How to secure T120 to Single Bike trailer - Triumph Forum: Triumph Rat Motorcycle Forums
 15Likes
post #1 of 23 (permalink) Old 05-15-2019, 05:39 AM Thread Starter
Main Motorcycle: T120 Black
Other Motorcycle: Tiger 800
Extra Motorcycle: Street Triple R
Question How to secure T120 to Single Bike trailer
I'm soon picking up a 2016 Bonneville T120 that i've just purchased and I'm looking for advice on How to secure it to Single Bike trailer for safe transportation
I was going to ride it back but I've decided to use my single bike trailer instead.
I'm old and I worry a little so any safe loading & securing tips like 'where to put the ties downs so they don't come loose if the bike bounces a little' would be greatly appreciated.
Thanks in advance have a good one safe riding
Nixey is offline
post #2 of 23 (permalink) Old 05-15-2019, 09:12 AM
joeschmoe's Avatar
I used to do this exact thing for a shop, so I can be of some help. I think. Hahaha!
What I would do is to take a ratcheting strap on each side of the lower triple tree to a corner of the trailer (or rail/tie down point). Make sure to put a good amount of tension on the front suspension/straps so it won’t go anywhere.
As for the rear, i’d go around the portion of your frame that has the mounts for the exhaust cans or the bottom shock mounting point on the swing arm.
Hope this helps.
Nixey likes this.
- Joe
joeschmoe is offline
post #3 of 23 (permalink) Old 05-15-2019, 09:58 AM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
Don't compress the forks more than a third of the travel. Depending upon how long on the road this trip will take, check the tension of the straps every hour or so. if a short distance, don't bother. Does this trailer have a front wheel chock or stop on it to keep the bike from moving forward? Maybe put the bike in gear while transporting. I've only used a pickup to transport bikes.
Nixey likes this.
Felony is offline
post #4 of 23 (permalink) Old 05-15-2019, 10:39 AM
Main Motorcycle: Thruxton R
The best method of tie down are canyon straps. They don't run the risk of scratching bars or controls and they provide the best tie down security due to the way they pull on opposite side bars. Check em out.
http://www.canyondancer.com/originalbarharness
Nixey likes this.
69Bronze is offline
post #5 of 23 (permalink) Old 05-15-2019, 02:34 PM
Main Motorcycle: 2018 Speedmaster
oldroadie's Avatar
This is good advice. Use ratchet straps for each corner, a fifth can secure the front wheel to the front of the trailer in lieu of a chock. I havenít ever put my bike in gear so I canít say if that effective. Itís far easier if you have a friend help you steady the bike, especially when de-trailering because itís just too easy to drop the bike removing the straps...I might have seen that before.
Nixey likes this.
2006 Scrambler
1974 BMW R90 sidecar rig
2001 BMW R1100RT
oldroadie is offline
post #6 of 23 (permalink) Old 05-16-2019, 04:47 AM Thread Starter
It's a purpose built wide axle single bike trailer with a very substantial front wheel location loop.
I've seen some that say tie down and compress the suspension while some say tie it below the suspension so the bike can move on it's suspension.
I guess the main thing is to check the straps before I get onto the motorway and try to keep my speed down to 60mph
A 2nd Class Shag is far Better than a 1st Class Wank
Nixey is offline
post #7 of 23 (permalink) Old 05-16-2019, 08:54 AM
I don't agree with letting the suspension move around. If you do, the straps will become loose easier and when the suspension compresses, the straps at that point will become loose. There will of course be some movement, but you want to minimize any large movement. You want to have the same force on the straps from one side to the other and front to back to keep the bike from listing to one side.
vistavette likes this.
Felony is offline
post #8 of 23 (permalink) Old 05-16-2019, 09:18 AM
triumph900's Avatar
Other Motorcycle: 2016 Speedmaster
Extra Motorcycle: 2014 Bonneville
I use 2 soft hooks wrapped around the fork just above the lower clamp. Then ratchet straps to secure. I compress the forks fairly tight, but not all the way. I then grab the handlebar and shake. If the trailer moves with the bike, youíre ok! Iíve done this with no problems for over 25 years.
Nixey likes this.
triumph900 is offline
post #9 of 23 (permalink) Old 05-16-2019, 09:33 AM
Main Motorcycle: 2009 Bonneville
Flash Nick's Avatar
Other Motorcycle: Kawasaki Super Sherpa
I have to respectfully disagree. That loop is not adequate for a 220 kg bike, it already looks bent.
I'd rather have the suspension compressed than have my bike flopping around at highway speed, however on this trailer you can't compress the front suspension because there are no anchor points forward of the front axle.
Flash Nick is offline
post #10 of 23 (permalink) Old 05-16-2019, 10:17 AM Thread Starter
The metal loop that the tyre pulls up to is not bent that's the way it is. It's only to stop the bike rolling forward. It's had a new Triumph rocket on it many times whilst traveling to shows.
Nixey is offline
T120 Front/Rear Brake Upgrade shrini23 Water Cooled Twins Talk 22 05-17-2018 10:24 PM
Thoughts on T120, StreetCup and T100 Sjeupie Water Cooled Twins Talk 41 05-12-2018 04:04 PM
T120 single seat and rack Brewers Whoop Water Cooled Twins Talk 3 04-06-2018 03:08 PM
Can You Tour On A T120? richreed701 Water Cooled Twins Talk 183 09-22-2017 11:34 AM
Triumph Reborn Tour Ė Some Notes from 12/03/15 grebmrof Air Cooled Twins Talk 62 12-16-2015 10:39 AM
