’ll give it a better, more throughout, washing and see if that’s the problem.
Qeww is offline
post #7 of 9 (permalink) Old 09-11-2019, 04:56 AM
Glimmerman's Avatar
Bump the thread... just rode home and clutch got progressively worse. An VW R36 thought I was teasing him off the lights. Cleaned the cable as best I could and then removed and cleaned the clutch lever assy, lubed and reassembled. Rain for the next day or so so will check on Saturday if fix sticks (pun intended).
Glimmerman is offline
post #8 of 9 (permalink) Old 09-11-2019, 08:45 AM
Main Motorcycle: Daytona 675R
Scottty's Avatar
Other Motorcycle: Thruxton R
Just had this issue on my Thruxton r, clutch started slipping a bit under acceleration and then the lever felt tight and not returning fully, cable was fine as expected with modern teflon lined cables, took the lever off and found the pin was fine inside the bush but the brass Bush was tight in the actual lever, when I pushed it out I found part of the bush picked up on the aluminium in the lever bore, unlike the one in the brake lever I think this Bush needs to be free to move, there is a machined groove in the bush that's presumably there to hold Grease. Had to clean up the bush and the lever with some fine Emery, greased everything and now it's back to normal.
And before you say that's poor maintenance on my behalf, in my defence I've only just bought the bike and it had supposedly been serviced before collection, I think they'd just done an oil change at most. The levers felt fine when I got the bike and I would have stripped them and greased them when I serviced it in the winter.
I've just done both brake levers clutch and gear lever just to be sure though now.&#x1f61c;
Scottty is online now
post #9 of 9 (permalink) Old 09-14-2019, 06:50 AM
Glimmerman's Avatar
Seems to have worked, relieved it was just the lever and not clutch plates. Lovely spring day out ... gratuitous shot of HMAS Melbourne in the background pending her decommissioning.
Scottty likes this.
Another stiff clutch thread blacki999 Daytona Deliberations 2 03-07-2017 08:02 AM
Reducing clutch effort - easy modification Coroja Maintenance & Workshop Talk 2 03-31-2016 07:20 AM
Clutch replacement. maydaymike Air Cooled Twins Technical Talk 25 11-22-2015 05:21 AM
955i Clutch problem whiteyboy Speed Triple Forum 3 11-20-2015 08:57 AM
Clutch play setting question Washryc Air Cooled Twins Technical Talk 3 03-09-2015 09:51 AM
