Won't Shift? - Triumph Forum: Triumph Rat Motorcycle Forums
 23Likes
post #1 of 58 (permalink) Old 02-18-2018, 10:04 AM Thread Starter
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
Won't Shift?
Didn't get very far this morning before suddenly noticing that my T120's transmission would shift up, but not down. Rode the bike home in 6th gear with some careful clutch slipping. The gear indicator confirms 6th. The clutch appears to function normally. When trying to downshift, the shift lever moves and stops, but it seems to move too easily and no lower gear is selected. The bike has never been dropped. No work has been done to the shifter or transmission. I never "drop" a clutch, or otherwise abuse a transmission. Anyone else have a problem like this one? Sure glad the bike is still under warranty.
Thanks!
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #2 of 58 (permalink) Old 02-18-2018, 10:33 AM
Main Motorcycle: 2018 Bonneville T120
Blusideupp's Avatar
Other Motorcycle: 2018 Speedmaster
Sorry to hear about your problem. Odd. Keep us informed as to what you find out.
Blusideupp is online now
post #3 of 58 (permalink) Old 02-18-2018, 02:38 PM
Main Motorcycle: T100 LC
Simon64ds's Avatar
Other Motorcycle: Street Triple R
I suspect youíre right. What a bummer! Can that be accessed without a complete strip down?
Simon64ds is offline
post #4 of 58 (permalink) Old 02-18-2018, 03:05 PM Thread Starter
tsmgguy's Avatar
Originally Posted by Simon64ds View Post
I suspect you’re right. What a bummer! Can that be accessed without a complete strip down?
Good question! I suspect that enough access will be obtained by removing only the left side cover, but don't know for sure. The good news is that the shifting drum and forks are probably undamaged.
Simon64ds likes this.
tsmgguy is offline
post #5 of 58 (permalink) Old 02-18-2018, 05:34 PM
Simon64ds's Avatar
Fingers crossed itís not too much of a pain for you. You did well to get it home in 6th, thatís one very flexible engine. Good luck.
tsmgguy likes this.
post #6 of 58 (permalink) Old 02-19-2018, 11:31 AM
Main Motorcycle: 2017 Street Twin 900
Could it have been dropped while parked, and then picked back up again, without you noticing it? That would be my guess.
Delta is offline
post #7 of 58 (permalink) Old 02-19-2018, 12:24 PM Thread Starter
tsmgguy's Avatar
It was shifting perfectly, and then not at all, without being parked in an interim. Seems odd to me, too.
tsmgguy is offline
post #8 of 58 (permalink) Old 02-19-2018, 01:11 PM
Main Motorcycle: '09 T100 EFi
lambroving's Avatar
Other Motorcycle: Monster 796 ABS "Pantah"
Extra Motorcycle: K100RS 16/ABS
Dumb, ignorant question. Is there some kind of return spring which might have broken?
'09 T-100 Forest Green / New England White, TORs, Intiminators & fork tubes raised 15mm, Chrome Ikon 7610 - SP8 Shocks, Custom Sargent Saddle, OEM Chrome Grab Rail, Conti Road Attack 2 EVO's 110/80VR19 & 150/70VR17, 7" Cibie lens and uprated H4 bulb.
lambroving is online now
post #9 of 58 (permalink) Old 02-19-2018, 01:27 PM
So it happened mid-ride, that is very strange.
If the shift lever linkage is intact (sounds like it is since it has the same travel) then it is likely an issue with one of the parts in the internal gear selector assembly.
Glad to hear it is under warranty, let us know what they find!
Delta is offline
post #10 of 58 (permalink) Old 02-19-2018, 03:30 PM Thread Starter
tsmgguy's Avatar
That's my thought, too. Maybe part #28 below, the shifter detent arm return spring? Looks like the spring keeps the arm (#25) against the shifter detent, part #4. After each shift, the detent should engage in preparation for the next gear shift. If the spring is broken and detent spins but won't engage, then it would seem that the shifter shaft would in turn not be able to rotate the shifter drum, part #1. I think part #20 is the shifter return spring, which seems to be OK.
lambroving likes this.
tsmgguy is offline
Sheared shift linkage bolt - Thruxton R Breadbeard Water Cooled Twins Technical Talk 50 09-16-2017 07:31 PM
05-09 Sprint ST1050 Shift Situation Buellsmithe Sprint Forum 4 05-11-2017 10:51 AM
Dropped 2013 Thruxton - Bent Gear Shift Lever cheezay Air Cooled Twins Technical Talk 3 09-01-2016 10:26 AM
Motone adjustable shift lever foxj Air Cooled Twins Talk 25 01-20-2016 06:10 AM
2011 Sprint GT Hard Down shift OrthoRider Sprint Forum 29 05-18-2015 12:50 PM
