Street Scrambler luggage conundrum resolved - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #1 of 18 (permalink) Old 08-06-2019, 03:16 PM Thread Starter
Gyp
Main Motorcycle: R1200R Sport
Other Motorcycle: Street Scrambler
Extra Motorcycle: R80RT
By using the simple technique of engaging my local welding magician to butcher two of the reduced-price graphite coloured top box racks and the Givi frames from my old Tiger 1050, I think I've solved the SS luggage problem.
As the resulting system is modular, I can use the topbox without side rails and keep the slimmer rugged pannier
Or (though not fitted for photos yet), as I bought a second Triumph top box rack and had that modded in the same way but with the back removed, I can have the panniers on without the top box mount
rc51owner and saddlebag like this.
Gyp is online now
post #2 of 18 (permalink) Old 08-06-2019, 05:07 PM
Main Motorcycle: Thruxton 900
Other Motorcycle: Thruxton 1200r
Extra Motorcycle: KTM Duke 390
Excellent work , I modified a givi rack to fit my Thruxton R and am very happy with the result . Far more satisfaction in doing something different . Ground clearance on right handers could prove interesting .
Hedgepig is online now
post #3 of 18 (permalink) Old 08-07-2019, 01:17 PM Thread Starter
Gyp
The other luggage configuration
Gyp is online now
post #4 of 18 (permalink) Old 08-14-2019, 12:16 PM
Newbie
Amazing set up Gyp! I've been looking all around the web for a similar set up as I'm planning a few long trips (2-up).
Could you post more details on the original Givi Frame and how much your welding magician had to modify it? Also how much $$$? Would he be willing to do another one?
I have the same bike in white and with fenders but with the V&H slip-on exhaust
lesceptique is offline
post #5 of 18 (permalink) Old 08-14-2019, 03:03 PM Thread Starter
Gyp
Funny you should mention the V&H slip on as I fitted one to mine this evening and the Givi setup no longer fits.
My Givi set up fitted my Tiger 1050 with the stock exhaust but not the Arrow slip on
My Givi set up fitted my R1200R with the stock exhaust but not with the Akrapovic slip on
My Givi set up fits my Street Scrambler but not with the Vance & Hines
What's it they say about people who repeat the same mistakes and expecting different results?
Anyway the current plan is stock exhaust for touring, V&H for rest of the time (similar to what I did on the Tiger 1050)
Back to the set up.
The main loops and the cross bar at the back are from the Tiger 1050 Givi rack that have been hanging up in my garage since I sold the bike 3 or 4 years ago. I also used two of the Triumph topbox mount kits as they were heavily reduced in the UK a while back (edit - A9758307 seems they still are reduced)
Those main loops are used as a base with the extraneous bits ground off.
The fabricator...
- widened and deepened the rear crossbar
- lengthened and reshaped the lower front limbs
- fabricated new top arms to mount to the top shock mounts*
- fabricated new top lugs (A) to mount to the Triumph topbox kit
- fabricated lugs on each top box kit to attach to the lugs on the main loop (A)
- shortened one of the top box kits to allow pannier only use
- fabricated an interface plate to bolt the Monokey plate to the top box kit in place of the Monolock one supplied
* I'd not expected him to do this as I was intending the top box mounting rack to take the load is it bolts to the chassis, but he was using the Triumph rugged pannier mount as a guide so copied that
Depending on how you look at it, the £££ was either eye-wateringly expensive or a bargain. Here goes -
Tiger 1050 rack - £free as it was going rusty in the garage
Givi panniers and top box - £free to me as they were also cluttering the garage
Fabrication work - £520
Stove enameling - £65
Triumph top box rack £39 x 2
End plugs for cut down rack - £2
Spacers for longer bolts at footrests - £3
Bolts for footrests and to position pillion seat/rack on top of rack mount - £6
That's a lot of £££, granted, but as I keep getting a pop up offering me a brilliant deal on Ducati luggage which is £1,900 for a pair of panniers and heated grips, for a totally bespoke build it doesn't seem extortionate. And less than the Fox shocks and V&H...
The quality of the work is impeccable.
If I were to do it again I'd leave off the bars to the top shock mount and stick with the Givi Monolock plate on the top box (using a different top box) and I that would keep the cost down a bit. Oh and I'd put the performance exhaust on first...
I'm sure he'd do another, but lead times can be long as his priority is building race cars (my job was paused so he could fabricate an exhaust mount for a 1962 Ferrari 250 GT SWB Breadvan worth about $23M...)
Gyp is online now
post #6 of 18 (permalink) Old 08-15-2019, 02:36 PM
Newbie
Thanks for the quick and detailed reply!
It doesn't seem that expensive when I compare it with commercial rack systems to be honest.
Right now my other options are:
a) tank bag + single side pannier + TEC luggage rack (I have it already).
b) Mosko Moto Reckless 80L System (700 USD + Shipping to EU). A guy did 9000 Km with this setup (photos from FB group below).
https://moskomoto.com/products/reckless-80l
ID:	652438   Click image for larger version
ID:	652440   Click image for larger version
saddlebag likes this.
post #7 of 18 (permalink) Old 08-15-2019, 03:18 PM Thread Starter
Gyp
The Mosko Moto Reckless 80L System looks good but I think you'd struggle to fit your pillion passenger on as well.
If you're not camping, the tank bag (10 litres) + side pannier (25 litres) + biggest givi Monokey (47 litres) isn't a bad compromise. OK, it's not quite the 132 litres of my combination (with room to strap to the top of the top box and panniers if need be, but it all depends on how much you intend to carry (obviously).
Gyp is online now
post #8 of 18 (permalink) Old 08-15-2019, 07:17 PM
Great ingenuity. I’m currently working on mounting a 45L Jesse odyssey on the back of my street scrambler using an old tv mount. It’s a big box, but I’m ATGATT, so I need a place to lock it while commuting.
Md9nyc is offline
post #9 of 18 (permalink) Old 08-16-2019, 02:41 AM Thread Starter
Gyp
Originally Posted by Md9nyc View Post
Great ingenuity. Iím currently working on mounting a 45L Jesse odyssey on the back of my street scrambler using an old tv mount. Itís a big box, but Iím ATGATT, so I need a place to lock it while commuting.
All of a sudden my set looks cheap!
If you are fitting a Jesse Odyssey, I'd have thought it was a simple
Bolt on the Triumph top box mounting bracket (cheap from Triumph UK at the moment)
Adjust the Jesse top box fitting kit to fit (line up, drill 4 holes)
Attach top box
Gyp is online now
post #10 of 18 (permalink) Old 08-17-2019, 03:54 PM
Main Motorcycle: '17 Street Scrambler
Other Motorcycle: '12 BMW R1200GSA - sold!
Nice work! Triumph not providing a set of good, 3 piece, hard luggage for the Street Scrambler and Scrambler 1200 is a serious oversight in my opinion. Ditto for the aftermarket vendors.
thorongil is offline
