T120 UPGRADE - Triumph Forum: Triumph Rat Motorcycle Forums
 14Likes
post #1 of 13 (permalink) Old 09-14-2019, 10:22 AM Thread Starter
T120 UPGRADE
Hello
HERE is my modification did last week
BAAK N1 Handlebar
Reloc ignition
Reloc Rectifier
Turn Signal
Givi Case
LED stop turn signal on Rear (Case and bike)
Side cover from BAAK custom Number paint by myself
Sorry I wrote a long message and when post it I was log out Grrrrrrrrr
I will do it if some of you have some questions about the install
Here is the Pics
Have a good one (the french guy)
yermak is offline
post #2 of 13 (permalink) Old 09-14-2019, 10:34 AM
Main Motorcycle: '16 Bonneville T120 Black
BarelySober's Avatar
Could you post a full size side view of the bike?
Want to check how the flat side panels impacts on the overall look...
Nice build!
PisgahVol likes this.
BarelySober is online now
post #3 of 13 (permalink) Old 09-14-2019, 10:52 AM
Main Motorcycle: 2018 Bonneville T120
Blusideupp's Avatar
Other Motorcycle: 2018 Speedmaster
Bike looks great. Did you have to add the longer cable kit? If so, how difficult was that, especially the brake line?
Blusideupp is online now
post #4 of 13 (permalink) Old 09-14-2019, 12:06 PM Thread Starter
Yes i bought them with the Handlebar ,What can i say I'm not to much afraid for the re-wiring stuff but brake line yes it was scary and I really hate this fluide , but i did the job and that work I use this tool very cheap on amazon for the brake the one with the pump first it was not working but by my fault after that work pretty good .
The clutch have to be change also and the grip for sure ,But man this is awesome the different for riding I can't beleive they didn't put that handlebar on stock so confortable now it's a (Mobylette )french expression .Do it that worth the job .
Oups just one hole to drill for the right lever I bought the special tool for drilling that worth it also so simple .
For those who are scary to do it it's not a big deal ,The Re-location of ignition was more difficult with the wire what a mess under the tank.
Blusideupp likes this.
yermak is offline
post #5 of 13 (permalink) Old 09-14-2019, 12:10 PM Thread Starter
side cover
here is the picture of side panel cover
yermak is offline
post #6 of 13 (permalink) Old 09-14-2019, 01:23 PM
Main Motorcycle: 2016 THRUXTON S/GREEN
Other Motorcycle: FZ 09
Extra Motorcycle: 2016 FZ07
Nice cases! Those grips are what I always used to put on my bikes, very comfy.
vitesse is offline
post #7 of 13 (permalink) Old 09-17-2019, 12:33 PM
Main Motorcycle: T120 Black MY2018
Mystic's Avatar
Nice mods there. Did you manage to tweak in the heated grips by modifying the handlebar or removed them?
Mystic is offline
post #8 of 13 (permalink) Old 09-18-2019, 04:15 AM
Main Motorcycle: 2017 T100
LA-Liquid-T100's Avatar
Other Motorcycle: 1977 CB750F2
Originally Posted by yermak View Post
Hello
BAAK N1 Handlebar
Reloc ignition
Reloc Rectifier
Turn Signal
Givi Case
Here is the Pics
Nice looking mods. The handlebars look like they are the same width as the LSL Flat Track. I had to get a longer clutch cable but everything else worked with a little ingenuity.
Sent from my iPad using Tapatalk
LA-Liquid-T100 is offline
post #9 of 13 (permalink) Old 09-18-2019, 11:51 AM Thread Starter
Hello
I just remove it and replace with normal triumph one.
yermak is offline
post #10 of 13 (permalink) Old 09-18-2019, 12:01 PM Thread Starter
Not exactly but close .and i really need to add a brake line extension.
LSL
Dimensions: W: 835, H: 110, D: 185.
BAAK
Height : 176mm
Width : 796mm
Swipe / pullback : 159mm
yermak is offline
