My TT600 - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 09-26-2019, 05:52 PM Thread Starter
Grant1's Avatar
My TT600
Bike is great but could do with an up to date map as it's not very smooth
ID:	656800   Click image for larger version
Grant1 is offline
post #2 of 12 (permalink) Old 09-26-2019, 09:49 PM
Main Motorcycle: 1997 Trophy 900
doofus's Avatar
hope that oil in the first photo didn't come out of *your* bike...
always thought the TT600 was cool as ****..nearly bought one a couple of times, each time things didn't quite work out. I thought it would be a nice contrast to my Trophy. There's not a lot around these days..anyway, if you're in search of advice you've come to the right place-there's a wealth of knowledge on this forum. Hope you get it sorted soon!
doofus is offline
post #3 of 12 (permalink) Old 10-02-2019, 11:17 AM
Main Motorcycle: Very fast 675
Official Leathers Tester
Will's Avatar
Other Motorcycle: DRZ 400 Bad Idea
I love the headlights. It looks decent with the stock headlight, but that's even better.
What year is your bike? Is it a 2000? Just a guess based upon the black frame. There's a whole lot that can be accomplished with mapping, and things that you can do that don't require a complete remap.
Will
Will is online now
post #4 of 12 (permalink) Old 10-08-2019, 12:01 PM Thread Starter
Grant1's Avatar
It's a 2002 reg but I've just recently fitted a 2001 engine with 4k miles on it so should be good for another 10 years +
Grant1 is offline
post #5 of 12 (permalink) Old 10-08-2019, 12:02 PM Thread Starter
Grant1's Avatar
The bike has had lots of work done powder coated the frame also
Grant1 is offline
post #6 of 12 (permalink) Old 10-08-2019, 12:39 PM
Will's Avatar
Gotcha. Load up the 2002 and later map. Use the one for an open can if you have an open can on the exhaust. Make sure the throttle bodies are synched up properly. That makes a difference. There's a "hole" in the timing below about 4k or 4500 rpm. I don't remember now, but if you fill that hole to smooth out the timing, it usually helps a bit. Then richen the mix a bit down low or use fuel idle trim adjustments to do something similar. All of those should help smooth it out.
Will
Will is online now
post #7 of 12 (permalink) Old 10-08-2019, 03:35 PM Thread Starter
Grant1's Avatar
I've been researching the tune ecu maps etc and hopefully once I've done the remap it solves the issue. It's not the best of weather here in the west of Scotland just now so maybe leave the test runs until better weather but I'll post any updates
Grant1 is offline
post #8 of 12 (permalink) Old 10-09-2019, 02:51 PM
Will's Avatar
I would just start with a stock map.
Will
Will is online now
post #9 of 12 (permalink) Old 10-09-2019, 07:01 PM Thread Starter
Grant1's Avatar
Yes that's what I'm thinking aswell I'm not too clued up on personalizing maps I dont want to cause any damage
Grant1 is offline
post #10 of 12 (permalink) Old 10-09-2019, 07:05 PM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
The Speed Four maps are much smoother and less abrupt. 10164 if you still have SAI otherwise 10167. They work equally as well with aftermarket or standard exhausts and have proven popular with lots of TT600 owners.
Terry Colley is offline
