Speed 4 brake solution? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 14 (permalink) Old 03-22-2019, 08:31 PM Thread Starter
Main Motorcycle: Speed four
farmer_frank's Avatar
Other Motorcycle: SV650
Extra Motorcycle: SV1000
Been having problems with my brakes going soft from time to time. Also noticed a substantial amount of brake fade the last time I took it to the track (high speed track). Being a novice/intermediate level rider I doubt i'm cooking the brakes that much. I've already pulled apart the calipers, cleaned, and thoroughly bleed the brakes.
What's the end all brake solution for these things? Thought I read something about using the brake pistons from the Daytona 675's.
farmer_frank is offline
post #2 of 14 (permalink) Old 03-25-2019, 12:52 AM
Main Motorcycle: 06 Sprint R.I.P. 2017
kubbie's Avatar
Other Motorcycle: 00 TT600
Extra Motorcycle: 16 Griso
That was for the Sprints brakes...... might work on the TT's too.
Double check on the Sprint forum.
Noticed today mine had a lot of free travel. Will pull the calipers, pump the pistons out most of the way, hose them with brake cleaner and an old tooth brush. Should be good to go.
kubbie
"I'll call you if you need me"
kubbie is offline
post #3 of 14 (permalink) Old 03-25-2019, 07:16 PM
Main Motorcycle: Very fast 675
Official Leathers Tester
Will's Avatar
Other Motorcycle: DRZ 400 Bad Idea
My take is that you have air in the brakes somewhere. How old are the lines? Have you rebuilt the MC and calipers? Not just cleaned, but replaced the rubber. None of that stuff lasts forever.
Will
Will is offline
post #4 of 14 (permalink) Old 04-25-2019, 05:25 PM
Le0theb0red1's Avatar
Daytona 675 pistons is the fix. Something to do about the fancy coating the pistons have that the Sprint's, TT600's, and Speed 4's dont have.
Le0theb0red1 is offline
post #5 of 14 (permalink) Old 04-26-2019, 01:55 AM
Main Motorcycle: 2004 Daytona 955i
Other Motorcycle: 2006 1050 Speed Triple
Extra Motorcycle: Vespa PX200
This has been an issue with that master cylinder/caliper combo for ever. Affects T595. 955 Daytona/Speed Triple, Sprint RS/ST, TT600, Daytona 600/650 and Speed4.
Bothers some people, others just live with it.
Been discussed to death with some very creative bleeding methods proposed.
Yes, you can bleed it to buggery, you can reverse bleed it, you can tie the brake lever back to the handlebar for a week, you can replace all the seals, you can swop the caliper pistons. It'll still go squishy with lots of lever travel. Air getting in the system? Maybe, but no one, including Triumph, has worked out how. The problem even carried over to the first '05-'07 radial caliper equipped 1050 Speed Triple. Yes, Triumph identified an issue with some of the coatings on some caliper pistons and issued a Tech Bulletin about it. One of several they issued over the years about the issue.
You want to fix it?
Replace the stock 14mmØ master cylinder with a 5/8"Ø unit from one of the '07 and on 1050's as Triumph eventually did (hallelujah). Less lever travel, much firmer feel. That bit we understand. Oh and it doesn't go squishy a week after bleeding. Go figure. That bit we don't understand.
Terry Colley is offline
post #6 of 14 (permalink) Old 04-26-2019, 02:03 AM
BTW you can use a 5/8"Ø master cylinder off another make of bike. It's a Nissin. Kawasaki used the exact same one with the same remote reservoir for many years and they're plentiful at the wreckers.
Let us know how you go.
post #7 of 14 (permalink) Old 04-29-2019, 01:06 PM
Will's Avatar
I believe you can.
Will
Will is offline
post #8 of 14 (permalink) Old 04-30-2019, 01:16 AM Thread Starter
All years of the D675 use the same brakes? Probably find a cheap set of calipers off fleabay and steal the pistons. Planning on doing a full brake system overhaul and figured i'd do the pistons while I was in there, but couldn't find where I read about the daytona pistons.
post #9 of 14 (permalink) Old 04-30-2019, 01:24 PM
Will's Avatar
I'll be interested in knowing how everything fits.
Will
Will is offline
post #10 of 14 (permalink) Old 05-01-2019, 12:38 AM Thread Starter
How many different brake packages did triumph offer on the D675? Parts listing for the 2006 model shows three different calipers, (standard nissan, monoblock nissan, brembo) and of course they all have different piston/seal kit part numbers. Knowing my calipers are just rebranded nissans we'll focus on the nissans. The standard split caliper nissan uses piston/seal kit T2020465 which shows as a fit for a wide range of bikes going all the way back to 1994 on the speed triple. The monoblock caliper piston/seal kit is T2021222 which fits only D675's from 2006 onwards.
Upon further inspection I discovered that the split caliper nissans use the same seal kit as the speed four so one would think the pistons would be a direct swap. I suspect the monoblocks use the same piston, but using different seals the piston/seal kit number is different and they don't offer the pistons by themselves so we can't directly compare part numbers between them.
08 Speed triple horn and brake light not working Aurobindo Speed Triple Forum 4 05-15-2016 10:18 PM
Brake Pedal Solution? slates74 Club Cafe' 17 06-08-2012 06:55 PM
2011 Speed Triple Review by Cycle World TonioStyle Speed Triple Forum 6 01-25-2011 09:01 PM
Speed Bleeders and general brake issues kuhlka Speed Triple Forum 6 03-22-2005 01:13 PM
