955i poor start - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
post #1 of 7 (permalink) Old 09-04-2019, 09:53 PM Thread Starter
Newbie
Richard J's Avatar
955i poor start
Hello, I am in need of some guidance. I’ve got two problems with my tiger. Maybe related, maybe not. It’s a ‘01 with 105K.
First, it’s struggles to start when cold. It stumbles after starting for 5 to 10 seconds, then idles up and runs perfect. Then each start up after warm is fine.
Second, the starter does not turn over when I initially press the starter button. After the second or third press it starts. I can see the warning lights dim slightly when pressing the starter button each time.
I’m relatively green to this bike. I’ve only done oil changes, plugs and air filter type of stuff on it. I’m still searching for parts supplies as well.
Any help greatly appreciated!
Richard J is offline
post #2 of 7 (permalink) Old 09-05-2019, 05:26 AM
Main Motorcycle: Sprint GT 2011 Blue
When did you last check the valve clearance?
Regarding the starting button, maybe some contact cleaner in the starter button/clutch contact/side stand contact.
I don't recall the interlock on 955. Clutch switch for sure (ground of the solenoid command).
Fred
fredsprint is offline
post #3 of 7 (permalink) Old 09-05-2019, 11:09 AM
Main Motorcycle: Tiger Explorer
lobout's Avatar
Other Motorcycle: Honda 300
I'd check the IACV and hoses. The hoses are notorious for cracking and leaking with age. My 955 had a problem starting and idling, and it was fine after cleaning the IACV with alcohol. As fredsprint says, make sure the sidestand and clutch switches are clean
lobout is offline
post #4 of 7 (permalink) Old 09-06-2019, 03:09 PM
Newbie
Main Motorcycle: Tiger 955i
Yamoto.by's Avatar
try another battery
Yamoto.by is offline
post #5 of 7 (permalink) Old 09-07-2019, 09:45 AM Thread Starter
Newbie
Richard J's Avatar
Great ideas, I’ll check those all. I didn’t realize I need to be checking valve clearance. Is that something I could easily do myself, or should I take it in? The closest shop that will work on my bike is about 6 hr drive, from me.
Also, parts? What supplies are you guys using?
Thank you!
post #6 of 7 (permalink) Old 09-08-2019, 12:47 PM
lobout's Avatar
Valve clearances need to be done every 10000 miles. They'd have to be really bad to affect performance/starting though. It's time consuming to check them but not that difficult. You'll need a workshop manual though. If you don't have the proper tool, ($$$$) the cams need to be lifted to change the shims. It's going to be expensive to get it done at a $hop. Don't know about parts because you don't say your location
lobout is offline
post #7 of 7 (permalink) Old 09-08-2019, 01:00 PM
Yes, checking valve clearance is an easy job to do providing you know the basics of mechanic.
Adjusting the valve gaps (if needed) is more difficult but requires a lot of attention an precision. Still not rocket science. Shims are 25mm.
As you have a first gen 955 (no O2 sensor and automotive alternator), changing the shims (over bucket) doesn't require to remove the cam shaft. You need a special triumph too though.
Here is a tutorial. But I guess many other are available.
BTW can you fill out your bike type and year in your profile so that people knows about it to help you better?
Fred
