Mushy front brake - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
 8Likes
post #1 of 18 (permalink) Old 08-12-2019, 05:05 PM Thread Starter
Main Motorcycle: 2006 Triumph Tiger 955i
Other Motorcycle: 1996 Triumph Trophy 900
Extra Motorcycle: 2018 Beta 300rr
Mushy front brake
Hello, long time observer, first time posting, so please go easy on me. I have a 2006 tiger 955i that I absolutely love. I keep up with the maintenance as best as I can and fix items as soon as they pop up. With that said, I replaced the front pads and wanted to flush the brake fluid with some fresh stuff. I have done fluid flushes countless times on many motorcycles and have rarely run into a problem. This time around, however, my brake lever feels mushy. Not to the point where it doesn't stop, it just feels like there is less resistance than average. It definitely has less resistance than my 96 trophy. Any suggestions? Anyone have this issue?
Dirtnapp is offline
post #2 of 18 (permalink) Old 08-12-2019, 05:50 PM
Main Motorcycle: 02 Sprint RS
Steve Ford's Avatar
Other Motorcycle: 06 Tiger
Extra Motorcycle: a few others
Remove the calipers, pump the pads closed, scrub the pistons as clean as you can get them with some brake cleaner and a pipe cleaner or something, coat the pistons with some Permatex Brake Piston grease, lever the pads shut, pump closed, lever back, etc. a few times.
Lube the pad pins and the caliper hanging pin with the grease as well.
That should do it and do the same for the rear as that sucker will crust in place and burn up your pads.
How do I know this, you ask...
Steve Ford is offline
post #3 of 18 (permalink) Old 08-12-2019, 08:26 PM Thread Starter
Looks like I have a nice little project for this weekend. Thanks for the help
Steve Ford likes this.
Dirtnapp is offline
post #4 of 18 (permalink) Old 08-13-2019, 05:46 AM
Main Motorcycle: 2006 Tiger '955
Hi........welcome to the forum
I've always struggled to bleed Tiger brakes properly, so could be something as simple as a bit of air in the system ??
I would also check the condition of the piston seals. A new set really does transform the brakes.
Safe riding.
Regards,
Graeme.
Tiger-G is offline
post #5 of 18 (permalink) Old 08-13-2019, 09:18 AM
Main Motorcycle: 2006 Tiger 955i
Lee337's Avatar
Other Motorcycle: Honda CB-1 (CB400f)
Had to rebuild the calipers on my 2006 Tigger just after i bought it as the seals needed replacing. I remember having a real issue bleeding the brakes, even with a vacuum pump to draw the brake fluid through.
In the end, I removed the calipers from the fork legs and raised them up as far as I could without stretching the brake lines and bled the lines through again. I followed this up with pulling the brake lever back as far as I could and cable tying it in position overnight.
Next day they were hard as nails & almost 12 months later are still pretty much the same.
If you have a particular faith or religion, that is good. But you can survive without it.
Dalai Lama
No matter how smart you are you can never convince someone stupid that they are stupid.
Lee337 is offline
post #6 of 18 (permalink) Old 08-13-2019, 03:26 PM Thread Starter
I suppose I will try and clean/grease them first. If that doesn't work I can rebuild them. Any reputable rebuild kits I should consider?
Dirtnapp is offline
post #7 of 18 (permalink) Old 08-18-2019, 09:44 AM
Main Motorcycle: 2011 Thruxton
Jayell's Avatar
Other Motorcycle: 2002 Tiger 955i
Extra Motorcycle: Mrs. Jayell's '13 CB500F
I replaced the seals on my rear caliper this week. The seal kit is Triumph part #T2020505, about $42.00. An alternative is Honda part #06431-MA3-405, about $6.00, but you'll need two Honda kits per caliper. Any seal kit which fits a Nissin two piston caliper should work. The pistons on the Tiger are 27mm. Don't take it from me, though; do your own research.
I'm not sure about using grease when when installing the pistons. I suggest using nothing but clean brake fluid. If the pistons and bores are clean and smooth, they'll drop right in. Don't forget to replace the banjo washers if you disconnect the brake hose.
Tying back the brake lever and leaving overnight is also a great idea, as Lee mentioned above.
Lee337 likes this.
Jayell: 2011 Thruxton - The Jewel, 2002 Tiger 955i - The Mule
Mrs. Jayell: 2013 Honda CB500F
Jayell is online now
post #8 of 18 (permalink) Old 08-20-2019, 07:55 PM
Steve Ford's Avatar
I don't know about Nissin but every Brembo caliper and master cylinder rebuild kit I ever sold came with a packet of assembly grease.
Good tip for the Honda part number!
Jayell likes this.
post #9 of 18 (permalink) Old 08-21-2019, 01:13 PM
Main Motorcycle: Tiger Explorer
lobout's Avatar
Other Motorcycle: Honda 300
I always had trouble bleeding the brakes when I had my 955. It was better when I pulled off the caliper and held it above the level of the master cylinder, thus allowing air bubbles to rise up before I started bleeding
lobout is offline
post #10 of 18 (permalink) Old 09-01-2019, 08:08 PM Thread Starter
I finally had a chance to tackle the front brakes. I took the Pistons completely out, cleaned them up, slapped some grease on them, worked them in and out a few times, and BAM.....I have brakes!!! Yay!! Thank you for all the help. I could not believe how dry/crusty they were. I suppose I will do that.back.as well.
Steve Ford and Lee337 like this.
Dirtnapp is offline
