Complete Instructions for Rebuilding Forks and Changing Fork Oil - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
 2Likes
post #11 of 20 (permalink) Old 05-14-2012, 05:45 PM
Main Motorcycle: Very noisy Daytona 600
BF, My D6 manual states 112mm with fork fully compressed?
Scorch is offline
post #12 of 20 (permalink) Old 06-30-2012, 09:30 AM
Main Motorcycle: tt600
aawesome
hexen1095 is offline
post #13 of 20 (permalink) Old 01-02-2013, 02:43 PM
Main Motorcycle: 2010 Scrambler
Scrambler forks
Thanks for your great post. I have a 2010 Scrambler and I live in Kigali, Rwanda. I was hit by a truck on a country road out here 4 months ago, and the bike has been sitting ever since, as I slowly accumulate the parts I've needed to replace the fork tubes and front wheel / disc.
I'm a novice, yet there aren't mechanics out here that know the bike, so I've got to do it myself. I'm getting close, but I have a few questions, and will likely have more.
I've got the fork sliders in, and I'm now trying to get the fork seal situated into the outer / lower (black) fork. There's loads of emphasis in your post on placing the seals right side up, and I'm cross referencing with the shop manual, which I've found has been useless at critical times. My notes tell me that the fork seal "right side up" is that which has the thin metal band right side up. I have photos I can send, and it might be better to send via email. The issue I'm having is that the seal is flush with the top of the lower black fork; using the specialty tool that I paid a fair bit for doesn't help me push it in so it is sunk below the top of the lower black fork. Tried with hammering the specialty part in position, for 10 mins or so, but to no avail. Not sure what I'm doing wrong here, other than to suspect I may have it in wrong or that I need to use more force, which seems a bit dicey.
Secondly, the other specialty part I had to buy for this repair - a long rod that I'm unclear what to use for. Is it somehow supposed to brace the damper rod so I can fully tighten the damper rod bolt?
Grateful for any advice you can provide. Thanks a lot in advance.
Stephen
sfberlinguette is offline
post #14 of 20 (permalink) Old 01-02-2013, 08:37 PM
Main Motorcycle: Very fast 675
Official Leathers Tester
Will's Avatar
Other Motorcycle: DRZ 400 Bad Idea
Considering that a Scrambler is a very different bike from a TT600, you might be better off asking in the twins forum. I'm sure somebody there has taken apart Scrambler forks.
Will
Will is offline
post #15 of 20 (permalink) Old 01-05-2013, 10:21 AM
Will - you're right...but I finally figured it out anyway. Back on the road now.
post #16 of 20 (permalink) Old 02-04-2013, 08:40 PM
Main Motorcycle: '02 Daytona 955i
Other Motorcycle: 02 KZ1000P
Extra Motorcycle: 09 Versys
BF, tremendous write-up. I have a question though on my
2002 Daytona CE. I have my forks apart and draining in my kitchen and will be replacing seals and wipers. I don't understand the oil lock part and the need to remove it. As I look through the bottom hole I don't see anything. Also, do I need to do anything with the compression adjuster at the bottom of the fork leg?
thanks, Mark.
blipco is offline
post #17 of 20 (permalink) Old 02-22-2013, 07:58 PM
Main Motorcycle: bmw f650gs
Other Motorcycle: 1997 tiger
Extra Motorcycle: 1998 motto guzzi
Haynes wouldn't let you give that much info they want you to have to guess about 1/2 of the info
pescarr is offline
post #18 of 20 (permalink) Old 06-26-2013, 10:51 PM
Main Motorcycle: Aprilia RST-1000 Futura
spaz_666's Avatar
Other Motorcycle: Triumph Speed Four
Extra Motorcycle: Ducati Monster 620 Matrix
Anyone found a way to do this without Special Tool 3880090-T0301?
I've done complete fork rebuilds on a Ducati, two Aprilias, and a Suzuki (both conventional and inverted), and never needed a tool like this before.
Would anyone with this tool be willing to post pictures & measurements so we could come up with a way to fabricate a less expensive alternative?
Thanks!
spaz_666 is offline
post #19 of 20 (permalink) Old 04-06-2014, 11:16 AM
Main Motorcycle: Daytona 650
Panthera1123's Avatar
Very helpful. I will be using these instructions soon.
Alea iacta est- Julius Caesar
Panthera1123 is offline
post #20 of 20 (permalink) Old 04-04-2018, 01:29 AM
Here is how my oil lock was oriented in both my fork legs on my 01 tt600.
chdrummerdude is offline
fork removal '98 T595 instructions mjonesjr8 Daytona Deliberations 0 07-15-2011 10:44 PM
Instructions for Fork Boot installation mybluett Air Cooled Twins Talk 9 09-22-2006 12:17 PM
fork rebuilding quagmire Classic, Vintage & Veteran 10 08-11-2005 09:00 AM
