T120 Front/Rear Brake Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
LinkBack Thread Tools
Old 08-04-2016, 12:19 PM Thread Starter
Main Motorcycle: H-D Rocker
Other Motorcycle: EXplorer XC
Hi guys
General question for Bonnie owners of either T120 or T100
When I looked at Triumph website T120 & T100 same share brake features
BRAKES FRONT
Single 310mm disc,Nissin 2-piston floating caliper
BRAKES REAR
Single 255mm disc,Nissin 2-piston floating caliper
I searched Triumph Performance Parts in Australia and they offer Brembo calipers upgrade 4-Piston Kit as a whole Plug and Play kit for T100.
Can anyguys suggest since the stock brakes are same between T100 & T120 so will this aftermarket fit onto a T120?
http://triumphperformanceparts.com.a...-kit-with-disk
http://triumphperformanceparts.com.a...riumph-classic
shrini23 is offline
Old 08-04-2016, 02:12 PM
Main Motorcycle: 2016 T120
T120 has dual front rotors. T100 single. Dunno if it's the same calipers.
Paul Skelton is offline
Old 08-04-2016, 05:06 PM
Main Motorcycle: 2013 Scrambler
Ben 1022's Avatar
Other Motorcycle: None as yet.
All the reviews of the new T120 I've seen, have said the brakes are good. I would suggest, if you haven't already done so, taking one for a spin and see if you think the brakes actually need an upgrade.
“All human wisdom is contained in these two words - Wait and Hope” - Some famous dumb ass.
Ben 1022 is offline
Old 08-04-2016, 06:24 PM
Main Motorcycle: 2016 Thruxton R
VaderSS's Avatar
Other Motorcycle: 2008 Honda GL1800
Extra Motorcycle: 2007 BMW F650GS
According to BikeBandit, the T120 / Thruxton S has the same front left hand caliper mounting bracket as the Thruxton 900, so I'd expect the front kit above to fit, but it only has the left side. You would need to find the other side caliper and mount as well.
Bikebandit shows a very different looking rear caliper carrier for the Thruxton 900 and the T120.
Personally, I'd break in the OEM set before looking at upgrades. If I wasn't happy with them after that, I'd try some HH pads.
According to EBC, the T120 / Thruxton S has the same pads as the Thruxton 900.
I'm guessing the stock Thruxton pads are of a compound similar to HH as they have similar bite to the HH pads on my F650GS.
Seeing the cost of those brakes makes me even more certain that the extra $2k for the Truxton R is well worth it over a Thruxton S.
If you think education is expensive, just wait until you see the cost of ignorance...
VaderSS is offline
Old 08-04-2016, 06:28 PM
I was in an accident with my t120 a few weeks back. The abs on the brakes seemed to work great. It kept me straight and upright and it seemed like I stopped pretty damned fast. However... If I had upgraded brakes perhaps I could have stopped in 20 feet instead of 25 feet and saved the bike.
Old 08-04-2016, 06:34 PM
Main Motorcycle: 2013 MG Stelvio NTX
Other Motorcycle: 2016 Bonneville T120
Extra Motorcycle: 2002 Speed Triple
I agree, after the pads bed in on my T120 I have NO complaints about the brakes on this bike, and I have 3 other bikes with Brembos to compare it to.
If you want more initial bite you can change the pads to a HH compound but quite honestly, I feel no need to, they stop quite good stock once things have bed in.
During the first 50 miles or so I was thinking "maybe I'll need to upgrade the pads"... then around 150 miles or so they seated and since then I'm a happy camper.
They are a HUGE improvement over the earlier T100 brakes, night n day.
16 Bonnie T120
13 Moto Guzzi Stelvio NTX
09 Ducati Sport Classic
02 Speed Triple
13 Husky TR650
danketchpel is offline
Old 08-04-2016, 06:42 PM
VaderSS's Avatar
I doubt that upgraded brakes would give you that kind of reduction in stopping distances at low speeds. They generally help from much higher speeds with multiple stops that can cause stock brakes to start fading.
VaderSS is offline
Old 08-04-2016, 08:21 PM
tsmgguy's Avatar
Other Motorcycle: 2007 Ducati GT1000
Extra Motorcycle: 2003 Triumph T100
The stock brakes on my T120 are some of the best I've ever ridden with. I'm contemplating no changes.
Photo: Ducati GT1000 at Utah's Bonneville Salt Flats
tsmgguy is online now
Old 08-04-2016, 09:04 PM
2Wheels1Carl's Avatar
My only issue with the brakes is the occasional squeal. I had the same problem with my 2006 Audi A4. Had the issue for years. Recently switched to a different material aftermarket brake pad, based on my mechanic recommendation, and it hasn't squealed since. I think it's got some kind of metallic compound that makes it squeal if the brake dust builds up too much. Not sure if it's the same with my T120 but it's a minor thing.
2Wheels1Carl is offline
Old 08-05-2016, 09:16 AM
Main Motorcycle: 2007 T100
Other Motorcycle: 06 Scrambler, 01 Bonnie
I am very satisfied with the brakes on my T120, so much better than the T100 even with the upgrades for the T100. I have a couple of Moto Guzzi's with Brembos and the T120 is comparable.
danketchpel likes this.
menzies is online now
T120 oil leak / Brake Squeal geb Water Cooled Twins Technical Talk 76 12-31-2017 12:29 PM
2016 Triumph T120 Vs. Indian Scout u6crash Biker Hang-Out 51 09-05-2017 08:48 AM
T120 Brake Pedal Adjustment? tsmgguy Water Cooled Twins Technical Talk 5 06-01-2016 07:41 PM
95 TB Brake upgrade - keeping my stock MC GJBushman Hinckley Classic Triples 4 03-16-2016 12:49 PM
Trident front brake upgrade mynamesrob T3 Sport / Touring Forum 2 04-20-2015 05:58 AM
