T100 Luggage Rack Options... - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 18 (permalink) Old 05-13-2018, 10:29 AM Thread Starter
Main Motorcycle: Yamaha Super Ténéré
Other Motorcycle: Moto Guzzi V7II Stornello
It's not like I haven't used Professor Google...and I've read the T120 luggage thread...but I can't seem to find luggage racks for my 2017 T100 Black that are black, and clearly fit.
Union Garage has a set, but looks like they only fit 2016 and prior years: http://uniongaragenyc.com/shop/motor...mph-bonneville
I've tried the US Triumph site, and they only show chrome and say "see your dealer": https://shop.triumphmotorcycles.com/...Rail_Kit,_Left
Plenty of Chinese one-offs on Ebay, but would rather avoid crap: https://www.ebay.com/itm/Black-Saddl....c100005.m1851
Any ideas? I suppose I can order through my dealer, but then they actually make you schlep there to pick them up. Rather just order and have delivered to install myself at home.
While we're at it, I'm planning on installing a pair of these. I have a Kriega tailbag and it's excellent. Any experience with their saddle bags? https://kriega.us/duo-28 (photos from Kriega's site)
JRider9 is offline
post #2 of 18 (permalink) Old 05-13-2018, 12:26 PM
Main Motorcycle: Triumph Bonneville T100
DesertBum's Avatar
Other Motorcycle: Prev. TigerXCX, Tiger abs
I have a Rentec on my 2017 T100. While mine is chrome they make it in black as well. If you want to do a Tail Tidy, though, your options are much more limited, though I managed to make a TEC one fit with my Rentec rack. I got my rack from NewBonnevile.com
https://newbonneville.com/shop/rennt...d-street-twin/
DesertBum is offline
post #3 of 18 (permalink) Old 05-13-2018, 09:51 PM Thread Starter
Not sure that Rentech is for saddlebags tho...
I can't be the only 2017 T100 rider looking to mount side bags. Or am I?
JRider9 is offline
post #4 of 18 (permalink) Old 05-14-2018, 12:46 AM
DesertBum's Avatar
OK, I missread your original post. I also have luggage mounted and went through he same frustration. The Kriega bags you show are saddlebags, i.e. they have straps connecting the two sides so they can be 'thrown' over (or under) the seat and the frame carries most of the weight directly. All you need is frames to hold the bags away from the wheels, essentially ones like Triumph's. I got mine off eBay. I'm attaching three photos of my bike. The first (not sure if they'll show in the correct order) is fully loaded (road quite well), the second unloaded that show the side 'racks', and a third that zooms. The one I ordered off fleabay included a short (3") bar with a hole at each end, for mounting between the bottom lug of the rack and the rear foot peg. That pushes the upper tube of the rack into a more horirzontal position. However I didn't like the final position of the rack so I fabricated my own extension bar (about 4 1/2") out of 1/8" x 1" aluminum bar (from TrueValue or the like). I then powder coated it black so it matched everything else. If you look very closely at the bottom picture you can see it, though with everything black it's tough to see. Using this technique you can make almost any similar design rack fit. Regardless I'd look for one from as late as possible.
The only true 'racks' I know of for the late model T100s are the Hepco-Beckers https://www.motomachines.com/Hepco-B...kaAmbBEALw_wcB.
Givi and a few others make something but they're really pretty wimpy compared to the dual-sport racks or the Hepco-Becker.
ID:	602105   Click image for larger version
post #5 of 18 (permalink) Old 05-14-2018, 02:36 AM
Dougl1000's Avatar
The Triumph mounting rack looks like chit and all it lets you do is mount throwover bags. if you wanted to put real motorcycle bags on, there are Easy Brackets. You bolt the bracket onto the back of the bag then mount the bracket onto the rail they supply. Quickly detachable. The mounting rail is black:
http://www.greatbikegear.com/index.p...result/?q=T100
Then there is Longride.be
http://longride.be/bag/mounting-brac...bonneville/190
This hardware allows you to use their quick lock system. Not sure if the have the bracket in black. If they sell the quick lock piece by itself, you could mount it to a non Longride bag.
Dougl1000 is online now
post #6 of 18 (permalink) Old 05-14-2018, 11:31 AM
DesertBum's Avatar
I agree with you on the appearance of the Triumph racks, but you missed the OP has a 2017. Triumph changed the location of the rear rack mounting lugs that year so earlier versions won't fit. It's the two per side threaded mounts by the seat latch that have changed, probably when they went to a locking latch mechanism. Thus the first one you list clearly won't fit and the second one is unlikely to. I spent a lot of money and returned a lot of products before I finally learned that. That's the dilemma for us with 2017 and later bikes - nothing really nice fits!
post #7 of 18 (permalink) Old 05-14-2018, 01:23 PM
Main Motorcycle: 2017 Street Twin 900
Originally Posted by DesertBum View Post
I agree with you on the appearance of the Triumph racks...
The racks they linked to were not an improvement in the looks department, either.
Delta is offline
post #8 of 18 (permalink) Old 05-14-2018, 02:09 PM
Main Motorcycle: 2017 T120
artpongs's Avatar
Other Motorcycle: 1998 VFR800
Extra Motorcycle: 1990 Hawk GT
https://www.motomachines.com/Hepco-B...8aAgYhEALw_wcB
I see SW-Motech and Givi have their versions as well
artpongs is offline
post #9 of 18 (permalink) Old 05-14-2018, 03:19 PM
Main Motorcycle: T120
Dudley65's Avatar
I fitted the Triumph top box rack this weekend and fitted my old Givi Top box rack with 4 spacers and it works a treat. I have the chrome one but Triumph do it in black as well.
I recon you could get the Givi pannier rack to fit as they seem to use 'U' bolts around the rack tubes. I know mines a T120 but should work the same, I did quite a lot of research before I brought mine. I don't like the way the Black plastic rack wobble when they have a box on top.
https://www.motorcycleplanet.co.uk/p...lle-t100-2017/
Dudley65 is online now
post #10 of 18 (permalink) Old 05-15-2018, 07:01 AM Thread Starter
All super helpful, but Desertbum, you clearly get the 2017 dilemma! (And you like to treat your bike like a pack mule, too).
Given the limited options, I’m calling the dealer today and will likely just bite the bullet and have them order the OEM Triumph ones. I assume they’ll have black ones that fit the 2017. Will report back with pictures.
JRider9 is offline
Luggage for T100 rear rack StratfordJohn Water Cooled Twins Talk 20 01-23-2018 06:55 AM
T100 Luggage rack woes AlexB5892 Air Cooled Twins Talk 3 12-03-2017 11:18 AM
