Checking Coolant on Thruxton R - Triumph Forum: Triumph Rat Motorcycle Forums
 4Likes
  • 2 Post By Ashman
  • 2 Post By steve betts
post #1 of 7 (permalink) Old 07-25-2016, 01:13 AM Thread Starter
Main Motorcycle: 2006 Bonneville T100
Anyone else have a hard time seeing the coolant level on the Thruxton R without taking off the sprocket cover? Without a flash light it look empty and with a flash light the whole things green. What's the trick?
creamcycle is offline
post #2 of 7 (permalink) Old 05-30-2019, 02:31 AM
Main Motorcycle: TBS,Daytona 900
Other Motorcycle: Speed Twin
Surprised you got no reply........ I just tried checking mine on the Speed Twin with a torch but couldn’t definitively gauge where the level was. Will remove the sprocket cover.......
Anyone care to add how they check the coolant level.......
Burren Boyo. is online now
post #3 of 7 (permalink) Old 05-30-2019, 07:37 AM
Main Motorcycle: 2016 Thruxton S
Ashman's Avatar
Other Motorcycle: 850 Norton Featherbed
Extra Motorcycle: 1960 650 Manxman
Send a message via Yahoo to Ashman
I just checked mine the other day, it takes less than a minute to undo 4 bolts to pull the sprocket cover off and put back on, no big deal and a lot easier to see the level, after 1 1/2 years the level is the same.
Ashley
retjustdad53 and saddlebag like this.
Ashman is online now
post #4 of 7 (permalink) Old 05-30-2019, 11:22 AM
Main Motorcycle: ThruxtonR,
pmorritt's Avatar
Other Motorcycle: BMWR1100RT
Yup. Thats what you have to do to get an accurate look. PITA. Almost 3 yrs on the R and still full when cold.
Masquerading every day as a normal person is exhausting.
pmorritt is offline
post #5 of 7 (permalink) Old 05-30-2019, 01:32 PM
No worries just thought there might be a shortcut for it. The torch trick works on some bikes...........
post #6 of 7 (permalink) Old 05-30-2019, 07:29 PM
Ashman's Avatar
Its quicker taking those 4 little bolts out than trying to see the level in that small sight area, so really the sprocket cover removal and putting back on is the shortcut
Ashley
post #7 of 7 (permalink) Old 05-31-2019, 02:58 AM
Main Motorcycle: '17 Thrux R
steve betts's Avatar
Other Motorcycle: '02 Bonnie (set free)
You need a torch and good eyesight to check the oil too. Not loving the smoked glass oil window. Fortunately doesn't seem to burn oil or coolant.
Ashman and retjustdad53 like this.
NRC FEK, Pazzo levers, CRG lanesplitter mirrors, BC blinkers, Rizoma reservoir, DID gold chain.
steve betts is offline
Thruxton R vs Thruxton Brake Master Resevoir SUPERCRUZ Water Cooled Twins Talk 5 06-29-2016 09:00 AM
Thruxton tube fork spacers vs Scrambler tube spacers Sactown Speedy Air Cooled Twins Technical Talk 7 01-31-2016 12:03 AM
Coolant change... Triplewannabe Speed Triple Forum 7 01-07-2016 06:35 PM
