Tt600/speed four oil cooler - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 06-18-2019, 04:28 PM Thread Starter
Tt600Hampton's Avatar
I’ve noticed some tt600’s and speed fours have oil coolers fitted and some don’t. Were these optional extras or country/area specific?
Thinking about fitting one to my tt600 (that is now semi-naked) purely as it runs hot anyway so wouldn’t harm it if I were to fit (uk summer time use only)
Would the oil filter be different from the HF191 (or equivalents) if so what oil filter would I need and any ideas how the coolers are mounted?
Thanks
Tt600Hampton is offline
post #2 of 8 (permalink) Old 06-19-2019, 11:32 AM
Main Motorcycle: Very fast 675
Official Leathers Tester
Will's Avatar
Other Motorcycle: DRZ 400 Bad Idea
Oil cooler? I don't recall an oil cooler on either TT600 I had, nor do I recall an oil cooler on any of the S4s I saw over the years. Do you have a picture of what you are talking about?
Will
Will is offline
post #3 of 8 (permalink) Old 06-19-2019, 04:23 PM Thread Starter
The water fed oil cooling jacket under the oil filter. (Not conventional air cooled like on a bandit) Usually has a water in pipe and water out pipe.
A previous later model tt600 I had that was imported from Europe had one, my current early uk model does not.
Is it a case of buying a jacket an extended spindle plus pipework and screwing it on or are the threads on the block different?
post #4 of 8 (permalink) Old 06-19-2019, 05:39 PM
Will's Avatar
Gotcha. I don't know the answer to any of those questions. What I can tell you is that if you are planning something like that, it's a good idea to check clearances. I'm not sure how it would fit with the exhaust header. But, if you have seen it done, then it can be done.
What I found is that a properly running TT600 will see indicated temperatures up to 110 C or more sitting in traffic. The temperature then drops to about 70 C when you are back in motion.
Will
Will is offline
post #5 of 8 (permalink) Old 06-24-2019, 07:45 AM Thread Starter
All sorted. Bought a second hand jacket, spindle and pipework. The standard 191 oil filter fits also.
post #6 of 8 (permalink) Old 06-24-2019, 11:07 AM
Will's Avatar
Good to hear. I'm curious to see what it is you mean. I just flat don't recall anything like that.
Will
Will is offline
post #7 of 8 (permalink) Old 06-24-2019, 11:24 AM
Main Motorcycle: TT600
Other Motorcycle: Yamaha TRX850
Extra Motorcycle: Guzzi 1000
Baldrick61 is offline
post #8 of 8 (permalink) Old 06-24-2019, 07:23 PM
Will's Avatar
Originally Posted by Baldrick61 View Post
Thanks. Live and learn. I never had a reason to think about that part, let alone replace it. I wonder why anybody would remove it.
Will
Will is offline
