Rough running and engine management light on - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
 1Likes
post #1 of 15 (permalink) Old 04-12-2019, 09:55 AM Thread Starter
Main Motorcycle: Triumph Tiger 955i
Hello,
My 955 has 30.000 miles, well looked after and ran like a dream. Yesterday I noticed the white smoke at start up seemed to go on for longer even after the bike had warmed up. Went for a ride and the bike run well except the throttle response seemed a bit 'snatchy'. The engine management light come on and the bike started to run like a tractor. The engine kept missing and I had to keep revving to stop the engine from dying. I carried on like this for 5 miles to get back home (I know you should have pulled over).
Started the bike this morning. Started easily but run rough for a bit and then cut out. Oil and water are good (for level and contamination). Battery is good and charges at 14.5V (has the wiring mod).
Any ideas as to the cause would be appreciated. I have read about MAP tubes being a common culprit (but don't know where these are or what they look like) ?????
Thanks.
dogday is offline
post #2 of 15 (permalink) Old 04-12-2019, 11:12 AM
Main Motorcycle: 2006 Tiger '955
Hi mate,
My immediate response would be to put it on TuneECU and read any fault codes, but that's when you come back with....."I haven't got TuneECU" ??
Safe riding.
Regards,
Graeme.
Tiger-G is offline
post #3 of 15 (permalink) Old 04-12-2019, 12:49 PM Thread Starter
Thanks for the reply Tiger-G. Your reply is spot on
I've heard of TuneECU but always stopped when reading the bit about "..... this can destroy your engine etc etc ". Could you tell me what I need i.e what cable to buy and where you would download the software. Many thanks.
dogday is offline
post #4 of 15 (permalink) Old 04-12-2019, 03:33 PM
Main Motorcycle: Tiger Explorer
lobout's Avatar
Other Motorcycle: Honda 300
You could also try Dealertool. I think mine cost 75 quid or so and it comes with everything you need
lobout is offline
post #5 of 15 (permalink) Old 04-13-2019, 01:44 AM Thread Starter
Thanks for the reply lobout. I'll look into the TuneECU option for now as it will cost about a tenner (assuming the cables off Ebay are OK??). Does anybody know what these MAP tubes are ? Ta.
Also, would this be suitable for a 2005 955i;
https://www.ebay.co.uk/itm/TUNE-ECU-...frcectupt=true
or would this work if I just wanted to know what the error code is?
https://www.ebay.co.uk/itm/Car-Fault...frcectupt=true
Many thanks
dogday is offline
post #6 of 15 (permalink) Old 04-13-2019, 05:39 AM
TuneECU is cheap as chips, as you're just paying for a cable. The software and maps are free, and it is brilliant for fault codes and installing new maps. I would go with that. I was scared stiff the first time I used it and remapped the bike, but after you're used it once, it's easy going
As for the MAP tubes ?? All I can think of is the IACV hoses ?? These are attached to the Idle Air Control Valve which is on top of the throttle bodies. They are plastic corrugated hoses and prone to cracks and leaks. They are soooo easy to replace, but are expensive if you go for Triumph originals. Many people improvise with silicone hose.
Edit: The link to the TuneECU cable looks ok to me. If their feedback is good....go for it !!
dogday likes this.
Safe riding.
Regards,
Graeme.
Tiger-G is offline
post #7 of 15 (permalink) Old 04-13-2019, 06:15 AM Thread Starter
Thanks for all the info Tiger-G. Looks like TuneECU is the way to go. Once I get an error code is it just a google search of the code or is there some specific Triumph list of error codes that I need from somewhere ??
Thanks.
dogday is offline
post #8 of 15 (permalink) Old 04-13-2019, 10:55 AM
Thanks.
TuneECU should provide the code and fault. If not, we'll sort you out on here
Good luck
Safe riding.
Regards,
Graeme.
Tiger-G is offline
post #9 of 15 (permalink) Old 04-13-2019, 12:16 PM Thread Starter
Good luck
Many thanks Tiger-G. I've got the USB lead on order and will let you know how I get on..... and maybe ask for more advice if it doesn't go quite to plan or hopefully
dogday is offline
post #10 of 15 (permalink) Old 04-16-2019, 10:28 AM Thread Starter
Problem solved
Bought the cable of ebay for 12.50. Installed TuneECU and drivers. Plugged in and......
P0352 - Ignition coil 2 circuit malfunction.
P1352 - Ignition coil 2 open circuit or short circuit to ground.
P0462 - Fuel level sensor circuit low input.
So it looks like a new ignition coil. Part number T1290006 if that is correct ????
Or could it be a break in the wire to the coil ???? I took a look but nothing obvious ?
Not sure about the fuel fault. There's half a tank of petrol and there's an intermittent fault to the fuel guage after hitting a large bump in the road.
Many thanks for your help Tiger-G. This has saved a lot of time and cost in trial and error fault finding !!!!
dogday is offline
Check engine light ON? Just phone your ECM... Forchetto Air Cooled Twins Technical Talk 32 06-13-2016 08:43 PM
Running rough and engine management light Londongeeza Thunderbird Twin - Technical Talk 4 04-23-2016 12:47 PM
02 Speed Triple - Check engine light ON, Fuel light ON, Oil Can Flashing Oil Light ON rogue1313 Speed Triple Forum 38 08-23-2012 10:54 AM
Engine Management Light lovecuba Sprint Forum 1 10-20-2008 08:36 PM
Engine Management Light! britishbulldog Speed Triple Forum 1 05-16-2004 10:18 PM
