Stock Speed 4, jerkiness => TuneECU - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #11 of 13 (permalink) Old 05-28-2019, 03:56 PM
Main Motorcycle: Bandit 1200
Brett8206's Avatar
Other Motorcycle: Triumph speed four
Extra Motorcycle: Kawasaki vn 800
Will I loaded the stock map then took that back a notch. I came to this discision also because it ran worse with the baffle in. Don't get me wrong it does do it very slightly but in a manageable rev range.
Brett8206 is offline
post #12 of 13 (permalink) Old 05-29-2019, 03:09 AM Thread Starter
Main Motorcycle: Triumph Speed Four 2004
@Brett8206 From the other thread you seem to have an aftermarket can? Mine is the stock one.
Since air/fuel ratio was discussed here's the map from stock tune (10167). It is also the same on 10164+air+ex+I limit tune. Out of curiosity I checked that 10089 (TT600 + exhaust) map has values up to 17.0 and other member have been happy without any changes to this
radjiv is offline
post #13 of 13 (permalink) Old 05-29-2019, 04:18 PM
Brett8206's Avatar
Well i did want a stock can to see if it sorted my problem out, as others have said it did for them. I can't remember what number map mine was but it was the same as what is on the ecu label. I think i smoothed out the fuel trim. I changed it to graphic mode and smoothed out the graph. Im no expert, this is what worked for me.
TuneECU For Dummies -Installation Guide and Questions pertaining to Installation Ebster1085 ECM and FI Tuning - Help, Tips & Tricks 337 08-03-2019 07:49 PM
2016 STR or wait for the rumored 800 in 2017? eric nyc Street Triple Forum 199 12-21-2016 02:52 PM
TuneECU Help - 2010 Speed Triple McGarnicle Speed Triple Forum 5 05-10-2012 11:43 PM
TuneECU remap help 09 Speed Triple jgerman ECM and FI Tuning - Help, Tips & Tricks 2 07-11-2011 07:37 AM
Top speed of stock S4,TT600 & D600? Serious_Dave Triumph SuperSports 26 12-20-2003 01:10 PM
