tank: fuel plate bolt - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 04-05-2019, 09:19 PM Thread Starter
Main Motorcycle: 01 TT600
jamesonepp's Avatar
Last year I was extremely frustrated with my '01 tt600. Replaced the fittings on the fuel pump (plastic ones snapped during maintenance... this also took three trips to the dealer, 1 hr drive each way), snapped off one of the fittings in the fuel plate and ended up replacing the fuel plate... Upon reinstallation, fuel sprayed everywhere. New plate didn't make a good seal. Try to remove it... and sheared off one of the mounting bolts on the tank. Fahhh!
Now that it's sat for a while and the gravel is almost all off the road, and I've chipped away all the ice from the bike...
Can I replace that bolt somehow? Drill it out and weld a new one in? Or am I looking at a new tank?
Also the inside is rusty, but it looks like surface and probably easily cleaned from what I see on here.
Thanks ya'll.
Jameson, like the Whiskey.
Jack of All Trades, Master of Some.
jamesonepp is offline
post #2 of 16 (permalink) Old 04-06-2019, 10:12 PM
TrueBlue02's Avatar
Hey man I just finished that nightmare. Just bought a 05 S4 and the PO didn't have the airbox on correctly, took off the fuel tank and Bam! Male fuel connector broke. Local Triumph dealer hooked me up with new aluminum ones because obviously PO didn't use the recall, clipped them in and Bam! Female connector broke. I should of replaced them before one broke, the other one came out smooth. Patience with a dremel and a pick, and a 1/4 BSPT tap, quick couplings metal females and back in business. Did you try to remove and tap the broken female before replacing the plate? Reinstall or replace ring gasket under the plate? Sucks about the bolt, Not sure a weld would hold but worth a try.
TrueBlue02 is offline
post #3 of 16 (permalink) Old 04-06-2019, 10:28 PM Thread Starter
jamesonepp's Avatar
No gasket... looks like a metal-metal seal?
Sent from my iPhone using Tapatalk
post #4 of 16 (permalink) Old 04-06-2019, 10:39 PM
TrueBlue02's Avatar
post #5 of 16 (permalink) Old 04-07-2019, 10:48 PM Thread Starter
jamesonepp's Avatar
No O ring on either the old plate and the new... curious
That would make sense.
post #6 of 16 (permalink) Old 04-08-2019, 06:13 AM
TrueBlue02's Avatar
That should be the seal problem, only a $5 fix, and maybe salvage the old plate by carefully removing old connector, tapping the threads, sell the new plate to offset cost of repairing tank bolts or towards another tank and get back out there.
post #7 of 16 (permalink) Old 04-08-2019, 09:35 PM Thread Starter
jamesonepp's Avatar
Bikebandit... $30 to ship an O ring to Canada. As much as I dislike our "local" dealer (read: 1hr drive from me) methinks I'll be calling them first or looking for another source.
post #8 of 16 (permalink) Old 04-10-2019, 12:06 AM
TrueBlue02's Avatar
Yeah I would, dealer here in Philly has always given me a better deal on parts than online, and they can offer advice if needed.
post #9 of 16 (permalink) Old 04-21-2019, 09:32 AM Thread Starter
jamesonepp's Avatar
Took the tank into the custom bike shop here in town and they seem to think itís an easy fix... drill out the old bolt, and use aircraft grade silicone to make a form-a-gasket? Apparently that stuff is fuel-proof...
post #10 of 16 (permalink) Old 04-22-2019, 01:01 PM
TrueBlue02's Avatar
So they're thinking of drilling the bolt and fill the hole with gasket material and I guess thinning the other bolts will secure they plate enough to prevent leaks? Is that also using the O ring gasket?
FuelBot - Fuel Level & MPG Gauge DEcosse Speed Triple Forum 53 02-10-2018 02:11 PM
Bonneville EFI Fuel Pressure Check Forchetto Air Cooled Twins Technical Talk 17 09-11-2017 04:12 PM
Potential fuel pump plate issue.... Captain Bob Daytona Deliberations 3 04-22-2015 09:29 AM
Tiger 955 external fuel filter? jdeng Tiger's 885i & 955i - Mods & Workshop 2 09-27-2012 11:13 AM
Info on removing fuel pump and plate from EFI tank Mingo09 Air Cooled Twins Technical Talk 2 04-12-2010 09:46 AM
