catalytic converter can be permanently damaged... - Triumph Forum: Triumph Rat Motorcycle Forums
 24Likes
post #1 of 17 (permalink) Old 03-25-2018, 10:04 PM Thread Starter
Main Motorcycle: 2017 T120 Black
Question catalytic converter can be permanently damaged...
"In addition, the catalytic converter can be permanently damaged if the motorcycle is allowed to run out of fuel or if the fuel level is allowed to get very low. Always make sure you have adequate fuel for your journey."
After reading this in the Owner's Handbook (pg 50), how is running out or low of gas going to damage the catalytic converter?
macunix is offline
post #2 of 17 (permalink) Old 03-25-2018, 10:29 PM
Main Motorcycle: '17 Bonneville T100
Kris_01's Avatar
It shouldn't. That's crazy. Run out of gas and the engine will die. The end.
runnerhiker likes this.
Kris
Kris_01 is offline
post #3 of 17 (permalink) Old 03-25-2018, 11:13 PM
Main Motorcycle: '17 Thrux R
steve betts's Avatar
Other Motorcycle: '02 Bonnie (set free)
How do you not occasionally get very low with a 3 gallon tank?
JFM likes this.
NRC FEK, Pazzo levers, CRG lanesplitter mirrors, BC blinkers, Rizoma reservoir, DID gold chain.
steve betts is online now
post #4 of 17 (permalink) Old 03-26-2018, 02:15 AM Thread Starter
The fuel pump could momentarily draw air causing the engine to experience a sporadic misfire condition resulting in possible damage to the catalytic converter.
macunix is offline
post #5 of 17 (permalink) Old 03-26-2018, 03:53 AM
Main Motorcycle: Street Twin
Other Motorcycle: Kymco 300i
Yes a misfire might damage the catalytic converter or get it even hotter than usual to the point of melting the internals, but who would ever know? I would be more worried about the fuel pump running dry and suffering damage through lack of lubrication. The alarmists that write the manual have a mindset that says every potential mishap should be blamed on the owner even if that means being imaginative and economical on technical accuracy.
Forchetto and BSA BIKER like this.
STroadster is offline
post #6 of 17 (permalink) Old 03-26-2018, 10:16 AM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
The catalytic converter will also be seriously damaged if you remove it, replace it with an X-pipe, and then throw the cat as far as you can, over the back fence and into the neighbor's yard.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #7 of 17 (permalink) Old 03-26-2018, 10:40 AM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
I was wondering what all these metal parts strewn all over my yard were. Thought they fell from the sky from passing jet liners.
Felony is offline
post #8 of 17 (permalink) Old 03-26-2018, 08:03 PM
tsmgguy's Avatar
Hi, neighbor!
JFM likes this.
tsmgguy is offline
post #9 of 17 (permalink) Old 03-26-2018, 08:13 PM
Kris_01's Avatar
Nah, if the pump sucks air, the engine has no fuel to burn and can't really cause any damage if the engine just bogs. I've never killed an engine through fuel starvation but I imagine you probably wouldn't run it that low anyway.
Kris
Kris_01 is offline
post #10 of 17 (permalink) Old 03-26-2018, 08:24 PM
Main Motorcycle: Triumph Bonneville T100
DesertBum's Avatar
Other Motorcycle: Prev. TigerXCX, Tiger abs
I highly recommend this method of damaging the cat!!!
DesertBum is offline
Gasket too thick for G clamp on Catalytic converter Singlin Water Cooled Twins Technical Talk 6 02-14-2018 06:28 PM
Catalytic Converter question Jedclampet Street Triple Forum 4 01-24-2018 10:21 AM
Will it damage the motorcycle to remove the catalytic converter? Striplewebb Maintenance & Workshop Talk 1 11-06-2015 11:24 AM
Removing catalytic converter on Tiger 800 ABS dwhite4893 Tiger 800 - 800XC Mods & Workshop 7 07-30-2015 10:24 AM
