Adaptations reset effect - Triumph Forum: Triumph Rat Motorcycle Forums
 1Likes
post #1 of 22 (permalink) Old 05-14-2019, 06:44 PM Thread Starter
Does anyone know why is my bike (T120) running way better after the adaptations are reset? I am not talking slightly but night and day, no throttle snatch, no hesitation, smooth as butter. Then after a few hundred miles, all goes down the drain? Is there a way of "locking" the ECU as not to use these adaptations? In the end, what exactly are these?
redamo is offline
post #2 of 22 (permalink) Old 05-14-2019, 07:38 PM
Dougl1000's Avatar
How did you reset the adaptations? I thought it was locked to doing anything except reading sensors. The ecu will adapt to ambient temperature and pressure after riding it. If you were able to reset adaptations to the factory defaults using software, the next step would be to let it idle for 12 min after the fan comes on. This would adapt to local ambient conditions. After a while, the O2 sensors tend to lean it out in closed loop. You may be feeling this.
Dougl1000 is online now
post #3 of 22 (permalink) Old 05-15-2019, 04:51 AM
Main Motorcycle: Thruxton R
Tricolour's Avatar
Other Motorcycle: Bimota DB9S
Extra Motorcycle: Morini Corsaro
Until the fan comes on is all that is required I would never run it for another 12 minutes.
The ECU is adapting to a riding style?
Time to wind it up?
bluesforchallah likes this.
Tricolour is offline
post #4 of 22 (permalink) Old 05-15-2019, 09:33 AM
joeschmoe's Avatar
I once saw a document directly from Triumph; can’t remember if it was from the service manual or elsewhere.
I know it said that you start it without touching the throttle and allow it idle until the fan comes on, then allow it to idle a further 12 minutes. Then shut off the throttle and you’re good to go.
There was/is a PDF somewhere on this forum that had this info. I’d even like it to see it again if someone know the location of this document.
- Joe
joeschmoe is offline
post #5 of 22 (permalink) Old 05-15-2019, 10:58 AM
Dougl1000's Avatar
Time to wind it up?
It will adapt if you let it run for 12 min. The 12 min tune is a real thing.
https://www.triumphrat.net/the-rocke...#/topics/12120
The instructions for loading a tune with TuneECU were to load the tune, reset the adaptations, and do the 12-min tune. I loaded a lot of tunes into my Rocket with Tuneboy without letting it idle for 12 minutes because it will adapt as you ride it. Waiting for the fan to come on doesn’t do anything. I didn’t say it would adapt to riding style. It adapts to ambient pressure and temperature. What does “time to wind it up mean”?
post #6 of 22 (permalink) Old 05-15-2019, 12:51 PM Thread Starter
The bike ran almost perfect like 200-300 miles after the adaptations were reset and then it started doing the snatchy/jerky throttle again. Keep on resetting the adaptations every few days sounds stupid to me...
redamo is offline
post #7 of 22 (permalink) Old 05-15-2019, 03:05 PM
Dougl1000's Avatar
I always have the snatchy jerky thing, mainly at the top of 1st. How did you do the reset adaptation?
post #8 of 22 (permalink) Old 05-15-2019, 09:09 PM
Tricolour's Avatar
I can't understand why an 'adaptation' at idle (in closed loop) for 12 minutes after the cooling fan comes on has anything to do with a snatchy, jerky thing mainly at the top of first.
When a change is made to an exhaust (for example) the ECU will adapt the closed loop correction over time when at idle but this adaptation is not in the open loop area and I don't believe the ECU can adapt much in open loop at wot.
wind it up - forget the idle closed loop adaptation and just ride it hard.
post #9 of 22 (permalink) Old 05-15-2019, 10:54 PM
Dougl1000's Avatar
I agree.
post #10 of 22 (permalink) Old 05-16-2019, 04:33 PM Thread Starter
Strange thing is not all T120 have the "snatchiness" which is weird. Or maybe people are not that bothered and get used to it. Whilst there have been numerous solutions suggested (decat, booster plug, power commander, o2 delete) I wonder how effective are they in the long run? I wonder if the ECU will not always try to "adapt" and basically be continuously fighting back these changes. I guess one solution would be to have a Bluetooth dongle always on and just reset adaptations using the TuneECU app before each ride... Used to be quite happy with my T120 but this is driving me nuts to the point of thinking to part exchange it against an R NineT.
redamo is offline
Sagem TPS Reset Procedure KitNYC ECM and FI Tuning - Help, Tips & Tricks 5 06-21-2019 04:08 AM
Tuneecu Reset Adaptations Question Finnegans Air Cooled Twins Technical Talk 9 08-07-2014 10:07 AM
TuneECU TPS reset question IJP Air Cooled Twins Technical Talk 1 07-31-2013 03:28 AM
Reset Adaption / TPS Reset warnzie Air Cooled Twins Technical Talk 1 06-24-2013 07:55 AM
TPS Reset Kills Bike KitNYC ECM and FI Tuning - Help, Tips & Tricks 2 06-02-2013 08:50 AM
