T120 Head Shake, Who has it? - Triumph Forum: Triumph Rat Motorcycle Forums
 12Likes
post #1 of 85 (permalink) Old 12-15-2017, 09:07 PM Thread Starter
Main Motorcycle: 2017 Triumph T120
Motard-Menace's Avatar
Wanted to see who else might be encountering head shake on their T120. I have a 2017 T120 and have a noticeable head shake from about 54mph down to 45-46 mph. If I remove my hands from the bars it will get violent to the point of going into a tank slapper essentially. I know ride with your hands on the bars, but the problem is it is still noticeable when you have your hands on the bars and just does not seem right. I was at the dealership today and they checked, spokes, steering stem, tire pressure etc. and basically told me to live with it or maybe get a stabilizer if I am that worried about it. I have ridden numerous bikes and numerous miles and have never had this issue on any of them at 55 mph. Of course at super high speeds I have seen this on other rides, but 55mph is like the speed I am constantly in around town. Anyway wanted to see if anyone else has had this issue and if you figured it out. Maybe its my tires? (Not pressure or anything, just the make/model) Any help would be appreciated.
Motard-Menace is offline
post #2 of 85 (permalink) Old 12-15-2017, 10:09 PM
Main Motorcycle: 2007 T100
Dave NEO's Avatar
Other Motorcycle: 1972 T100R 500 Daytona
tires or road...anything special? My vintage ride gets really squirrely on those grooved surfaces on bridges..but that is tires. My '07 t-100 is smooth in range you mentioned.. Good luck.
Man skall lyssna när en gammal hund skäller.
One should listen when an old dog barks.
~ Swedish proverb
Dave NEO is offline
post #3 of 85 (permalink) Old 12-16-2017, 12:20 AM
Main Motorcycle: 2017 T120 Black
I haven’t noticed any issues. How many miles? Hit any curbs or potholes? If you have access to a dial gauge, check the runout. Sounds like a bad wheel. Did this just start happening? When did you first notice the issue? How long have you had the bike? Buy it new off the showroom floor? Keep us posted
macunix is offline
post #4 of 85 (permalink) Old 12-16-2017, 07:55 AM
Main Motorcycle: 2016 Triump Thruxton
saddlebag's Avatar
Other Motorcycle: 2015 Kawasaki Versys 1000
Your tires are just worn. A new set will fix it. Until then, ride with your hands on the bars.
saddlebag is offline
post #5 of 85 (permalink) Old 12-16-2017, 08:50 AM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
No problems here.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is offline
post #6 of 85 (permalink) Old 12-16-2017, 09:09 AM
Main Motorcycle: 2017 Speed Triple R
Farwalker's Avatar
Other Motorcycle: 2017 Bonneville T-120
I have about 6,000 miles on my 2017 T120 never experienced head shake like you describe at any speed.
I put 32 lbs of pressure in the front tire (36 rear). I only got about 3,000 miles out of my front tire (original equipment).
"When plunder becomes a way of life for a group of men living together in society, they create for themselves in the course of time a legal system that authorizes it and a moral code that justifies it."
Frederic Bastiat
Farwalker is offline
post #7 of 85 (permalink) Old 12-16-2017, 10:58 AM
Main Motorcycle: 2018 T120
ECT120's Avatar
No shake on mine either. I'm guessing tires and/or tire balance. I had a lot of issues with a tire on my 01 BMW R1150GS. Rocky Mountain ATV installed it and used dynabeads to balance. I headed down the road and immediately took it back. They replaced the tire and the same thing happened. I road on it shaking for 300 miles and stopped at an authorized RMATV dealer and had them removed the beads and balance the wheels with weights. No more shake!
Beads work for some people but my experience has not been positive.
Get your wheel balanced.
ECT120 is offline
post #8 of 85 (permalink) Old 12-16-2017, 11:24 AM
2Wheels1Carl's Avatar
Have to agree, this is a tire problem or wheel balance problem, not a bike geometry problem.
I had issues with the OEM tires on grooved pavement (it’s everywhere here in SoCal) so I swapped out the factory rubber for a set of Pirelli Scorpion Trail II tires (at around only 500 miles on the odometer) and couldn’t be happier. They look more modern and perform great on all kinds of crappy pavement.
2Wheels1Carl is offline
post #9 of 85 (permalink) Old 12-16-2017, 01:25 PM
Main Motorcycle: 2016 Bonnevile T120
I haven't experienced any handling or control issues with my '16 T120. Nothing but goodness from my perspective. Check you tires for wear or balance.
Seachild is offline
post #10 of 85 (permalink) Old 12-16-2017, 03:18 PM
Main Motorcycle: 2016 T120 Bonneville
Soulkicker's Avatar
Other Motorcycle: 1977 KZ1000A
I have around 5500 miles on my T120 and it has been doing the hands off head shake at those speeds for the last 1000-1500 miles.
I think it's the front or rear tire wear also.
I'm also using 32lb Front and 36lbs Rear air pressure.
Mine are actually wearing very very well and look like they will go to about +7000 miles, even using real legal tread depth measurements.
Unfortunately, the mild head shake bugs me too, so I bet I'll be doing two new tires next late spring early summer.
And they won't be these factory Pirelli tires if the consensus is, it's a tire issue.
Soulkicker is offline
2016 Triumph T120 Vs. Indian Scout u6crash Biker Hang-Out 51 09-05-2017 08:48 AM
Oil inside a center head bolt nut? Code Man Classic, Vintage & Veteran 8 04-09-2017 12:53 PM
T120 thoughts and some drama RustySam Water Cooled Twins Talk 23 05-01-2016 06:02 PM
Thors Hammers trapped in 955i Tiger Head mickw555 Tiger's 885i & 955i - Mods & Workshop 3 04-22-2016 01:33 AM
Another New T120 Owner upstateTrophy Water Cooled Twins Talk 7 04-14-2016 01:28 PM
