Triumph Forum: Triumph Rat Motorcycle Forums (https://www.triumphrat.net/forum.php)
-   Water Cooled Twins Talk (https://www.triumphrat.net/water-cooled-twins-talk/)
-   -   Did The TEC Camshaft on my 2018 Street Twin (https://www.triumphrat.net/water-cooled-twins-talk/953254-did-the-tec-camshaft-on-my-2018-street-twin.html)
dakski 05-20-2019 10:01 PM
I had the TEC Camshaft upgrade installed on my 2018 Street Twin and picked her up today.
There's a 300 mile break in period so I cannot comment (yet) on the power gains over 5,000 RPM, where it really makes a difference. I can give my initial thoughts.
The bike sounds a little different and definitely pulls more easily. Surprise, surprise, she appears to breathing great and running smooth as can be. I did the K&N air filter at the same time, but imagine that's a nominal difference at best. Low-mid range, where she would bog a little if I didn't downshift, she pulls smoothly through now.
I will comment more as I put more miles on her and after she's broken in for sure.
The mechanic who did the work took pictures and documented the entire process for me. He will send them shortly and I can post some.
George at TEC was awesome to deal with and the part arrived on time and went in with no issues. He sells two camshafts for the street twin. One for early serial numbers and one for later models (which I have). There was no negative readings on the valves when the cam went in and the adjustments were pretty straight forward, according to the mechanic. I did send George my serial number to confirm which part I needed.
SquireSCA 05-22-2019 07:52 AM
Did you have to make any changes to fueling, and what did it cost for the mechanic to install the cam?
dakski 05-25-2019 12:06 AM
No changes to fueling. The mechanic quoted me 3-5 hours, and it took him 5 hours, plus ECU reset and a few other minor things. He charged me for 5 hours. My mechanic charges $100 an hour, so it was $500, plus some shims and miscellaneous parts. The total was $600 plus tax.
We reset the ECU to stock and as George said, it searched for a few minutes, realized the cam was there, and began running perfectly. It's as if it was meant for this engine.
dakski 05-25-2019 12:19 AM
3 Attachment(s)
WOW! 250 miles in with the new CAM.
George said keep it under high RPM's (5,000 or so was what I figured) for 200 miles. Then you can go crazy, but cruising, keep it under 5,000 RPM's for another 200 miles. After 500 total miles do an oil change.
It's a different bike. She pulls from 2,800-7,200 RPM's now quickly and smooth. The torque is definitely still there, and more of it, but it's above 5,000 RPM's that she's a completely different bike. No more running out of steam. She pulls hard all the way to redline.
When at about 3,300 RPM's, she's torque galore with instant response. Before, she would pull for a second and then start running out of air. Also, below 3,000 RPM's before, she was not happy, almost gasping. Now, she just pulls smoothly. I generally keep her about 3,000 RPM's +, but it was interesting to see her not get bogged down and just pull hard instead.
I had my buddy who works at the bike shop ride her. He was blown away. He says she pulls as hard or harder than 1200 now, especially higher up. He also says the reduced weight helps too. She's quick and light on her feet. He said he understands why they don't offer this in the 900's from the factory. No one would pay $3k more for a 1200 bonneville.
His main ride is a street triple, and the Street Twin, Cam or no Cam is not that. However, she's much quicker, much easier to ride, and if you drive a stock 900 after riding a modified cam one, it will feel like it's choking.
Right now she's making about 63HP and 60 F/T pounds at the wheel. That's up from 49HP at redline and about 53FT/lbs peak. However, the torque is much higher throughout the rev range and HP is dramatically higher after 5,000 RPM's.
If I do a cat-delete exhaust, like the rebel 2-1 that TEC sells, it will bump the power to 67HP at the wheel and 63 F/T pounds at the wheel. I may do that down the road, but for now, I am enjoying my "rocket." :)
Of note, my average fuel mileage went from 54.5mpg to 51.6 mpg. However, I might getting on her a little harder too. Either way, a small price to pay.
Below are a few pictures of the build.
SquireSCA 05-25-2019 08:57 AM
Very cool. I will likely do this with my dealer. They have done some cool builds for customers including a supercharged Thruxton R... 5 hours is not bad at all. I could probably save a few bucks if I just wait till the 10k mile valve check, as they will have to get in there anyway. Might as well have them install the cam and then set the valves and call it a day. Would have them do the X pipe at the same time, I already have the snorkel removed, K&N air filter and opened up the stock cans...
I am gonna go talk to them today and see if it makes sense to wait for the valve check or just pull the trigger and have them do it. That it doesn't need any fueling is awesome...
tsmgguy 05-25-2019 09:07 AM
Before and after dyno runs would have been great.
dakski 05-25-2019 09:08 AM
I don't think you will regret it.
George told me if you do exhaust, to have the dealer install the Vance & Hines ECU tune from Triumph. It runs richer than stock. He also sells a injector plug kit if you do not have access to the V&H tune, but any dealer should.
If you do not touch the exhaust, it's all good to run the stock ECU.
Also, in case you missed it, George sells two CAMs - one for earlier models and one for later models. Make sure you get him your serial number and get the right one.
Good luck and keep us posted!
dakski 05-25-2019 09:12 AM
I agree. Apparently, it's pretty documented what the stock bike makes.
When I am done with upgrades, I'll consider a dyno run. I didn't want to spend the money now. Seat of the pants - it's a lot more power, but more importantly, qualitatively, it's a much better ride.
I am getting the HP numbers from George's video on Derestricting the 900. I should have said that earlier, full disclosure.
ICON636 05-25-2019 09:53 AM
I've done about 1,600 miles since my TEC cam was installed. I've got the V&H high mount tune, Termignoni full exhaust, and air box snorkel removed with stock air filter. The bike works runs great and now pulls hard all the way to the rev limiter. I rode the bike 8,000 miles before the cam install and never hit the rev limiter once. There was just no since in revving it that high because it was done accelerating. Since the cam install I've hit it several times. I wouldn't call it a performance cam, but the bike has noticeably more performance than it did before. I'm eager to see how it matches up with my friends Ducati Scrambler Cafe Racer with Akrapovic and tune.
vitesse 05-25-2019 11:33 AM
Great BUT with 300cc more the 1200 is a much more powerful engine plus a 6th gear. Ride a Speed Twin and a Thruxton, they are in a different class. If this solves it for you that is all that matters.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
