BONNEVILLE T120 2016 sprocket - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 12 (permalink) Old 05-18-2019, 08:31 AM Thread Starter
Main Motorcycle: 2016 Bonneville T120
capecodcarl's Avatar
Other Motorcycle: 1972 Butaco Alpina
Extra Motorcycle: 1960 ?Harley Davidson 125
Lightbulb BONNEVILLE T120 2016 sprocket
Good day all, new to the site and hope my post goes somewhere ? Trying to gear down my 2016 Bonnie but can't seem to locate a 39T rear sprocket. I thought someone posted somewhere a Thruxton would fit ? Any help would be much appreciated . Thanks.
I once complained about my boots ,until I saw a man with no feet. Enjoy the ride !
capecodcarl is online now
post #2 of 12 (permalink) Old 05-18-2019, 09:35 AM
Main Motorcycle: 2007 BMW R1200GS Adv.
Hookalatch's Avatar
Other Motorcycle: 2018 T120
Extra Motorcycle: BMW Airhead sidecar
I got mine here http://www.pbisprockets.com/ Mine is a 40 tooth but they likely have 39 available too. Personally I wouldn't want anything small than 40 tooth and the bike still seems high geared with that. However, I rarely ride on interstates.
Chuck
Hookalatch is online now
post #3 of 12 (permalink) Old 05-18-2019, 01:40 PM
retjustdad53's Avatar
Other Motorcycle: 2016 Thrx R
The watercooled Thruxtons will fit your T120. You are currently running a 17FT and 37RT sprockets, that gearing is quite high at 2.1764 (37/17).
The Thruxtons run a 16FT and 42RT is a little low for most folks 2.625 (42/16). A lot of T120 owners are going with a 16FT with the stock 37RT a 2.3125. This would be slightly lower gearing than a 17FT and 39RT at 2.294 for better acceleration.
Remember when you talk gearing on the sprockets the higher the number i.e. 2.625 the lower the gearing is on the bike.
There some threads on the 39T rears out there if you still want to go that way..
retjustdad53 is online now
post #4 of 12 (permalink) Old 05-18-2019, 08:05 PM
Main Motorcycle: 2017 Street Twin
Raisch has 37, 40, & 42 steel sprockets.
https://www.classicbike-raisch.de/en...nsmition?c=202
ICON636 is offline
post #5 of 12 (permalink) Old 05-18-2019, 09:07 PM Thread Starter
Sprocket
Thanks all,hope this replies to all,I'm a bit of a computer illiterate ! Make that more than a bit.
ICON636 likes this.
post #6 of 12 (permalink) Old 05-19-2019, 04:03 AM
Newbie
Main Motorcycle: T120 Black
I put the thruxton 16T front sprocket on. Transformed the bike - just feels "right", as if that's how it should have been all along. Had to lose two links from chain.
Pinnelli is offline
post #7 of 12 (permalink) Old 05-20-2019, 04:07 AM
Main Motorcycle: Bonneville T120
gaeter's Avatar
I donít agree with changing the front sprocket to a smaller one. There are mathematical formulas to prove and explain why it wears off the sprocket and chain faster, but you donít need that.
After careful thought, I replaced the rear 37T sprocket with a 40T on my T120 / 2017 and Iím uttermost pleased with it. First gear is shorter, which helps a lot in town. It also permits to move the rear wheel a bit more frontwards. Originally, the position is very rearwards and doesnít give much possibilities to correct the chainís tension.
Always replace front and rear sprockets + chain at the same time.
gaeter is offline
post #8 of 12 (permalink) Old 05-20-2019, 08:08 PM Thread Starter
Thanks again all!
post #9 of 12 (permalink) Old 05-21-2019, 02:37 PM
BamaGuru's Avatar
I switched from a 37T rear sprocket to a 39T. Simple change but made a big difference. I like it much better and would recommend it to any T120 owner.
BamaGuru is offline
post #10 of 12 (permalink) Old 05-21-2019, 05:44 PM
Which is better for slow riding on a T120 on gravel and light trails, stock or 39T?
redamo is offline
2016 Street Twin and T120 Recall SteveMKentucky Club Cafe' 0 04-11-2016 08:16 PM
Seeking subjective advice on trading in a 2015 Bonneville SE for a 2016 Street Twin Scrambler900 Air Cooled Twins Talk 94 02-29-2016 07:04 PM
