Left heated grip sometimes not working - Triumph Forum: Triumph Rat Motorcycle Forums
Tiger's 885i & 955i - Mods & Workshop Workshop and technical talk for the 885i & 955i Tigers
post #1 of 3 (permalink) Old 04-10-2019, 02:54 PM Thread Starter
Main Motorcycle: 04 Tiger 709EN
Svampskaft's Avatar
As the title suggests, my left heated grip only seems to work sometimes. Any suggestions on where to look first?
Svampskaft is offline
post #2 of 3 (permalink) Old 04-10-2019, 04:00 PM
Main Motorcycle: 2006 Tiger '955
Hi mate,
First of all you could check you are getting a constant electrical circuit to the grip, but it is more than likely that the heating element wire has snapped. On occasions it might just make a contact and restore the circuit. It's happened to me before.
Nice simple solution.......peel the grip back, the wire is protected by a thin covering of "something", lift this with a sharp blade where the wire is snapped (it should be obvious where the wire has snapped). Solder in some fuse wire the same gauge as the original, and bob's your uncle, fanny's your aunt........a fixed grip
Good luck and keep us posted as to how you get on
Safe riding.
Regards,
Graeme.
Tiger-G is online now
post #3 of 3 (permalink) Old 04-28-2019, 10:37 AM Thread Starter
Svampskaft's Avatar
Hi,
Thanks for the help. I've finally got around to try what you said. Took off the grip and pulled both wires off. Not enough was remaining when I had striped the wires. I check the wire going to the grip and it had 12V and ground which is good. I've sent an inquiry to a local motorcycle junk yard. Hopefully I can get a cheap working left grip and just attach that one. The old one looked pretty beat anyway.
Water cooled Thruxton OEM heated grip issues B0llock$82 Water Cooled Twins Talk 8 10-05-2017 12:42 PM
Aftermarket heated grips with OEM heated grip controls mcmu72 Tiger 800 - 800XC Mods & Workshop 0 10-15-2014 08:34 PM
Heated grip wiring kpmunt Sprint Forum 2 08-07-2012 04:02 AM
Left grip keeps coming loose cgreer00 Speed Triple Forum 16 08-02-2012 03:47 AM
Heated grip connector- Shorted Bike John&hisorangebeasty Sprint Forum 2 02-18-2009 03:10 PM
