Thruxton noise on ignition - Triumph Forum: Triumph Rat Motorcycle Forums
 5Likes
  • 1 Post By tsmgguy
  • 1 Post By shadydaverave
  • 1 Post By tungvo
  • 1 Post By looseparts
  • 1 Post By Forchetto
post #1 of 10 (permalink) Old 05-27-2016, 04:35 PM Thread Starter
Main Motorcycle: Thruxton R
When I turn the ignition key on my Thruxton before pressing the starter the bike does its little prep routine, then there is a constant light whirring noise from somewhere in the engine.
I don't recall this on my previous Triumphs. I guess it is normal but thought I would check. Thanks
Wilco10 is offline
post #2 of 10 (permalink) Old 05-27-2016, 06:17 PM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Don't know for certain but I'll bet it's either the radiator fan or the fuel pump.
Wilco10 likes this.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #3 of 10 (permalink) Old 05-27-2016, 07:37 PM
Main Motorcycle: 2016 Street Twin
My t120 has the same noise, before starting if you move the throttle you'll notice it change pitch
I think it's the fuel pump and is nothing to worry about
Wilco10 likes this.
shadydaverave is online now
post #4 of 10 (permalink) Old 05-27-2016, 09:15 PM
Main Motorcycle: Triumph Street Twin
tungvo's Avatar
That noise come from the electric system that control butterfly valve. the noise will change when you twist throttle and you could hear valve moving inside engine carb.
Wilco10 likes this.
tungvo is offline
post #5 of 10 (permalink) Old 05-28-2016, 12:27 AM
That makes sense
post #6 of 10 (permalink) Old 05-28-2016, 01:04 AM
Main Motorcycle: 98/01 955 SpeeTona
looseparts's Avatar
Other Motorcycle: 2016 Thruxton R 'Daquan'
Extra Motorcycle: '48 Nimbus w/ sidecar pro
Wow. You're right. That sound did not happen on my '14 or '98 Triumphs - sure, they made sounds resetting the stepper motor and priming the fuel pump but then it stopped once done.
I noticed this new bike keeps making the whirring sound like you said, as long as the key is on. I was a little concerned the first time I heard it, but chocked it up to 'these darn kids... what will they think of next' ; -) After reading this thread, I went to the garage to see if it did change sound with the throttle position and - it does. You can make the darn thing sound like R2-D2 !
I'm pretty sure it's suppose to do that, but I really wonder why. What exactly is going on there?
Wilco10 likes this.
http://serveronthewall.com/motorcycle-blogs/
Recent Bikes: '14 Street Triple R '98 T595 Daytona '79 KZ650 Cafe
'73 DT3 Dirt Track Racer '06 VN900 '67 TR6C Street Tracker '67 T100 Street Tracker
looseparts is offline
post #7 of 10 (permalink) Old 05-28-2016, 03:03 AM
Supernova
Forchetto's Avatar
It could be something to do with a phenomenon called stiction, the static friction present in the sort of moving parts associated with electronic throttles, suspension systems, fluid valves, etc.
An electrical signal, independent of the proper control one (I think it's called an oscillating or "dithering" signal) coming from the twistgrip is constantly injected into the DC motor that controls the butterfly valve and keeps it "exercised" as it were.
As an example we have a machine at work that injects sticky chemicals to be mixed together to produce a packing foam and even at rest there's a constant humming coming from the mixing valves as they're moved to and fro by a tiny amount.
Wilco10 likes this.
Forchetto is offline
post #8 of 10 (permalink) Old 05-28-2016, 03:04 AM Thread Starter
Thanks for the replies that sets my mind at rest.
Wilco10 is offline
post #9 of 10 (permalink) Old 09-08-2019, 04:15 PM
Hi guys i got Speed Triple, after turning the ignition on there’s a sound like in my video. This situation remains few second after turning ignition completely off. Is this sound ur talking about? Any one know what’s that and whether this situation requires repairing? https://m.youtube.com/watch?v=D9j_nV4Q2GY
Jakub95 is offline
post #10 of 10 (permalink) Old 09-12-2019, 02:58 AM
Main Motorcycle: 2019 Scrambler 1200 XE
bobbo's Avatar
Other Motorcycle: 2013 Moto Guzzi Stelvio
Extra Motorcycle: 2006 Scrambler (sold)
Yep, that's the sound. My XE does the same. Managed to fix the noise by putting on my earplugs and helmet before turning on the ignition
bobbo is online now
Thruxton tube fork spacers vs Scrambler tube spacers Sactown Speedy Air Cooled Twins Technical Talk 7 01-31-2016 12:03 AM
Ignition woes Mark Gavin Air Cooled Twins Technical Talk 8 07-15-2015 07:54 AM
Have Immobilizer, dump ignition switch? 15Ace Air Cooled Twins Technical Talk 3 05-31-2015 08:44 AM
